Espritmodel.com Heli Air
Old Dec 09, 2004, 08:21 AM
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
ESC Response at low throttle.
Well my "perfect motors" arrived yesterday, and they are... perfect. They turn at (rough guess) 60 rpm at 1.2V (One NiMh cell). The torque on that one cell is such that you can barely stop the shaft with your bare fingers. Even at 7.2V they are whisper quiet. Really, I can't say enough good things about these motors. If I didn't have Christmas shopping to do, I'd buy the entire lot this guy has.
Unfortunately (of course there's an 'unfortunately') my low cost ESC (~$20 w/shipping on eBay) won't spin the motor as slowly as it is capable of turning.
My understanding is that an ESC is basically a high speed switch, that controls the amount of time the switch is "on" and "off" per cycle in order to control the speed of the motor.
My motor and speed control abruptly transition from 'coughing' starts and stops to (400?) RPM at approximately 1/8 throttle.
Is this because my ESC is junk, or because the motor can't run on the heavily clipped waveform generated by the ESC at low throttle? Would a $$$ ESC give me the full range of throttle on the motor?
Regards,
Ray
RGinCanada is offline Find More Posts by RGinCanada
Old Dec 09, 2004, 01:39 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
you might find the last paragraph of bath trials in http://www.astecmodels.co.uk/elco.htm interesting.
martin richards is offline Find More Posts by martin richards
Old Dec 10, 2004, 08:27 AM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Thanks Martin,
After reading that article, It sounds like the ESC is the culprit.
I checked around for "scale boat speed controls" and in addition to astecmodels' I found the one available from www.modelcontrol.com and one from astroflight. Are there any others out there, and has anyone done a review comparing them?
I'd like the full range of control from dead slow (prop just turning) all the way up to wide open throttle. What ESC would you recommend?
Old Dec 10, 2004, 02:51 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
My main interest is fast electrics and an on/off switch would almost do for that. Hopefully some ot the scale types will be able to help with recommendations for specific types. How many amps do you think the motors will draw?
Old Dec 10, 2004, 03:02 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
These are slow efficient motors
Starting (inrush) current < 8A, Maximum continuous operating current 2.5A. Almost any ESC on the market will handle this, but which ones offer the best low speed control?
Anyone who's got an opinion, please chime in!
Old Dec 10, 2004, 03:04 PM
Columbus Ohio
Joined Mar 2004
Esc
I have used both Mtroniks and Electronize ESCs and have been very pleased with the results. Just my newbie 2cents.
Jason
Brutusjm is offline Find More Posts by Brutusjm
Old Dec 10, 2004, 04:20 PM
Shawnee KS
Joined Sep 2004
I'm hearing alot of good things about Hitec's EZX-R. I'm planing on putting one in "Father Goose". You might want to talk to Pat. He's who told me about them. Could
you please post the ebay thread for the motors again?
Fred
cop56 is offline Find More Posts by cop56
Old Dec 10, 2004, 07:03 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Thanks for the tip. I'll be sure to check it out. Pat, if you see this, would you add your comment?
Here's the motor links:
Motor:
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Specs:
http://www.mpm.maxonmotor.com/files/...f/04_124_e.pdf
Old Dec 12, 2004, 03:24 AM
Waihi, a small town in New Zealand
Joined Nov 2004
I have used several Electronize controllers and have been very happy with them, especially the help I received and the low parts cost to repair one when I managed to fry one (entirely my own fault). I have not tried the new models yet but have heard one good report. The explanation on their website of why variable frequency of pulse gives gentle start up and max power seems logical and you can also choose to stay locked on low or high frequency to get the response you want. I will certainly try one for the next project. That's my 5cents worth! Cheers, Ian.
Kiwimodeller is offline Find More Posts by Kiwimodeller
Old Dec 13, 2004, 09:22 AM
One apostrophe may be too many
patmat2350's Avatar
Motor City
Joined Dec 2004
See my note on low cost ESC's over in the SCALE forum.
You may/may not really need your motor to just "tick over"... real question is, does it go slow enough to make the boat just crawl?
And keep in mind that a geared solution may give you really slow prop speeds if that's what you're after. Using the Condor 20 ESC (at a lousy 50 Hz PWM frequency!) on a Speed 600 geared down 3:1, I can watch my tug's prop turning over, blade by blade...
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Dec 13, 2004, 10:36 AM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Hi Pat,
Thanks for the input. I read through the info on your website with great interest (particularly enjoyed the DUKW build).
It looks like the Hitek EZX-R may be the way to go, although I am considering investing in some higher end equipment as I intend to continue in this hobby for some time to come.
What I'd really like to do is try them all and buy the one I like best Ah well, lets wait and see what Santa brings...
Regards,
Ray
Old Jan 07, 2005, 08:30 AM
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
Originally Posted by RGinCanada
Hi Pat,
Regards,
Ray
Poor low speed motor control can be the result of 2 things. Some ESCs set a dead band where any throttle position below a preset value is considered no throttle. This causes a jump from nothing to a moderate speed as the throttle stick moves in a linear fashion. This is a simple method of compensating for variations in throttle trim. The other possibility is the ESC's switching frequency. At low motor speeds, low ESC switching frequencies are ineffective. RC ESC's operate in the several khz to several 100khz range. 100khz ESCs are very popular in the helicopter community. I have tested several of these and they have excellent low speed control. I can forward you a Microchip datasheet that gives more detail. Some of the ESCs you mention have low and high frequency capabilities. Anyway, for your application higher ESC switching frequency, 8khz or higher, will give better low speed control.
Bill
whanderson is offline Find More Posts by whanderson
Old Jan 07, 2005, 10:27 AM
patmat2350's Avatar
Motor City
Joined Dec 2004
I dunno... I have an ESC that runs at 50 (yes, fifty) Hz in my tug... I can slow the motor down to where I can see the prop blades ticking over one at a time... 3:1 gear reduction helps that a bit. One nice effect of the slow rate PWM is that the motor growls instead of whining at part throttle.
Pat M
Old Jan 07, 2005, 11:53 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
In my experience with rock crawling r/c trucks the higher the ESC frequency, the slower I can get the tires to turn. So slow in fact, that I can watch the lettering on the tire and read it easily. This with a 7K Hz esc.
Kmot is offline Find More Posts by Kmot
Old Jan 07, 2005, 01:36 PM
Joined Oct 2003
Pat M
First off, the 3:1 reduction helps quite a bit more than "a bit." Second a 50Hz ESC uses different technology than modern ESCs.
Bill
Discussion TB18 at low throttle ChuckB Castle Creations 2 Jun 13, 2006 04:41 PM
CD-ROM Motor runs rough at low throttle spudboy 3D Flying 8 Nov 30, 2004 03:56 PM
Brushless motor kicks back at low throttle settings??? New Park Pilot Power Systems 5 Aug 28, 2004 08:55 AM
ESC Efficiency at Low RPM? JRuggiero Power Systems 47 May 07, 2004 12:37 AM
Help with nose high E3D at low throttle Ninjak2k Sport Planes 15 Aug 05, 2003 11:31 PM
