Old Dec 08, 2004, 09:14 PM
ECOFLIGHT is offline
Find More Posts by ECOFLIGHT
ROCHESTER, NY
Joined Jul 2002
problem using esc with hitec 5x
I am trying to use a phoenix 35 brushless esc with my hitec 5x and 555 reciever. I cannot get the esc to arm, yet it works ok with a standard futaba radio and receiver.
I tried adjusting the end points to +-100 and +-125 , reversing the servo direction, and 0 trim, but I cannot get the esc to arm.
Any suggestions?
ECOFLIGHT is offline Find More Posts by ECOFLIGHT
Old Dec 09, 2004, 11:26 AM
TOhm is offline
Find More Posts by TOhm
Hitec / Multiplex USA
Joined Apr 2004
Hi ECOFLIGHT,
Try setting both endpoints to 125% and have the trim at zero. Then make sure the stick is in the down postion when you turn the ESC on. It should arm now.
Tony Ohm
TOhm is offline Find More Posts by TOhm
Old Dec 09, 2004, 04:38 PM
ROCHESTER, NY
Joined Jul 2002
I tried that, but it still won't arm. Bad esc?
Old Dec 09, 2004, 04:59 PM
TOhm is offline
Joined Apr 2004
What mode are you in? Is it ACRO or GLIDEACRO?
Old Dec 09, 2004, 05:05 PM
TOhm is offline
Joined Apr 2004
Old Dec 10, 2004, 01:11 PM
ROCHESTER, NY
Joined Jul 2002
ACRO MODE!
Old Dec 10, 2004, 03:39 PM
TOhm is offline
Joined Apr 2004
Sorry about the double post.
Have you tried to operate channel 3 with a servo? Does the servo seem to have full range? I'm hesitant to say the ESC is bad since it does work with your Futaba.
Old Dec 12, 2004, 02:16 PM
ROCHESTER, NY
Joined Jul 2002
I tried channel 3 with servo and I got nothing.
Must be a bad reciever!
Old Dec 12, 2004, 05:29 PM
Gonnacrash is offline
Find More Posts by Gonnacrash
Havin FUN
Gonnacrash's Avatar
United States, KS, Basehor
Joined Sep 2001
Eco.
Change TX to different model, if its programmed for model 1, go to model 2 or 3 and see if problem still there... Just a thought.
Don-Basehor, Ks
Gonnacrash is offline Find More Posts by Gonnacrash
Old Dec 13, 2004, 06:16 PM
BRENDAN LUGO is offline
Find More Posts by BRENDAN LUGO
Hitec service
BRENDAN LUGO's Avatar
San Diego
Joined Nov 2004
If your radio is set to mode 1 that could also be causing your problem. Double check to make sure the radio is set to the proper mode. This can be found on page 11 part B of your manual.
BRENDAN LUGO is offline Find More Posts by BRENDAN LUGO
Discussion using ESC with BEC cyclonite Power Systems 16 Nov 19, 2006 03:27 AM
Using NiMHs with Hitec Eclipse 7 Krason Hitec/Multiplex USA 2 Nov 17, 2003 12:29 PM
Help Needed: Can I plug-in a receiver battery while using a ESC with a BEC? CheeseWing Parkflyers 3 Sep 26, 2003 07:22 PM
CC Dragon 35 ESC with Hitec 3SS FM JeffD Electric Plane Talk 0 Jan 28, 2002 07:14 PM
Training with Hitec Flash 4/5X WAR Beginner Training Area (Aircraft-Electric) 2 Jul 27, 2001 12:02 AM
