Old Mar 01, 2002, 09:44 AM
Scomis is offline
Find More Posts by Scomis
Father of Ten
Salem, Or
Joined Sep 2001
Does This Sound Right?
A friend of mine has a graupner sp300 w/ 2.2:1 Gearbox with a gws 8x4 prop. He is using a pixie 20 esc which is fine to about 3/4 throttle. If you go above 3/4 throttle the motor stops. Why would this happen, It seems to me that the amp draw of that setup should be well within the range of the pixie 20. Is it a bad esc?
Any info would be helpful.
~scott
Scomis is offline Find More Posts by Scomis
Old Mar 01, 2002, 09:51 AM
Scomis is offline
Father of Ten
Salem, Or
Joined Sep 2001
I forgot to mention the battery pack he is using. It is a 6cell 700 mah Nimh Maxell pack.
~Scott
Old Mar 01, 2002, 09:52 AM
Gliderguy is offline
Find More Posts by Gliderguy
An Original!
Joined Aug 2001
Everything else being in good shape, you should check out the battery pack. Try another pack and see if you get the same results. Somehow the ESC is seeing less voltage than it wants, either too high of a drain or too low of a supply. that's one possibility anyway.
The other might be how the end points are set on your throttle.
Gliderguy is offline Find More Posts by Gliderguy
Old Mar 01, 2002, 10:41 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
I am fairly sure the problem is that the battery voltage is dropping too low and the LVC is kicking in. Do you have a voltmeter?
Doug
CoClimber is offline Find More Posts by CoClimber
Old Mar 01, 2002, 10:46 AM
Scomis is offline
Father of Ten
Salem, Or
Joined Sep 2001
He has another friend who does. I'm going to give him my 8 cell pack to try. It sounds like voltage though.
~Scott
Does this sound right? Beeping ESC, rumbling motor QuazBotch Power Systems 6 Aug 05, 2005 01:03 PM
Does this sound right to you? louisd Batteries and Chargers 1 Mar 25, 2005 02:55 PM
Question does this sound right? stirlingnut Power Systems 0 Mar 12, 2005 12:50 PM
Does this sound right? irate 850 iflych52 Batteries and Chargers 3 Mar 19, 2004 02:27 AM
GWS Spitfire - does this sound right? mattski Parkflyers 10 Sep 07, 2003 07:17 PM
