Old Dec 06, 2004, 02:03 AM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
T-38 Talon Park Jet
Here are BETA plans for the latest member of the Park Jet series, the Northrup T-38 Talon. This design is very similar in concept to the F-18 and F-15 Park Jets, and uses the same construction methods and recommended power setups. Like the other jets, itís intended to be a true park flyer built with simple construction methods and using inexpensive and readily available components. Here are the specs:
Wing area: 218 sq in
Span: 28.2 in
Length: 45.4 in
Weight RTF: 15 Ė 18 oz
Wing loading: 10.9 oz/ft2
Motor: GWS EPS-350 with C gearing (or brushless equivalent)
Battery: 1200 Ė 1500 mAh 11.1V Lithium-polymer
Prop: 8x6 (EPS-350) or 9x6 (brushless)
Flight controls: Wing flaperons, full-flying horizontal stabilizer
The general wing planform and tail moments of this design are fairly similar to the F-18 Park Jet, so Iíd expect the T-38 to fly similarly. However, because the real T-38 has such a small wing area this design also has a smaller wing area than the F-18 Park Jet (218 vs 254 sq in), making the wing loading a little bit higher. Thus, the T-38 will be a little hotter than the F-18, but if the weight is kept low it should still qualify as a park flyer.
The reason Iím posting beta plans is because these plans have been done for nearly a month and I havenít had time to build it yet, and with the holidays approaching I wonít have the time to build it for at least another month. And since many fellow Ezoners have expressed strong interest in building this jet, I decided to go ahead and post the beta plans now and let you guys help work out the kinks!
Please note that because these are beta plans they may have errors and that the CGs and control throws shown are untested. Thus, if you build this please take note of any errors or misalignments in the plans, and most importantly what CG and control deflections your finished model flies best with, and let me know. After I collect a list of improvements, Iíll update the plans (if I don't build my own copy sooner!). Both tiled and non-tiled files are posted below, as are previews of the plans.
Enjoy, and post pictures as you build this!
Steve
EDIT #1: (Aug 6, 2005) I finally had a chance to build this bird, so I've attached some photos below.
EDIT #2: (Aug 21, 2005). I updated the T-38 plans to fix several errors and include several design improvements, and also developed a new illustrated construction guide for this model. These are available in post #872 of this thread (link below):
http://www.rcgroups.com/forums/showp...&postcount=872
jetset44 is offline Find More Posts by jetset44
Old Dec 06, 2004, 02:21 AM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
That's AWESOME!... now you can get to work on this....
Akura2 is offline Find More Posts by Akura2
Old Dec 06, 2004, 02:24 AM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
or this....
Old Dec 06, 2004, 03:02 AM
RoverTomcat is offline
Find More Posts by RoverTomcat
Zoom-Zoom
RoverTomcat's Avatar
Switzerland, ZH, Dietikon
Joined Jun 2004
Whoa - Steve! That'll be my next jet...
Thanks for publishing the plans! Now where did I put my sanding mask?
Best regards - Paco
RoverTomcat is offline Find More Posts by RoverTomcat
Old Dec 06, 2004, 03:07 AM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
BTW Steve... sorry to threadjack...lol
Great-looking plane!!!
Old Dec 06, 2004, 03:10 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Thanks again Steve!!!!
Do you know how many you are driving crazy these days....
I just had a look at he plans -a and it's great work as usual
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Dec 06, 2004, 03:21 AM
hummingbird111 is offline
Find More Posts by hummingbird111
what wing man??
hummingbird111's Avatar
Nashville Tennessee
Joined Jul 2003
T-38
Hey Steve,, that's a rocking plane,,... i've been looking around for something a little different than the F-16,, kinda similar too,,wow!! that's a cool plane,, i didn't know what a T-38 was till now ,,thanks !!
hummingbird111 is offline Find More Posts by hummingbird111
Old Dec 06, 2004, 05:49 AM
cyberbipe is offline
Find More Posts by cyberbipe
cyberbipe's Avatar
United States, AK, Fairbanks
Joined Sep 2003
Thanks Steve,
I have built the 2 previous jets and the fly awseome I will have to get bussy on this one next. This is such a great thing you do by giving us these plans.
Michael
cyberbipe is offline Find More Posts by cyberbipe
Old Dec 06, 2004, 05:50 AM
ravencsr is offline
Find More Posts by ravencsr
Melbourne, Eastern Sub.
Joined Sep 2004
Thanks for the plans Steve !
The missus is not too keen on you for giving me the eagle and hornet to play with.... said I was spending too much time on my planes and not enough time with her !
Now she's seen these plans !! (still haven't let on to her about the gripen )
Guess I better get my priorities right.............. now where did I put my cuttin knife ?????
ravencsr is offline Find More Posts by ravencsr
Old Dec 06, 2004, 07:49 AM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I must say Steve, you are a credit to the E-Zone and unselfish individual.
Thanks for all your contributions. Without saying, your plans are great!
J
J Morgan is offline Find More Posts by J Morgan
Old Dec 06, 2004, 08:34 AM
Spinner is offline
Find More Posts by Spinner
Yorktown, VA
Joined Oct 2000
Steve,
What John said, multiplied by hundreds for the masses!
Joe
Spinner is offline Find More Posts by Spinner
Old Dec 06, 2004, 08:35 AM
Spinner is offline
Yorktown, VA
Joined Oct 2000
Steve,
Many thanks from all of us.
Joe
Old Dec 06, 2004, 09:03 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Hint
I just thaught I'd copy this from the F18 park thread
Steve's Beer Fund
Paypal account address: jetset44@verizon.net
empeabee is offline Find More Posts by empeabee
Old Dec 06, 2004, 09:04 AM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Is it in EDF version too?
Guys like jetset make this forum so popular!
Even though I "might not" make this one, I appreciate your effort and persistance
Hats off for Jetset44!
Dave
RNAF is offline Find More Posts by RNAF
Old Dec 06, 2004, 10:44 AM
T_MECO is offline
Find More Posts by T_MECO
T_MECO's Avatar
Houston
Joined Jun 2004
Thanks Jet for the official release of this thread. I had a chance to get a head start on this project. This plane does handle similarly to the F-15. However, It requires speed! This is not going to float around like the F-18, 15 foam planes. I used a axi 2208/34 with 9x6 SF prop. Controlability became an issue at low speeds. This baby lives for speed. I have some c.g. and rebuilding issues to do prior to my next flight. Seeing how my first attemp went off with mixed results.
T_MECO is offline Find More Posts by T_MECO
Shumate/3DFoamy T-38 Talon VID JohnVH Pusher Prop Jet Models 5 Aug 18, 2005 12:04 AM
T-38 Talon Alexis_Ruiz Electric Ducted Fan Jet Talk 7 Apr 07, 2005 06:08 AM
T-38 Talon made from sturdyboard tbitz Electric Ducted Fan Jet Talk 20 Oct 18, 2004 10:51 PM
Wanted: T-38 Talon or S3-A viking ttnissan Aircraft - Electric - Airplanes (FS/W) 0 Dec 25, 2001 02:10 PM
T-38 Talon or S3-A Viking ttnissan Foamies (Kits) 0 Dec 25, 2001 02:08 PM
