Old Dec 05, 2004, 03:00 PM
want2B400Xpert is offline
Find More Posts by want2B400Xpert
Joined Jan 2003
Is the tail really that bad?
I got my new reciever/speed controller for my dragonfly (esky radio) and now Im having tail problems. It just doesn't have the power at just over hover throttle. I can't keep the tail straight when barely climbing. Does that sound like the tail motor is burining out? Its probably had maybe 20 flights now. At low main rotor throttle, the tail has all the power in the world though. Any ideas? It is the EDF-50 you guys use for tail replacements right? And which tail rotor works best?
James
want2B400Xpert is offline Find More Posts by want2B400Xpert
Old Dec 05, 2004, 04:11 PM
aerohawk1 is offline
Find More Posts by aerohawk1
micro mechanic
aerohawk1's Avatar
Oz, Kansas
Joined May 2004
sounds like its dying
you might try the esky 3d tail motor in the geared drive...it is meaty and has carbon brushes.
mine has lasted for well over 40 flights,now(50% resulting in crashes ).
they say that the direct drive gives you more authority in starboard turns,but I have yet to need more.
not to mention that a GD will have a much lower amp draw than a DD.
myself,I'm going brushless this week(if I can keep the amp draw low enough-hoping to come in under 2 amps,lol)...I think the tail is starting to lag a bit in climb.
I'm going to try a number of methods,but the one I'm favoring is motor near frame,with belt driven,reduced(5:1,maybe) drive.
I have many small,cogged belts and 3mm drive gears from old pc printers that are already perfect legnth
If I can make the motor light enough,I will just mount it at the end of the boom,but I want it to be a reduced drive to keep amps down.
aerohawk1 is offline Find More Posts by aerohawk1
Discussion Am I really that bad at this?? merlinmurph Hand Launch 25 Nov 28, 2006 10:02 PM
Discussion Are the Walkera Heli's really that bad? Lou Coaxial Helicopters 9 Oct 22, 2006 07:32 PM
Metal gear servo for elevator, r they really that bad? Magna High Performance 1 Jun 28, 2005 02:35 AM
Are KAN 3000s really that bad? Matthew Allen Batteries and Chargers 8 Sep 03, 2004 04:57 AM
Is the ECO8 really that bad?? Hooloovoo Electric Heli Talk 36 Jun 21, 2002 07:21 AM
