Old Dec 05, 2004, 10:53 AM
Air plane is offline
Find More Posts by Air plane
all can crash
Air plane's Avatar
Joined Dec 2004
Himax 2025-4200 in gws "d" box q?
Can the genII TP1350 handle this setup or do i need the 2100
Air plane is offline Find More Posts by Air plane
Old Dec 05, 2004, 11:00 AM
brianb10 is offline
Find More Posts by brianb10
brianb10's Avatar
Joined Nov 2003
Is it 2s or 3s? The 1320 should be fine either way. D gearing sounds low. With my 4200 my gear ratio is 4.5. Yours is 6.6. With 3s and 9x7.5 prop I draw 18 amps. Your batt is good for about 16 so you can get more out if it by gearing lower. If its 2s gear lot lower
brianb10 is offline Find More Posts by brianb10
Old Dec 05, 2004, 11:04 AM
all can crash
Air plane's Avatar
Joined Dec 2004
3S sorry..
Old Dec 05, 2004, 11:13 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Even using a prop as big as 11x7 you'll only pull just over 11A, so you should be fine with the 1320.
Motor: Himax HA2025-4200; 4200rpm/V; 0.75A no-load; 0.075 Ohms.
Battery: Kokam 1500; 3 cells; 1500mAh @ 3.7V; 0.027 Ohms/cell.
Speed Control: Castle Creations Phoenix 25; 0.0065 Ohms; High rate.
Drive System: DD; 11x7 (Pconst=1.17; Tconst=0.95) geared 6.6:1 (Eff=95%).
Airframe: Anything you want.
Conditions: Sea Level, 29.92inHg, 59F
AirSpd (mph) = 0.0
Batt Amps = 11.4
Motor Amps = 11.4
Motor Volts = 10.1
Input (W) = 114.9
Loss (W) = 22.0
MGbOut (W) = 92.9
MotGb Ef(%) = 80.8
Shaft Ef(%) = 73.6
Motor RPM = 38654
Prop RPM = 5857
Thrust (oz) = 23.4
PSpd (mph) = 38.8
Prop Ef(%) = 0.0
Total Ef(%) = 0.0
Time (m:s) = 7:55
Dr Kiwi is offline Find More Posts by Dr Kiwi
brianb10 is offline
brianb10's Avatar
Joined Nov 2003
According to my calc youll be drawing under 10 amps static with 10x8 prop. C gearing will give you under 16 amps static and less in the air.
For Sale Himax 2025 4200 in GWS "C" GB jhamm Aircraft - Electric - Airplanes (FS/W) 5 Oct 07, 2005 12:28 AM
F/S Himax 2025-3200 W/ GWS C box and heatsink Aobid Aircraft - Electric - Airplanes (FS/W) 0 Oct 11, 2004 03:47 PM
Question Himax 2025-4200 in GWS Gearbox orangepeel Power Systems 25 May 15, 2004 04:10 PM
Question Himax 2025-4200 in GWS Gearbox orangepeel Parkflyers 3 May 13, 2004 10:19 AM
Himax 2025 4200 w/GWS gearbox parrott 3D Flying 0 Dec 26, 2003 05:14 PM
