Old Dec 04, 2004, 09:55 PM
DsWright is offline
Find More Posts by DsWright
ProBro #1889
DsWright's Avatar
United States, OH, Amelia
Joined Aug 2004
How do you measure AMPS with a multimeter?
My CC P-10 is getting warm while testing a motor i built. I can't seem to figure out how to use my multimeter to measure amps.
Please be descriptive.
thanks
DsWright is offline Find More Posts by DsWright
Old Dec 04, 2004, 10:01 PM
Flying Weasle is offline
Find More Posts by Flying Weasle
Birmingham, Alabama, United States
Joined Jan 2004
Most of them will not do it. Only the high dollar ones will.
You need something like an Astro Whatt Meter.
Flying Weasle is offline Find More Posts by Flying Weasle
Old Dec 04, 2004, 10:03 PM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
I have a AC/DC multimeter, should be capable of up to 10 DC amps...
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
If your meter has a special hole for the red lead to check amps...put it in there...then hook up everything as normal. Then take the red lead from the batter and hook the red lead from the meter to the battery lead....and the black lead from the meter to the remaining red wire going to the controller. The best way someone described it is pretend everything is normla...then a kid (meter) breaks in the middle of the circle (red battery lead) and holds hands with the two kids (both ends of the red battery lead.
run the motr and you should read amps. If you have a buddy with the clamp on amp meter it's much easier...you don't have to cut wires.....
I made up a harness out of two connectors....and wired it so one end goes to my battery...the other end goes to the controller.....and I just left the red side so I could insert my meter...and taped the plack side together..
hope that helps....
mjdee14 is offline Find More Posts by mjdee14
Old Dec 04, 2004, 10:23 PM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
You can use a shunt resistor to measure current using a common voltmeter.
As Ohm's law states:
I = V/R
Where:
I = Current
V = Voltage
R = Resistance
To implement the formula, simply put a low-value resistor in series with the power or ground connection to the ESC, then measure the voltage difference between each lead of the resistor. The difference can be plugged into the formula to yield a current.
For example, a .05 ohm shunt resistor reads "0.17V" across the two terminals. We simply replace the variables with our known values and solve the equation
1: I = 0.17/.05
2: I = 3.4A
When using this though, take care that the shunt resistor is of the lowest possible value to minimize voltage losses, and by minimizing voltage losses, you are also minimizing power dissipation, as:
W = VI
Therefore:
W = I x I x R
Using this formula we can calculate power dissipation of the given resistor. Suppose the conditions of the above example, 3.4A and 0.05 ohms.
1: W = 3.4 x 3.4 x 0.05
2: W = .578W
Keep in mind that the resistor power rating of your shunt must be a higher number than your calculated dissipation at max continuous current draw you plan to measure.
Hope this helps, it will allow you to easily measure current using just a DC voltmeter.
-Matt
zagisrule! is offline Find More Posts by zagisrule!
Old Dec 04, 2004, 11:52 PM
Ron H is offline
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
If you are using Deans Ultras you can flip one plug over and plug in the negatives leaving the positives open. Now plug one probe into the pack's + lead and push the other in between the exposed rx + lead and the connector. They stay put like this and it frees up both hands.
Ron H is offline Find More Posts by Ron H
Old Dec 05, 2004, 06:55 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
thanks
If you put the VOM (meter) in line then you will be adding wire and resistence and results may not be accurate. The shunt with meter works very well
Post # 7 here:
http://www.rcgroups.com/forums/showthread.php?t=297491
The resistence of 12" of #10 solid copper wire is .001 ohms.
Charles
Discussion How do you measure motor Amps missle Beginner Training Area (Aircraft-Electric) 10 Dec 30, 2006 07:43 PM
Question How do you measure direct current with a CRO? yakman DIY Electronics 5 Jun 11, 2006 05:23 AM
How do you make decals with a computer? Andy W Scale Kit/Scratch Built 50 May 24, 2003 09:12 PM
How do you measure Static Amps? Within 5 seconds of a fresh charge or? rparigoris Power Systems 3 Mar 20, 2003 10:30 AM
How do you measure motor contstants? Aero-BearAZ Power Systems 4 Jul 19, 2001 11:33 AM
