Old Dec 03, 2004, 02:43 AM
Lift Crazy* is offline
Find More Posts by Lift Crazy*
aka Lee
Joined Jun 2003
Gulfstream II (Scratch build photo essay)
This slope forum and all the amazing PSS planes being shown here inspired me to try my own scratch build.
I went through 3-view after 3-view... nothing stood out.
When i saw racingodds G5 i knew that i should try to build an executive jet.
So i searched for some decent 3-views and played around with some ideas.
I decided to start out with foam as it was cheap and relatively easy to shape.
Here in South Africa we don't get a whole lot of EPP floating around... and if you could find some it would probably set you back quite a bit.
Well i'm not much of a waffler so i'm gonna let the pics do the talking.
Here are some specs:
Airfoil: RG-15 (12.652" Root 8.952% thickness)
Length: 1260 mm or 49.606 inches
Span: 1200 mm or 47.244 inches
Weight w/o covering: 1150 grams or 40.565 ounces
Wing cores are made per TFLG's "worlds cheapest foam cutter" method and are sheeted with 2mm balsa.
The leading edge is balsa.
Main construction material is EPS.
As an experiment i used silicon to glue the eps sheets together, it works very well but when sanding you will have to trim the excess. (Watch your fingers with that razor blade)
If there are any questions i will hazard an answer... i am by no means a guru when it comes to scratch building. This is my very first attempt.
Enjoy...
Lift Crazy* is offline Find More Posts by Lift Crazy*
Old Dec 03, 2004, 02:47 AM
aka Lee
Joined Jun 2003
Gulfstream fuse in compact form
Was going to use the windrider bee as my wing but then decided against it.
Old Dec 03, 2004, 02:48 AM
aka Lee
Joined Jun 2003
Old Dec 03, 2004, 02:54 AM
aka Lee
Joined Jun 2003
Old Dec 03, 2004, 02:55 AM
aka Lee
Joined Jun 2003
Old Dec 03, 2004, 02:56 AM
aka Lee
Joined Jun 2003
Old Dec 03, 2004, 02:57 AM
aka Lee
Joined Jun 2003
Old Dec 03, 2004, 03:00 AM
aka Lee
Joined Jun 2003
The Gulfstream II's current state
Any progress will be posted here when i have taken pics.
Lee
Old Dec 03, 2004, 03:20 AM
Ado is offline
Ado
Find More Posts by Ado
Ado
Meow?
Ado's Avatar
Brisbane Intl, Australia
Joined Sep 2001
wow... lookin good!
nice work.
Cheers,
Ado
Ado is offline Find More Posts by Ado
Old Dec 03, 2004, 04:36 AM
Alfred is offline
Find More Posts by Alfred
Alfred's Avatar
Perth
Joined Apr 2002
Great job on the G! Can't wait to see a vid of it flying.
Lots of boat rods!
Alfred is offline Find More Posts by Alfred
Old Dec 03, 2004, 08:00 AM
vnylwrks is offline
Find More Posts by vnylwrks
vnylwrks's Avatar
Mission Viejo, California, United States
Joined Jan 2004
Great job on the gulfstream. It sure looks good.
Where can I get one of those black baseball caps with the pilot on it (its in the picture showing your plane on your dining room table)? Did you get it locally or did you order it from somewhere online? How much did it cost?
Mitch
vnylwrks is offline Find More Posts by vnylwrks
Old Dec 03, 2004, 08:06 AM
aka Lee
Joined Jun 2003
Thanks for all the comments guys!
Mitch the cap is our club cap... the guy on the cap is the Atlantic Flying Club's logo.
Later...
Lee
Old Dec 03, 2004, 08:18 AM
nwoods is offline
Find More Posts by nwoods
Retired Slope Racer
nwoods's Avatar
SoCal
Joined May 2003
That looks great! I love those side strakes that hold on the jet nacelles. and that linkage at the back looks cool. Must have taken quite a bit of thought!
nwoods is offline Find More Posts by nwoods
Old Dec 03, 2004, 09:20 AM
ericm is offline
Find More Posts by ericm
Vancouver WA
Joined May 2004
Neat! Way to go, taking on the project and going for it. Love seeing that...
ericm
ericm is offline Find More Posts by ericm
Old Dec 03, 2004, 10:47 AM
oscarmeyer is offline
Find More Posts by oscarmeyer
Drive anywhere to fly.
oscarmeyer's Avatar
United States, CA, Irvine
Joined Aug 2004
Nice looking plane. Can't wait to see it in full color.
oscarmeyer is offline Find More Posts by oscarmeyer
Build Log SR-71 Mk.II Scratch Build...again Willmsy Electric Ducted Fan Jet Talk 685 Jan 24, 2013 09:28 AM
AP Avenger - Scratch build Photo platform Joe Bennett Parkflyers 32 Apr 07, 2004 11:12 PM
AP Avenger - Scratch build Photo Platform Joe Bennett Aerial Photography 0 Feb 01, 2004 05:47 PM
TACO II Scratch Build Acer Parkflyers 43 Jun 04, 2003 08:01 AM
Firebird II Speed Wing for 1st Semi-Scratch Build? Dave Hederich Power Systems 16 May 21, 2002 09:50 AM
