Old Dec 02, 2004, 11:38 PM
jbj620's Avatar
United States, AL, Fort Payne
Design a Plane With EPP AND Depron ! What would be your favorite...
Hello, This is a question I have been asking myself lately. I like the way a Depron plane flys, but as we know it is not as durable as a EPP plane. IMHO EPP planes will not stay in trim at times, and some do not fly as well as Depron planes... But what about MORE combinations of both ? It is like most models are built out of one or the other. If you could design a plane with EPP and Depron how would it turn out ? Would it be like a Zoom Zoom all EPP except for the tail feathers or maybe a Shockflyer with a true airfoil EPP wing, Depron ailerons and tailfeathers, get the idea... If you could combine EPP and Depron in any combination into a design what would be your favorite?
jbj620 is offline Find More Posts by jbj620
Old Dec 03, 2004, 12:06 AM
los angeles
Joined Mar 2004
the epp is lighter... 6mm blade cut 1.3# density epp is lighter than 3mm dupron. i think either can warp in a hot car but epp is more flexi to begin with. i've built the r3d, the mini r3d, zoom zoom and just recently started building the flat dupron planes like the shocky edge and mini 3dx. just now i downloaded the plans for the mini voltex by derekb and it's a built up wing and sorta built up fuse done in 2 and 3mm dupron that suppose to come in at under 6oz with a ips setup and 3s 340's and with a 28" wingspan to boot. i don't see how he did it but i'll have to try for myself as my shocky edge is coming in a 6oz and i'm using as light or lighter electronics
skyhiflyhigh is offline Find More Posts by skyhiflyhigh
Old Dec 03, 2004, 12:16 AM
Huntington Beach, California, United States
Joined Oct 2001
Check out the review of the EPP Straight Edge:
http://www.rcgroups.com/links/index.php?id=4565
Chris has worked hard on this plane for two years before it came to market this Feb.
Tom
www.WingWarrior.com
wingmaster is offline Find More Posts by wingmaster
Old Dec 03, 2004, 12:19 AM
jbj620's Avatar
The idea is if you could combine the ability to shape EPP, combined with the rigidity of Depron... in the right places... how many more great flying yet durable planes could we have.
Old Dec 03, 2004, 12:37 AM
jbj620's Avatar
Tom
www.WingWarrior.com
Tom, This is a cool plane ! Great job Chris !
Old Dec 03, 2004, 12:38 AM
los angeles
Joined Mar 2004
i don't think u can mold epp with different densities all in the same part. u could make it thicker in some areas though. didn't ming have a molded epp plane being beta tested?
Old Dec 03, 2004, 02:40 AM
Got more toys than my kid
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
3mm EPP skin wrapped around 2mm depron ribs with a carbon-tape reinforced 6mm depron spar.
6mm EPP fuselage sides with 3mm depron keels (to prevent tail wag). 3mm Depron control surfaces, horizontal and vertical stabilizer.
That should be a reasonable compromise of durability and rigidity.
macr0t0r is offline Find More Posts by macr0t0r
Old Dec 03, 2004, 09:24 AM
3d_Crazy's Avatar
Fort Worth, TX
Joined Nov 2003
I used depron control surfaces with one of my Revolution 3D's... it gives you the crisp responce and since the rest of the plane is made from EPP it is still durable.... People have been doing this with other EPP planes for a while now.
3d_Crazy is offline Find More Posts by 3d_Crazy
Old Dec 03, 2004, 01:50 PM
Airdrie, AB Canada
Joined Sep 2004
I just finished an EPP Tensor. With Depron control surfaces. Perfect combination IMHO.
Rigid and crisp flight. EPP bouncibility. Usually the EPP gives more than enough to save the controls.
mjws is offline Find More Posts by mjws
Old Dec 04, 2004, 01:57 PM
jbj620's Avatar
Thanks for the replies guys ! I thought this would be a interesting new subject but looking at the response I guess most people are not interested in the idea...
Old Dec 05, 2004, 07:06 AM
Fayetteville NC
Joined Nov 2003
I don't think its lack of interest. It's that there are many planes like this out there already. I personally love the combination of an epp fuse and wing with depron control surfaces. I was never able to get my SX2 and other funplanes type all epp planes to fly like I wanted. However once the epp control surfaces are replaced with stiffer depron it's a different world.
I'm flying a Zoom Zoom right now which I love (the ailerons are actually epp but they are thick and very stiff). I'm probably going to pick up one of the wing warrior edges if the reviews are as good as I think they'll be.
Dave
dmsick is offline Find More Posts by dmsick
Poll What would be your choice for a 500 size heli? brovic777 Mini Helis 106 Oct 25, 2007 03:02 PM
Question What would be your perfect Trex setup? briherpman Mini Helis 10 May 13, 2007 11:58 PM
What would be your perfect heli? EP heli freak! Electric Heli Talk 70 Dec 17, 2005 10:12 AM
what would be the best nicd battery combonation to use in a spirit with a power pod? drrhythm Electric Sailplanes 5 Jul 05, 2003 02:14 PM
What have YOU built with 5mm Depron? Matthew Allen Foamies (Kits) 31 Jul 17, 2002 10:24 AM
