Old Dec 05, 2004, 06:30 PM
a1pcfixer is offline
Find More Posts by a1pcfixer
Counter agent of B.S.
United States, IN
Joined Aug 2003
Originally Posted by LexTalionis
Lex
Lex, what did you use for reinforcement around the motor mounts?
Both sides/top & bottom?
Jim
a1pcfixer is offline Find More Posts by a1pcfixer
Old Dec 05, 2004, 06:49 PM
Spencer J is offline
Find More Posts by Spencer J
USA
Joined Jun 2002
Chuck, here's how far I went with my Stryker
-Park Zone F-27 Stryker (not the RTF version ;-)
-Mega 16-25-4
-Graupner 7X7
-PolyQuest 4S-2600mAh
-CC Phx-35, BEC disabled
-KoolFlight Systems UBEC
-AUW w/battery 27oz! Yep that's right!
Static WOT: 20.89A and 245 Watts (freshly charged battery)...~53oz of thrust
MAIDEN FLIGHT VIDEO...3.7MB 320x200 24FPS
Muchos Gracias to Moter of the E-Zone for launching her and taking the video. This is gonna be a very fun model to chase slower electrics around
Lex
Sluckern-Sluchatash!!!!!!!!!!!!!!!! That's the best paint job I've seen on ANY parkflyer!!!!!!!!!!!!!!!!!!!!!!!
I'm e-mailing that to Parkzone. Do you mind???
Spencer J is offline Find More Posts by Spencer J
Old Dec 05, 2004, 06:59 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Originally Posted by ChuckD
Has anyone had to create fin supports? If so...what did you use?
--C
Chuck:
Not on this plane, but I have had to reinforce others. The best thing I have found is 0.007 x 0.250 carbon fiber tape. The fan folded foam guys use it a lot. You use foam safe CA or very thin epoxy and glue it down to either side of what you want to reinforce, like balsa elevons or a fuse.
I have put it on the bottom of wings, on the inside of both sides of a GWS foam fuse, and on the top and bottom of ailerons. The FFF guys cut the 1/4" foam in two, glue the tape to the surface of the cut, and then glue the other piece to the other side of the tape. It makes FFF wings stiff without using a spar. You can also sister the tape to the sides of a 1/4" square balsa stick, like a GWS motor stick, to make it almost unbreakable.
This stuff is much lighter than small diameter CF rods and the part ends up much stiffer. CF just does NOT stretch, so the result is a sandwich that is incredibly rigid since one side or the other of the part tries to stretch and can't. All this at the cost of very little extra weight.
And before you ask.... don' buy it at your LHS, they charge about $10 for 3 feet. There is a guy on here on the Zone that sells 50 ft for $20. See http://www.rcgroups.com/forums/showt...hreadid=182442
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Dec 05, 2004, 07:14 PM
rc_ron is offline
Find More Posts by rc_ron
shawnee, ks
Joined Apr 2004
lex,
that is an AWESOME PLANE!!!
rc_ron is offline Find More Posts by rc_ron
Old Dec 05, 2004, 07:22 PM
ChuckD is offline
Find More Posts by ChuckD
Cancelled Account
AWESOME FOAM! Again...great!
--C
ChuckD is offline Find More Posts by ChuckD
Old Dec 05, 2004, 08:14 PM
LexTalionis is offline
Find More Posts by LexTalionis
Bubble Head SSN 762
LexTalionis's Avatar
Austin Bergstrom, Texas, United States
Joined Apr 2004
No go right ahead, I don't mind
Some questions asked...why 16-25-4 and not 16-25-3...well, because that's all I had. I know the 7X7 Graupner Speed Prop is the right prop. I used the thinest bass-wood ply sold at the LHS for the top and bottom motor mount support...epoxied in place with pinch clamps and then glassed over.
Thanks for the comments guys. I guess I'm lucky my vert stabs didn't fold on it's maiden...gonna do something to stiffen them up.
Lex
LexTalionis is offline Find More Posts by LexTalionis
Old Dec 06, 2004, 12:35 AM
Flappy is offline
Find More Posts by Flappy
just wing it
Flappy's Avatar
Foresthill, California
Joined Jul 2004
FoamCrusher,
I'm curious. Did you try it with the APCe 6x4? I think when spinning high RPM's those thin electric props are the way to go. They're uh. . . thin. So they have very little displacement at the tips where it's moving the fastest. So you're not wasting tons of energy disturbing the air with a thicker airfoil. Plus, it's a step down from the 6.3
Flew with the Mega 16/15/5 on 4S1P 2100 and a 6.3 x.4 prop . . . The cells come out hot. . .
Flappy is offline Find More Posts by Flappy
Old Dec 06, 2004, 12:44 AM
STaNgXs is offline
Find More Posts by STaNgXs
Huntington Beach, CA
Joined Sep 2004
'why on earth are you blowing hundreds on a 160 dollar plane to modify it with big engines and lipolys when you can just buy a really good plane to begin with?'
I..'what a waste; starving people in the world and here you are spending all this money'...
haha, that guy sounds like a complete idiot.
there's no limit in this world, go as far as you can possibly
STaNgXs is offline Find More Posts by STaNgXs
Old Dec 07, 2004, 04:29 AM
fastback67 is offline
Find More Posts by fastback67
Nampa, Idaho
Joined Nov 2004
Very sharp looking plane Lex, nice job. I got the F27 about 3 months ago as my first plane and I am in the process of gutting the stock electronics. What servos, ecs, and Rx are you guys using? Any suggestions would be appreciated. Thanks.
Mike.
fastback67 is offline Find More Posts by fastback67
Old Dec 07, 2004, 10:14 AM
Bubble Head SSN 762
Joined Apr 2004
Mike,
I'm using HS-60 SuperMicro Servos and the fit like a glove into the stock Stryker wing. I bought mine a ServoCity.com. I'm using a Berg 4 MicroStamp RX, CC Phx-25 ESC, and KoolFlight Systems U-BEC.
Lex
Old Dec 10, 2004, 08:46 AM
ChuckD is offline
Cancelled Account
Wattage Cap into 16/15/4?
Hey All,
From past posts, you have seen that my setup houses a Mega 16/15/4....
What is the maximum amount of wattage the motor can take?
I plan on getting a custom 1.7:1 Gearbox and putting 4s TP 2100's in there...
Will the wattage cook anything? It will only pull 25amps at W.O.T. (which will be used sparingly with 50.6oz of thrust....
But will it cook the motor with Watts? Is that even possible to cook something with watts?
--C
Old Dec 10, 2004, 12:36 PM
Vonbaron is offline
Find More Posts by Vonbaron
Plane hugging cat
Vonbaron's Avatar
Mackay Queensland Australia
Joined Sep 2001
Originally Posted by brianb10
Heres overpowered:
My pico stick FD with a Himax 2025 on 3 cells(didnt last long)
Hahahahaha! That is so funny cos I did the same thing! Glad to see I'm not the only one.
Sorry, back to the Stryker. I also have a stryker but just with the stock 480. Lots of fun that thing. But I have severe orientation problems with it. Half the time I don't know which way is up.
Vonbaron is offline Find More Posts by Vonbaron
Old Dec 10, 2004, 03:13 PM
United States, IN
Joined Aug 2003
Hey All,
--C
From their web site it shows 16 cells MAX (16 x 1.2v), and 25 amps MAX
http://web.telecom.cz/megamotor/Elek...electromotors_
Jim
Old Dec 10, 2004, 03:37 PM
Flappy is offline
just wing it
Flappy's Avatar
Joined Jul 2004
480 watts. ah. . hooooooey!
On 12 cells that's 32 amps. Which is why many unicorn fliers are going 12 cells w/ 6x4. It comes out right at 32 amps!
Old Dec 10, 2004, 06:24 PM
ChuckD is offline
Cancelled Account
So that is how much it can take? 480 watts? Is that correct (sorry for the 'needing to have it beaten across my forehead' approach)...but I am still new to all of this.
My best,
--C
Gallery F-27 Stryker How Far Can You Take It? Part 4 FoamCrusher Parkflyers 4512 Mar 23, 2011 07:40 PM
F-27 Stryker How Far Can You Take It? Part 3 Fred Bronk Parkflyers 560 Jul 03, 2005 01:04 AM
F-27 Stryker How Far Can You Take It? Part 2 Michael Heer Parkflyers 861 Apr 10, 2005 10:02 PM
Corona: How far can you build, Kit only NewRotorSoon Electric Heli Talk 4 Mar 03, 2003 10:55 PM
Slow Stick on Kokams.... or how long can you take it? Tres Wright Parkflyers 20 Jan 21, 2003 09:20 AM
