Old Apr 12, 2007, 09:31 AM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
Peter,
Unfortunetly, No, I don't have any CAD software that can handle ether of those formats. Thank you for checking though. I need to get some real cad software ;-)
Dave.
creapyd is offline Find More Posts by creapyd
Old Apr 12, 2007, 10:19 AM
creapyd is offline
Prefectionist
Joined Mar 2007
Mini SE5A
Originally Posted by pmjass
Ha Ha,
I can laugh. I've had a couple do the twist in my hand. They wrap up tight very quickly.
Tell me more about the motor. Star/Delta? Wire gauge? Static Amps?
It sounds like a good set up. I've wound three motors so far although they have all been the Aircraft-World type motors. If haven't tried a GB motor yet.
Do you think there would be much interest in a mini SE5A. I have the plans for
the outdoor version and it wouldn't take much to scale it down for 3mm depron. I like multiwings when using 3mm Depron as the wingspans are shorter and the struts provide bracing consequently it is a lot easier to get a stiffer structure.
Peter
Peter,
Did you ever produce the indoor plans for the SE5A? I would love to be able do dogfight in a gym with snoopy and the red barron.
Old May 25, 2008, 03:24 PM
nigelsheffield is offline
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
epp baron
i have just finished baby baron in 5mm epp, used carbon strip in the wings and wider wing joiners otherwize as per plans, not flown yet waiting for calm weather, has any one else done this if so how did it go? using 450mah 2 cell lipo and 80w brushless motor. handles great on the living room floor.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Sep 05, 2008, 08:54 AM
NielsR is offline
Find More Posts by NielsR
Belgium, Flemish Region, Mechelen
Joined Aug 2007
I'm planning on making this little wonder... Would a 24gr 1300KV would do the trick? Or should I put it in a gearbox to reduce the KV?
Cheers,
Niels R.
NielsR is offline Find More Posts by NielsR
Old Sep 30, 2008, 03:00 PM
brantley is offline
Find More Posts by brantley
brantley's Avatar
Exmouth, Devon, UK
Joined Dec 2004
For anyone thinking of building this great little aircraft, I have been given permission from kzey at Digital Millworks (who used to produce the kit) to post a copy of their excellent build manual.
Enjoy.
brantley is offline Find More Posts by brantley
Old Jan 25, 2009, 08:12 AM
mormathi is offline
Find More Posts by mormathi
Haugesund, Norway
Joined Apr 2007
I have built the baby baron the result is great, and only one question remains:Where is the center of gravity? I would be very greatful if anyone could help me whith this.
Morten Mathisen
Norway
mormathi is offline Find More Posts by mormathi
Old Jan 25, 2009, 08:30 AM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
Page 3 of pdf manual file in post # 200 right above yours:
3/15/05 ver 0.9 to version 1.0
o Added brushed motor information to specs
o Changed recommended starting C.G. to 1 1/8th inch back on middle wing
o Added note to apply packing tape to aileron surfaces to reduce flex for outdoor flight.
Pete Miller is offline Find More Posts by Pete Miller
Old Feb 19, 2009, 04:35 AM
pmjass is offline
Find More Posts by pmjass
Team FlightPower AUS
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Morten,
any pics, have you flown it yet?
Peter
pmjass is offline Find More Posts by pmjass
Old Feb 21, 2009, 08:10 AM
mormathi is offline
Haugesund, Norway
Joined Apr 2007
Pictures of th baby baron
I've now built the baby baron, and I thought someone may be interested in some pics.
It flies great. I'm now building the big one for outdoor, an I'm looking forward to the spring, and the withdrawal of the cold Norwegian winter.
Morten Mathisen
Norway
I have taken a great interest in WWW1 planes, if someone has drawings I would be most grateful if you could post them to me:
mormathi@online.no
Old Feb 22, 2009, 04:55 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Looks good Morten.
I see you added a flying axle.
Old Apr 18, 2010, 09:59 AM
AhLian is offline
Find More Posts by AhLian
Joined Dec 2008
i have just started on this plan, and im stuck at the undercarriage construction part. can some1 enlighten me how to construct? wad size rods/accessories/joints do i have to get?
AhLian is offline Find More Posts by AhLian
Old Oct 13, 2010, 01:10 PM
idigbo is offline
Find More Posts by idigbo
Joined Dec 2004
Thought I'd revive this thread and show a couple of pics of mine. Basically standard and hand painted in artists acrylics. I test flew it at the UK Nationals where it was middaired on the Sat evening Out with the UHU POR and some cyano and it was going again the following evening. It still shows some signs of battle, since the fuselage was in two, as were the wings all the struts and tailplane!!!
An ace design, many thanks for sharing.
Ian.
nats 2010.mp4 (1 min 33 sec)
idigbo is offline Find More Posts by idigbo
Old Oct 13, 2010, 01:16 PM
idigbo is offline
Joined Dec 2004
.....and a couple of flying pics. I could've edited my balding pate but I aint that vain. Apologies to all it offends
Ian.
Old Oct 13, 2010, 03:58 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Wow,
great job with the build. Your model looks fantastic. I quickly looked at the pictures and thought that's not my version. It has a full fuz, closer inspection revelaed the T section.
Of late I have been considering reviving my foamy WWI foamies design activities your post may just have provided enough spark to get me going again. I have some camel plans almost finished and I was thinking of re-doing the DR-1 with a central crutch. From some aspects the T looks great from other angles it looks a little ugly.
Thanks for posting.
Regards,
Peter
Old Mar 12, 2012, 09:26 AM
Shawndae is online now
Find More Posts by Shawndae
Building until we fly w\ Jesus
Shawndae's Avatar
United States, CA, Moreno Valley
Joined May 2011
Well I tried my hand at my first foam build. Made one of each size. I must so that after building many wood and ARF kits I am now also hooked on building with foam sheet.
Here is a shot of my new toys that I just flew over the weekend.
Shawndae is online now Find More Posts by Shawndae
Red Baron 3D vs. Flying Corps Looooeeee! Life, The Universe, and Politics 8 Jul 17, 2004 12:57 AM
Has anyone managed to get the Red Baron Reno Racer to fly? PETERRAKE Scale Kit/Scratch Built 6 May 22, 2002 03:07 PM
Mustang Reno Racer "Red Baron" Troy High Performance 5 Mar 28, 2002 01:05 PM
Red Baron Wannabe RCFlybry Parkflyers 12 Nov 09, 2001 12:20 AM
Red Baron - 3D Hans Electric Plane Talk 1 Jul 22, 2001 01:37 AM
