Dec 01, 2004, 01:20 AM
Here
Joined May 2003
Absalut Build Thread (Q&A)
Hey guys,
There's a few threads on the Absalut DLG. It's getting Scattered. I want to start this thread for anything that has to do with the Absalut DLG.
To start with, I should be getting mine in soon whenever I-Care sends mine out. I keep checking my Credit Card and it has not been charged. I ordered Yesterday EARLY morning and Icare guys emailed me back answering a few questions. But they did not say anything about shipping. They do USPS Priority. If they woulda send it out today "Tuesday" I would recieve it around Friday. So if they ship it out tomorrow Hopefully it will come in Saturday so I can start on the build.
I have on order, Hitec Electron 6 RX because I currently own one, and basically specked out my Art Hobby Timon 2m with this receiver. So I trust this RX in my Absalut. I also ordered 4 HS-56HB. They're 12mm or .45" inch Thick. They weigh 10grams. I heard the centering is excellent and the gears are karbonite. Also they are Ball Bearing drivin too. Should be smooth. The casing has a side mounting bracket built in but I doubt I'll use it.
In my Art Hobby Timon's servos are servo tape mounted and a layer of clear tape over that, then the skin that was cut out reattatched with tape over the servo. It holds on super tight and nice. I've done plenty of highspeed passes and no sign of flutter. I will try this method on the Absalut. If it does not work, then I will epoxy the servos in the wing with heatshrink.
For a battery pack, I ordered 4 400mah NiMh 2/3AAA cells. Lighter than 4 700mah NiMh AAA cells that I also ordered too. I will put both packs together and see which one works best in the nose.
Don't know if it's neccessary for a switch jack. I can do the old fashion plug and unplug from the RX way as I do with most of my slopers.
Any Inputs would be great.
-Tomi
