Old Nov 29, 2004, 10:58 PM
mikekosatka is offline
Find More Posts by mikekosatka
Houston Intercont, Texas, United States
Joined Nov 2002
airplane engine vs. helicopter
Is there any real difference between a helicopter engine and the same size motor used in a r/c airplane?
mikekosatka is offline Find More Posts by mikekosatka
Old Nov 30, 2004, 01:24 AM
Flying Weasle is offline
Find More Posts by Flying Weasle
Birmingham, Alabama, United States
Joined Jan 2004
The size of the head.
You SHOULD NOT use a plane engine on a heli (overheating problems) but, you can use a heli engine on a plane if it's inside a cowling. If it's out in the open with the prop wash it really won't heat up to proper operating temps. But, it can be done.
Flying Weasle is offline Find More Posts by Flying Weasle
Old Nov 30, 2004, 02:51 AM
russern is offline
Find More Posts by russern
Heli pilot
russern's Avatar
Royse, Norway
Joined May 2004
the heli engine also has more power, and torque. it is accually more like a rc car engine, than a rc plane engine, but the torque is higher
russern is offline Find More Posts by russern
Old Nov 30, 2004, 12:36 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
Most heli engines are ringed engines as well. Not many ringed plane engines left anymore.
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Nov 30, 2004, 10:12 PM
rcsoar4fun is offline
Find More Posts by rcsoar4fun
United States, ID, Star
Joined May 2003
The carbs are also different. A heli engine spends a lot more time at 75% throttle than an airplane engine. If I had to bet I would guess the timing is a bit different as well.
Kristopher
rcsoar4fun is offline Find More Posts by rcsoar4fun
Old Dec 02, 2008, 05:07 AM
UNGAB is offline
Find More Posts by UNGAB
Joined Dec 2008
PLEASE I NEED TO KNOW THE variation IN THEIR COMPONENTS ie the structural difference and the
UNGAB is offline Find More Posts by UNGAB
Old Dec 02, 2008, 05:14 AM
UNGAB is offline
Joined Dec 2008
pls does anyone know the difference between the engine components of airplane helicopters and automobiles?
Old Dec 02, 2008, 07:48 AM
barracudahockey is offline
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
The helicopter engine has a bigger heat sink, usually a carb optimized for mid range, and most importantly, a shorter crank shaft.
barracudahockey is offline Find More Posts by barracudahockey
Old Dec 02, 2008, 01:19 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
And they tend to run at higher RPM. So timing is different. Heli engines run in the 17,000 RPM range.
Pinecone is offline Find More Posts by Pinecone
Old Dec 07, 2008, 01:18 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
oil + its lubrication is different.
DarkHeli is offline Find More Posts by DarkHeli
Old Dec 08, 2008, 04:28 AM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
The extra oil used is due to the generally higher power settings used in helis.
But Cool Power 15% Aircraft and Heli are the same fuel, same oil content.
Old Dec 10, 2008, 06:53 AM
GunnyGlow is offline
Find More Posts by GunnyGlow
piro-maniac........
GunnyGlow's Avatar
United States, CO, Aurora
Joined Dec 2007
But do they taste the same??!!
GunnyGlow is offline Find More Posts by GunnyGlow
Old Dec 10, 2008, 12:39 PM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
Yeap.
Old Dec 14, 2008, 03:37 PM
Joined Sep 2004
The extra oil is due to the fact they are at the mercy of the efficency of the cooling shroud and fan and not hanging out in the airstream being cooled by prop wash for the most part. Most heli engine manufacturers reccomend 18 percent oil.
Old Feb 02, 2009, 04:06 AM
IM_Oblivion is offline
Find More Posts by IM_Oblivion
Joined Feb 2009
SO, on a scale of 1-10. with one being snap-in-and-go, and ten being impossible. How hard would it be to take a "Traxxis TRX .15 pro" engine, and put it in a similarly sized heli. Also consider we may have stuff like a CNC machine, expensive measuring tools, and engineering experience. And we were not afraid to mod the aircraft and/or engine.
I only ask because I have this engine (as you might have guessed) and I am considering getting a heli if the price is right. And being able to do this "conversion" could save me lots of cash. But it may be more expensive to do then just buying an engine.
Here is the engine
http://www.traxxas.com/products/nitr...x_trx15pro.htm
IM_Oblivion is offline Find More Posts by IM_Oblivion
new saito 150 four stroke airplane engine for sale tattooman Aircraft - Fuel - Airplanes (FS/W) 1 Aug 29, 2004 05:35 AM
fuel usage : miniature jet engine vs real one tech.knockout Fuel Jet Talk 5 Jul 14, 2004 01:08 AM
