Old Nov 29, 2004, 09:52 PM
grindel is offline
Find More Posts by grindel
Joined Nov 2004
weight shift micro helicopter
I have been out of RC for a while and am just getting back into it.
I am intrigued by the use of the zip zap motors. I wouldn't have estimated them to be powerful enough to base any sort of rc plane on, no mater how small the rc system was...
ok, so here is the idea, I don't know if it feasible or not, but does anyone remember the weight shift helicopter plans that were sold in the back of old Popular Science magazines (maybe they are still there but I haven't read PS in years.) The basic layout was like a helicopter but with rotation of the blades powered by propeller engines that spin with he blades
propeller engine/motor
..............blade | blade
.... ========0=========
................propeller engine/motor
top view
It presumably doesn't need a tail rotor since the only torque on the main body is the drag of the bearings any spin could be countered with a rudder and a little forward velocity
Thought would have to be given to the propeller design and to the distance of the engine from the axle. also power would have to be transferred through the stationary axle to the spinning motors (possibly by using motor brushes?)
control: I have no idea how far to put the bulk of the weight below the blades. control might be accomplished by shifting the battery pack and receiver with the rare earth magnet actuators...maybe. One could also use an ESC for the motors but throttle response would be very slow. I am not sure if one could make a collective control light enough though. Electronic wing warping maybe? blades framed by carbon fiber and skinned with balloon rubber so that the wing warping can occur mechanically?
I might be able to do some work on propeller and rotor optimization if someone understands my gibberish and thinks the idea has merit. I don't think I can afford right now to do a full fledge project though. Also, the props could be placed in the rotors themselves instead of on separate structure might be beneficial. anyway...thoughts?
I'll try to draw something up to make it clearer.
grindel is offline Find More Posts by grindel
Old Nov 30, 2004, 07:40 AM
glxy is offline
Find More Posts by glxy
4-D traveller
glxy's Avatar
New Location
Joined Dec 2003
The Hoverfly is an implementation of such an idea which I think is inferior to the conventional heli design.
glxy is offline Find More Posts by glxy
Old Nov 30, 2004, 12:02 PM
grindel is offline
Joined Nov 2004
the hoverfly doesn't appear to have blades and is just using rotation for stability. I intend to have the motors horizontal and use them to spin the blades to create lift. It might be a good idea (cheaper for now) to create a teathed model and simulate the weight of electronics. Thanks for the idea.
I can't envision this power system to be more efficient by any means than a direct drive system, but that doesn't mean that it couldn't be a better solution (read: lighter, easier to build) for a 6" wingspan helicopter using pager motors as propulsion.
heck, it even might be able to fly as well as spin around and look goofy.
Old Nov 30, 2004, 12:36 PM
glxy is offline
4-D traveller
glxy's Avatar
New Location
Joined Dec 2003
Originally Posted by grindel
... I intend to have the motors horizontal and use them to spin the blades to create lift.
Interesting, only problem is it can be hard to get enough head speed, or the motor prop tips have to go supersonic?
Not necessarily less efficient if the blades are long and huge. But you need hub brushes to supply power for the motors, increasing tear and wear. All in all, this configuration has many more moving parts than a conventional design.
Old Nov 30, 2004, 01:05 PM
HoverBovver is offline
Find More Posts by HoverBovver
Scarecow
HoverBovver's Avatar
UK
Joined Sep 2004
what you need is tiny tip-jets like this full sized version.
HoverBovver is offline Find More Posts by HoverBovver
Old Nov 30, 2004, 01:08 PM
Scarecow
UK
Joined Sep 2004
they are developing nano jet turbines that could be used to replace batteries in the future.....this would be ideal although a few years away.
found a link...
http://www.newscientist.com/news/news.jsp?id=ns99996559
Old Nov 30, 2004, 08:22 PM
grindel is offline
Joined Nov 2004
I don't see how this has "many" more moving parts than a standard helicopter...really, the hub brush design doesn't seem to be a show stopper to me...power could be even transfered through a set of ball bearings using no brushes. The battery could also be located at the hub and spin with the blades...although this would require the reciever to have its own battery.
anyway, enough conjecture
Ok...other informed oppinions? any guess about feasibility? How about blade design? where can I get good pager motors?
Old Nov 30, 2004, 08:50 PM
Geoffrey109 is offline
Find More Posts by Geoffrey109
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
Well, let me pipe in.........this project is really a multi-rotor design.......in the wrong thread......for sure.....but if you want the best of the best.......motors and electronics for micro controls.......start here: www.homefly.com.
G109
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Nov 30, 2004, 09:21 PM
grindel is offline
Joined Nov 2004
meh...ok...whatever
anyway, thanks for the opinions.
good link, too pricey for me for something that might not work very well
Idea A carrying case for micro helicopter ben hui Micro Helis 18 Jul 22, 2007 12:07 AM
F/S: MS Hornet Micro Helicopter Package GoEFlight Aircraft - Electric - Airplanes (FS/W) 0 Mar 24, 2002 06:46 PM
Weight shift control FemtoFunFlyer Electric Heli Talk 4 Mar 20, 2002 07:05 AM
FS: MS Hornet Micro Helicopter Package GoEFlight Aircraft - Electric - Airplanes (FS/W) 0 Feb 11, 2002 08:37 PM
WTB Hornet Micro Helicopter JoeR Aircraft - Electric - Airplanes (FS/W) 0 Dec 17, 2001 10:07 PM
