Go Back   RC Groups > Aircraft - General > Aerial Photography
Old Nov 29, 2004, 07:29 PM   #1
maxalentix's Avatar
Send a message via Yahoo to maxalentix
Magpie AP - Success!
I finished assembling my Magpie Slowflyer wing on the weekend along with the MM camera mount and I decided to give it a try. I attached the camera mount to the fuselage using fiberglass tape and velcro. I stuck the velcro to the plastic straps that line the fuselage for strength. After seating my Sony DSC-U40 into the mount, I threw the Magpie into the wind. At first the AXI 2208/34 struggled a bit with the extra 5 oz of weight, but the Magpie did manage to climb..and climb and climb and climb! this plane really floats! It must have gone up almost 1000 feet and I was able to just float around at less that 1/2 throttle. I stayed up there barely moving for 30 minutes, before my neck began to really get sore. A large black bird came over to check out the red and yellow plane. I estimate that at the throttle setting I was using, the motor was drawing less than 2 amps. I never thought this plane would soar that well with a camera on it! The Magpie came in very predictably and slowly for a soft touchdown in the grass. Another reason I tried this setup is that landing in grass is stress-free: no aborted landings due to wind or people in the way. Oh, there was a steady 5 mph wind blowing too.
I used my home-made camera switch.
--Gary
  • Name: PB290055W.jpg
  • Name: PB290057W.jpg
  • Name: PB290058W.jpg
  • Name: DSC00224.jpg
  • Name: DSC00225.jpg
maxalentix is offline Find More Posts by maxalentix   Reply With Quote
Old Nov 29, 2004, 07:46 PM   #2
maxalentix's Avatar
One last Picture
  • Name: DSC00242-High640.jpg
Old Nov 29, 2004, 07:48 PM   #3
honey... anOTHER PLANE!
Dampy's Avatar
Nice pics, great altitude! Did you have to dial in a little trim adjustment with the cam on the side?
Also what battery & prop are you using?
Neil
Dampy is offline Find More Posts by Dampy   Reply With Quote
Old Nov 29, 2004, 08:05 PM   #4
maxalentix's Avatar
Thanks Neil,
I did dial in 1 click of trim to compensate, but I didn't really notice the camera at all once it was in the air. I also used a 50-cent solution: I taped 2 quarters to the opposite wingtip
My power setup is OK - no vertical climbing here:
Prop: APC 10x5
Motor: AXI 2208/24 brushless
ESC: Castle Creations 10-amp
Battery: Thunderpower 2S 2100mah lipo. (I bet it would be a lot better with a 3S)
How is your inline-camera Mapgpie coming?
--Gary
Old Nov 29, 2004, 08:15 PM   #5
lvspark's Avatar
Sounds like a good one!
I really want to get mine in the air...
lvspark is offline Find More Posts by lvspark   Reply With Quote
Old Nov 29, 2004, 08:24 PM   #6
Client Advocate
RCFEVER's Avatar
That motor is rated for about 17oz of thrust. Seems a bit underpowered.
What is your AUW?
I bet an AXI 2808/34 or PJS 800E would be perfect. Throw a co-pilot on there, rocket the plane up to desired altitude, kill the power and let it float up there with the co-pilot keeping her level, then snap away!!!
BTW your magpie pie looks good, nice pics.
Matt
RCFEVER is offline Find More Posts by RCFEVER   Reply With Quote
Old Nov 29, 2004, 08:35 PM   #7
maxalentix's Avatar
It climbs fast enough with this setup, just not what I am used to flying it with the SP wing and no camera. AUW is 23 (camera setup). A 2808 ! Wouldn't that would rip the motor mount right off ?
BTW, I have a 2808/20 in my parts box, and I am waiting for the Top Creations aluminum mount. I think I'll save it for a larger plane though
--Gary
Old Nov 29, 2004, 08:46 PM   #8
Client Advocate
RCFEVER's Avatar
Lol,I should have mentioned that a different motor mount would probably be needed. But this motor weighs the same as the PJS 800 and will allow you to carry more gear.
Matt
Old Dec 01, 2004, 12:57 AM   #9
Peepin' from above
Gwelan's Avatar
Maxalentix, do you think the Magpie is the next big thing in AP ? I mean, is the Slowstick about to be be replaced as the standard AP platform ?
Gwelan is offline Find More Posts by Gwelan   Reply With Quote
Old Dec 01, 2004, 02:20 AM   #10
maxalentix's Avatar
Gwelan,
I can't really speak for others, but I prefer the way that the Magpie flies over the Slowstick. It doesn't get thrown around in the wind, and mine will still float around with a 5 oz camera+mount sticking out of its side. Maybe the SS can handle higher payloads, and the stick configuration may be more flexible, but I vote for the Magpie. I also have an EZ-400 plane for AP, but that one needs a "runway" to land. I went out at lunch today and flew the Magpie some more --> http://rcgroups.com/gallery/showphot...cat=500&page=1
After the flight, I just plopped it in front of me on the grass... easy!
--Gary
Old Dec 01, 2004, 08:47 AM   #11
Lifetime hobby
rhenningsen's Avatar
Video
The Magpie sounds great. But a forward facing camera is a must for good aerial video.
Has anyone explored ideas for a mount that allows a forward-facing camera?
rhenningsen is offline Find More Posts by rhenningsen   Reply With Quote
Old Dec 01, 2004, 09:38 AM   #12
TStokes's Avatar
Send a message via Yahoo to TStokes
A forward-facing camera is necessary for a certian "type" of video - but I have been taking videos from the side - and I consider them "good".
If you want to simulate the feeling of flying the plane, I guess you would want forward-facing (although you can't see the ground from the forward glass of most planes other than ultralights). But for circling, say, a golf course to get an idea of the layout, side mounted is better.
Almost all of the aerial video I have seen were taken from the side of a plane or helicopter - even in situations like 'Cops'. Exceptions are sweeping videos over a cliff or "gunsight" videos from warfare.
If you are trying to "fly by video" with a live link, then I would thinkthat forward-facing is a must.
Tom
TStokes is offline Find More Posts by TStokes   Reply With Quote
Old Dec 01, 2004, 10:12 AM   #13
Flying in Sycamore IL
Looks really nice Gary,
I am thinking I too will be building a magpie over the winter
Could you tell us more about the homeade switch for the Sony cams ?
Could this work on any newer sony ?
I have a dscV1 that I am using now with a servo and would love to rig something like a remote setup.
Thanx in advance
Ryan
Boydz is offline Find More Posts by Boydz   Reply With Quote
Old Dec 01, 2004, 01:53 PM   #14
maxalentix's Avatar
Boydz,
You won't need the whole winter to build the Magpie it should only take week at most if you work on it a few hours every day.
Here is more info on the switch --> http://www.rcgroups.com/forums/showthread.php?t=271573
It is based on an Atmel microcontroller and and AQW210 switch. I programmed it to time the signal from the receiver and then trigger the switch based on where the stick on the transmitter is. I soldered 3 wires onto the Sony's shutter switch. Soldering those wires was very hard to do because the solder pads are TINY. Not recommended if you don't have rock-steady hands. I made my own because I have some experience programming microcontrollers. I browsed RC CAM Man's site before building my switch. He has ready-made units here --> http://www.rc-cam.com/project1.htm
The AQW210 chip is a solid-state switch and it works with my Kodak CX-7300 as well. I think it would probably work with most cameras, but I can't confirm it.
--Gary
Old Dec 01, 2004, 02:06 PM   #15
Ascended Master
Sparky Paul's Avatar
Your first aerial shot looks more like Engiland than the land of fruits and nuts.
All that green!
Resembles the area around Widebottom on Walmsley...
Sparky Paul is offline Find More Posts by Sparky Paul   Reply With Quote
Rave First Magpie AP - Nikon 3700 Pics Kosh28 Aerial Photography 4 Apr 01, 2005 01:07 PM
Does the Magpie AP come with camera mount? Mac8 Aerial Photography 2 Apr 01, 2005 10:31 AM
Nikon Coolpix 5600 Video from Magpie AP manatee Aerial Photography 7 Apr 01, 2005 03:03 AM
First pics from Magpie AP and Nikon 3700 mikeb33 Aerial Photography 11 Mar 28, 2005 05:46 PM
buy a MagPie AP, or just get a steelhead wing for my slow stick? Nethole Aerial Photography 3 Mar 23, 2005 09:59 PM
Congratulations SimpleM!
