Old Nov 29, 2004, 08:20 AM
Ninjak2k is offline
Find More Posts by Ninjak2k
United States, VA, Warrenton
Joined Apr 2001
Cleanup after an off-road run?
After a nice filthly off-road run, is there any place I should be looking to clean up like the axle bearings to keep things rust free and running right or any other maintenance that should be done?
Has anyone run in sand and, if so, is there any special maintenance that should be done afterward?
Dan
Ninjak2k is offline Find More Posts by Ninjak2k
Old Nov 29, 2004, 08:32 AM
savage is offline
Find More Posts by savage
Joined Jun 2004
Try using nitro clean. You can get it at your lhs.
savage is offline Find More Posts by savage
Old Nov 29, 2004, 03:43 PM
Ninjak2k is offline
Joined Apr 2001
Thanks, savage. I'm not concerned with the oil residue from the fuel so much (as I only run electrics), but rather getting dirt, mud, sand, etc. in the bearings, components, and the like. Unless nitro clean is a general purpose cleaner?
~Dan
Old Nov 30, 2004, 07:58 PM
Kiiski is offline
Find More Posts by Kiiski
Will race for parts!
Kiiski's Avatar
United States, WA, Chehalis
Joined Mar 2004
An air compressor and Simple Green work great. Spray on the simple green, avoiding unprotected electronics and the engine, then spray it off with an air nozzle.
Kiiski
Kiiski is offline Find More Posts by Kiiski
Old Dec 01, 2004, 09:21 PM
lectraplayer is offline
Find More Posts by lectraplayer
Professional Crasher
Joined Apr 2004
I usually seal all openings (I run nitro), and disconnect the battery, then I just use the hose pipe to spray it off. I will not reconnect the battery until next morning after the truck has fully dried off. I then will often tear it down and relube the bearings, but this isn't really necessary, but is highly recommended. Again, disconnect the battery and avoid flooding the radio best you can, and don't reconnect the battery until the next morning. Mixing electricity with water is where you get in trouble.
lectraplayer is offline Find More Posts by lectraplayer
Old Dec 02, 2004, 05:35 PM
Jbiker31691 is offline
Find More Posts by Jbiker31691
Harrisburg Intl, Pennsylvania, United States
Joined May 2004
for in the sand baloon all your electronics. be sure to get ALL or the sand out of thhe gears and small crevaces.
Jbiker31691 is offline Find More Posts by Jbiker31691
Old Dec 02, 2004, 06:41 PM
Pacoson71 is offline
Find More Posts by Pacoson71
6 planes 2 jets 2 helis
Pacoson71's Avatar
United States, MA, Charlton
Joined Sep 2002
simple green and denatured alcohol for near the electrics works best for me.
use WD40 on bearings and dogbones to remove water
if you don't have compressed air
Pacoson71 is offline Find More Posts by Pacoson71
Old Dec 02, 2004, 08:56 PM
Joined Apr 2004
I often use isopropanol to do my cleaning, it takes off all the oil and grime and stuff really well. I only occasionally use the water hose when there's a LOT of crap on my car.
Old Dec 05, 2004, 12:22 AM
cressers is offline
Find More Posts by cressers
Joined Nov 2004
strip it down, clean, grease and re-assemble.
Will last forever and fly.
cressers is offline Find More Posts by cressers
Old Dec 07, 2004, 08:42 PM
Joined Apr 2004
Yeah, the cleaner you keep it, the longer it will last, whatever it be.
HELP! New to RC. Looking for an off-road car or truck jhouzenga09 Off-road Cars 7 Dec 26, 2007 11:06 PM
Question Any1 own an OFF-ROAD track xxxnt7 Off-road Cars 4 Jun 21, 2007 11:23 PM
Discussion Looking for an off road buggy moody07747 Off-road Cars 17 Jun 09, 2007 03:38 PM
It's still an off-road vehicle! FullTrax RC Tanks 9 May 18, 2004 10:04 PM
