Old Nov 28, 2004, 07:36 PM
Lemjim is offline
Find More Posts by Lemjim
Joined Sep 2004
Warped wing
Need some input on straighting wing. While repairing the RH wing I came up with up with a warp or twist. Eveything was o.k. till I put the last piece of sheeting accrossed the front leading edge, pow the warp or twist. The wing has not been covered at this point. This is for my T-34 and has a lot of sheeting and not much open area. Could I spray with hot water and clamp till dry or should I use some other method? Trailing edge is about a 1/4" lower at the tip end and it takes some good pressure to twist it back holding on to the ends and twisting.
Thanks , Jim
Lemjim is offline Find More Posts by Lemjim
Old Nov 28, 2004, 08:06 PM
Shroomer is offline
Find More Posts by Shroomer
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
Just a heat gun and a helper should solve this. might be pretty hard to twist out the warp
how far is it outa wack ?
Shroomer is offline Find More Posts by Shroomer
Old Nov 28, 2004, 09:54 PM
RC-Addict is offline
Find More Posts by RC-Addict
RC-Addict's Avatar
USA, OR, Albany
Joined Sep 2004
Yes, I had the same problem with a bi-plane wing I built. I read somewhere to spray a water-ammonia mixture (not sure what the ammonia was for. Plain water would probably work too.) and then twist it in the opposite direction, and hold it in place with weights/clamps, and let dry overnight.
You will need to be able to twist it the same amount in the opposite direction (over twist) so that when it springs back, it comes out where you want it. After you have sprayed it down, it will be able to flex more than it can dry. If you over do it, or it needs more, just do it again. I ended up having to do mine 2 or 3 times before it was right.
RC-Addict is offline Find More Posts by RC-Addict
Old Nov 29, 2004, 05:55 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
The ammonia is supposed to soften the balsa wood better than plain water. Over twist in the opposite direction and let dry that way. It should spring back a little bit. You will want to get this right before covering the wing.
GregG is offline Find More Posts by GregG
Old Dec 10, 2004, 10:33 AM
Lemjim is offline
Joined Sep 2004
Well I tried the water treatment twice and it took some out but not all, so I went ahead and covered it then put some opposite twist in, then took my new heat gun and sucked out the wrinkles and WaLa now straight. Thanks for the input on this rebuild.
Jim
Old Dec 10, 2004, 08:50 PM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
glad to hear the heat gun worked man.... can we get pics of the finished model ? and maybe some in flight ?
Dandy Warped Wing cubsflyer Parkflyers 13 Jun 19, 2003 09:59 PM
Wattage Extra 330L ARF has warped wing - Help ! Al P Electric Plane Talk 2 May 09, 2003 11:12 AM
Warped wing..... pullin-gs Electric Sailplanes 7 Jan 07, 2003 06:31 AM
Virus 280 warped wing help! locomoto Parkflyers 6 Apr 20, 2002 09:03 PM
Fixing a warped wing tenover Power Systems 3 Mar 04, 2002 11:51 PM
