Old Nov 28, 2004, 06:00 PM
ave
Wind Junkie
ave's Avatar
North Coast, Calif.
Joined Jun 2004
Lets make the complete builders toolbox!
Lets put together a list of tools/materials that making EPP building and some mild composite work(Join/glass a wing/fuse once in a while, make fillets, etc) enjoyable. These tools should go as far as giving one the ability to make a nice looking PSS plane, like in so many of the awesome build threads I've seen!
I searched the threads but didn't find everything I felt was needed, so point me to a thread that tells this if I missed it. I know you can get away with 10%(or much less) of what is listed, but this is a semi-ultimate list of tools. I'm not talking about $3000 mills/lathes and such though!!! Nothing here costs much more than $100 individually. I can actually afford to buy one of these things once in a while you know
I guess the next thing to do after this is to prioritize them(so I know which order to buy them in!)... ack!
Here is an initial list:
Power tools:
-Dremel tool + attachments[drill press, router(table and plunge), multi-cutter] & bits
-Tabletop Belt(4"x36")+disk sander(6")
-Small air compressor(for dusting/airbrushing/etc)
-Hot glue gun
-Planer?? (do they make them small enough?)
-Soldering iron
Hand tools:
-Permagrit$(block$, file$, etc) $$$$$....
-Sanding blocks(foam, wood, shaped, etc)
-Sandpaper(60 thru 400grit, dry and wet/dry)
-Knives/saws/miter boxes/scissors(various)
-Pliers(Z-bend, needle nose, etc)
-Tweezers
-vice
-Levels(a few)
-Measuring(tape, straight edges, square, triangles, flexable, adjustable)
-Clamps(various)
-Cutting mat/board?
-Incidence meter?
-Hand/razor Plane
-Spackle blades/cards(different sizes/shapes)
Common building materials:
-CA(thick, med, thin, kicker)
-Epoxy(5min, 30min, 2hr?)
-Epoxy mixing materials(gloves, cups, sticks, syringes, brushes)
-Chopped Glass
-Micro balls
-Lightweight filler/spackle(drywall filler)
-Bondo
-Fabric scraps(kevelar, carbon, glass, mat)
-Goop(Marine)
-Acetone
-Toulene?
-3M 77
-Carpenters glue
-Fiber tape(1/2", 2", unidirection+cross)
-Various balsa, spruce, plywood scrap
-Various EPP scrap
-Masking tape(various sizes)
-Mylar?
-Release agent/wax?
-Silicone
Covering/Finishing tools/materials:
-Covering Iron
-Heatgun
-Airbrush
-Brushes
-Pens(Sharpie, etc)
-Paints
-Primer
Misc:
-5-6lb +/- 1.0 gram scale(for heavier less accurate weighing, AUW, etc)
-8oz +/- 0.1 gram scale(component weighing, accurate epoxy mixing)
Feel free to add....
ave-
ave is offline Find More Posts by ave
Old Nov 28, 2004, 06:06 PM
average user
Joined Jun 2004
music
mr.zagi5c is offline Find More Posts by mr.zagi5c
Old Nov 28, 2004, 06:23 PM
timmig's Avatar
Southern California
Joined Sep 2003
Corona's!!!!!!!!!!!! Are MANDATORY!!!
timmig is offline Find More Posts by timmig
Old Nov 28, 2004, 06:41 PM
ave
Wind Junkie
ave's Avatar
North Coast, Calif.
Joined Jun 2004
I see, I guess we need to and an "entertainment" section...
Old Nov 28, 2004, 06:51 PM
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
Man, I have enough problems building "straight" when sober, I couldn't imagine how bad my stuff would look after bending an elbow a couple times
ke6guj is offline Find More Posts by ke6guj
Old Nov 28, 2004, 08:22 PM
Junk pile raider
krash's Avatar
Fremont, Cal
Joined Mar 2004
I only have 15 of those items!
krash is offline Find More Posts by krash
Old Nov 28, 2004, 08:32 PM
average user
Joined Jun 2004
I only have eight...
Stay in it!!!!
Riverside, California, United States
Joined Aug 2004
It looks like I need to find a scale and some goop.
joe manor is offline Find More Posts by joe manor
Old Nov 28, 2004, 10:30 PM
sANTA mONICA
Joined Nov 2004
All I really need is a CNC mill, lol
DANWAY is offline Find More Posts by DANWAY
Old Nov 29, 2004, 12:12 AM
MINE!
Mick Molloy's Avatar
Australia, NSW, Hammondville
Joined Jul 2003
I think we should put some BEER on that list.
Mick Molloy is offline Find More Posts by Mick Molloy
Old Nov 29, 2004, 12:35 AM
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
I got the beer!!!!!
steve wenban is offline Find More Posts by steve wenban
Latest blog entry: been there and back
Old Nov 29, 2004, 12:36 AM
Joined Dec 2003
about the only thing I got on the list
Old Nov 29, 2004, 06:51 AM
Alfred's Avatar
Perth
Joined Apr 2002
A press drill would be nice and a disc sander.
Alfred is offline Find More Posts by Alfred
Build Log Hagamos un F3B -going stronger than ever - chetosmachine Multi Task F3X 231 Feb 16, 2009 04:46 PM
Discussion 1/32 pan car ?? lets make one superdave42 Micro Cars 24 Feb 26, 2008 05:00 PM
lets make a full fuse yak 54 sprinter Foamies (Kits) 12 Feb 01, 2006 12:03 PM
