Old Nov 26, 2004, 09:17 AM
Mat
The ground jumped at it!
Mat's Avatar
Ohio
Joined Jun 2004
Can lipo batteries be used in below freezing weather?
Also cand your store them and charge them in below freezing tempertures?
Mat is offline Find More Posts by Mat
Old Nov 26, 2004, 09:34 AM
mexico's Avatar
NJ
Joined Aug 2003
I wouldn't suggest storing them in below freezing conditions. It may be possible that if the contents froze solid some chemical changes could take place or expansion could damage the cell. Just a guess.
In terms of using them in freezing temps - I have. As the pack gets colder it puts out less power and flight time decreases. If you can keep them inside a full fuse plane, out of the wind, or cover them with some foam or other insulator they work a little better. As far as I can tell using them in the cold won't damage them.
Not sure about charging them in freezing conditions. Seems to me it would be similar to using them. The chemical reaction would probably happen slower and charging might take longer. But I am no expert.
mexico is offline Find More Posts by mexico
Old Nov 27, 2004, 09:55 AM
Germany
Joined Dec 2001
Below 5°C, you should only slow charge them (1/10C).
Suzanne is offline Find More Posts by Suzanne
Old Nov 27, 2004, 10:45 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Here is a link scroll down to common l specs for Poly Quest Li Pos.
http://www.battlepack.com/polyquestspecs.asp
Charles
Can a Futaba crystal be used in GWS receiver? eta Parkflyers 3 Aug 13, 2004 02:52 PM
Can 555 Rx be used in 40 size plane? billsmithjr Hitec/Multiplex USA 3 Jul 23, 2004 12:10 PM
Can BL Motors be used in RC Cars and Trucks? Rogerdoger Power Systems 6 Jan 04, 2004 04:32 PM
Can a Marine/RV battery be used in a car? Ben74 Power Systems 13 Jan 31, 2002 01:34 AM
Can a folding prop be used in pusher config? MtnGoat Power Systems 2 Jul 26, 2001 09:44 PM
