Old Jan 12, 2005, 10:09 AM
TheZeek is offline
Find More Posts by TheZeek
Never enough time to Fly
TheZeek's Avatar
Maine
Joined Nov 2004
You will Have to post some pictures of the new motor setup when you get it done.. Did you build your kan 1/3A 1050 pack or purchase it somewhere?
Zeek
TheZeek is offline Find More Posts by TheZeek
Old Jan 12, 2005, 10:39 AM
juki48 is offline
Find More Posts by juki48
Canandaigua, NY
Joined Sep 2004
I bought the pack, but there's a ton of sources for those. I'll post some pics when it's done. I have to rewind the motor. it's too hot for the soarstar. it'll rip it apart. I'd rather get longer flight times anyways.
juki48 is offline Find More Posts by juki48
Old Jan 31, 2005, 06:45 AM
juki48 is offline
Canandaigua, NY
Joined Sep 2004
well, I rewound the motor and took the soar star out yesterday. It was amazing. still don't have any pics but it did fly vertical! not the best thing for the plane but It was still a ton of fun! flight times were great even in the cold!
Old Jan 31, 2005, 09:24 AM
Mnelsen is offline
Find More Posts by Mnelsen
Kart racer
Kansas City, Kansas
Joined Jan 2005
One of the problems I found with my Soarstar was wieght. It flies much better with 9 or 10 oz. taken off. Smaller RX gear will help but put a GWS IPS system on it with a LIPO batt, better yet with a brushlees motor or an outrunner motor. Yes, I know much more money, but you can fly it in closer and very slow, even indoors. Less wieght also means less damage on impact.
Mnelsen is offline Find More Posts by Mnelsen
Old Jan 31, 2005, 09:55 AM
juki48 is offline
Canandaigua, NY
Joined Sep 2004
my outrunner I built weighs about 1/2 as much as the stock motor and gearbox. It spins the same prop and puts out 2oz more static thrust and uses more than an amp less current. it does fly well with a smaller battery. I have a 4/5th AAA pack that it just floats around with. you can fly circles around yourself and just reach out and pick it out of the air. I must get it indoors!
Old Feb 04, 2005, 11:53 PM
mrm1 is offline
Find More Posts by mrm1
Fly a LiL' Lower Will Ya!
mrm1's Avatar
North Central Florida
Joined Sep 2004
I broke down and went cheap. Got a new 400 motor on an impulse buy.
That is up from the 380 stock. cost was $15 and it put the power set up to just over stock when it was new. Flys great now. Gets out over the trees without making any passes around the baseball field. Just wish I would have gotten a 480...and that brushless sounds good too.
Really enjoying it now
mrm1 is offline Find More Posts by mrm1
Old Feb 05, 2005, 05:34 AM
juki48 is offline
Canandaigua, NY
Joined Sep 2004
the 400 was a good move, with this plane, lighter is better. I was even tempted to try a nice geared 300 with the lighter pack. for $15 it gets you in the air with a little more performace. can't go wrong with that.
Old Feb 05, 2005, 06:49 AM
TheZeek is offline
TheZeek's Avatar
Maine
Joined Nov 2004
Has anyone gone lipo on a soarstar with the stock motor? The lipo 3s 1500mah pack weighs 5 oz less than the pack (9.6v A sized 1100mah) that I am using now. Next question is would the stock motor handle the extra voltage?
Zeek
Old Feb 17, 2005, 08:40 AM
juki48 is offline
Canandaigua, NY
Joined Sep 2004
brushless with a cam
here is my brushless motor with a cheap digi cam strapped to it. works great!
Old Feb 17, 2005, 09:11 AM
HIGHFLYER99 is offline
Find More Posts by HIGHFLYER99
HIGHFLYER99's Avatar
North East
Joined Nov 2001
the extra voltage, if applied frequently, will cut down the life a bit of your speed 400 but what the hell, they're cheap. What's the total weight with camera?
HIGHFLYER99 is offline Find More Posts by HIGHFLYER99
Old Feb 17, 2005, 09:15 AM
juki48 is offline
Canandaigua, NY
Joined Sep 2004
hmmm.. I'll have to check when I get home today. camera and servo add 6oz. I did weigh that.
Old Mar 05, 2005, 03:51 PM
constantcrash is offline
Find More Posts by constantcrash
Trinity, FL
Joined Jan 2003
juki48,
I just finished putting together a SoarStar and would like to know if the CG is actually supposed to be as far back as the little booklet says.
That's almost exactly half-way the cord of the wing. Usually it's about 1/3 the cord on most planes.
Jim
constantcrash is offline Find More Posts by constantcrash
Old Mar 05, 2005, 06:31 PM
TheZeek is offline
TheZeek's Avatar
Maine
Joined Nov 2004
Thatís where I balance mine. Works good for me.
Old Mar 05, 2005, 07:24 PM
Trinity, FL
Joined Jan 2003
Thanks Zeek,
Just thought it might be a mistake and didn't want to make that first launch with a great big surprize coming my way.
Jim
Old Mar 06, 2005, 05:39 AM
TheZeek is offline
TheZeek's Avatar
Maine
Joined Nov 2004
I also hand launch my Soarstar each and every flight. It can get real squirrelly on the ground if there is any wind at all.. I just give it half throttle and give her a toss.
Zeek
Video Super Flying Models Soar Star on Floats mrm1 Electric Plane Talk 0 Dec 23, 2006 11:25 AM
Build Log Super Flying Models Eindecker Assembly rnrdoc Fuel Warbirds 2 May 31, 2006 07:31 AM
Question Anyone know the address for the Super Flying Models website? yogorilla Parkflyers 1 Jul 14, 2004 01:37 AM
