Old Dec 05, 2004, 04:23 PM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
No, it pushes bottom and top flow out. THere is no spanwise flow at the center, and it just goes out from there. This does NOT give a beneficial effect; in fact quite the opposite. It make the wing stall early and at the tips.
The tip vortex in the sense you spek is not signifigant on any real wing. All wings have the vortex fromshear effects between the downwash and outside air, but the vortex caused by spanwise flow does not occur on some planforms like an elliptical or pointed wing.
--Alex
raptor22 is offline Find More Posts by raptor22
Old Dec 05, 2004, 08:51 PM
KingOfTheHill is offline
Find More Posts by KingOfTheHill
Ninja of the Nasty
KingOfTheHill's Avatar
Joined Jan 2004
Originally Posted by AustinTatious
Ive flown a sonic ( King of the Hill's) and it was awesome!
They seem to turn much tighter and also have way more yaw stability. They fly more like a real airplane than a wing. Plus they never tip stall and start spinning!
just saw this.... yes the JW and sonic are the same foil/thickness.... and the sonic (old name aurora) was bowmans first real DS built plane a few years back.... from what ive talked to pat about it, from what ive been told
wings dont like to stay knifedge'd they have a tendancy to correct themselfs and flatten out... also when you take a wing (any wing ive flown at least) when you put a lot of elevator in and you go to POP the top turn it kinda washes out and spins... like turning on ice...
those are what ive heard and felt in all wings ive DS'ed... and the planks ive owned (jw, moth, m60, electron) i have never felt that wash out or felt them fighting to stay knife edged....
those are just my takes....
JOe
KingOfTheHill is offline Find More Posts by KingOfTheHill
Old Dec 05, 2004, 10:11 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Hehe, I know why!
Because most of the swept wings on the market are designed for combat, not for DSing, and the planks are mainly designed for speed (and DSing) and not combat!
I'm a genius!
Steve
surfimp is offline Find More Posts by surfimp
Old Dec 05, 2004, 10:15 PM
Ninja of the Nasty
Joined Jan 2004
haha...... and the award goes to surfimp steve...
LOL
great answer... you should be on jepordy
JOe
Old Dec 21, 2004, 12:05 PM
grindel is offline
Find More Posts by grindel
Joined Nov 2004
It seems to me there is a need for a swept wing that uses a spanwise difference in airfoil shape instead of twist to make a bell shaped lift distribution..something with CF 1/4 chord and rear spars to remain stiff in fast flight. EPP to give the airfoil shape, covered in mylar. The hope is to create a wing that will need neither twist nor control deflection (reflex) to maintain level flight.
been floating in my head for a while...I need to get back into crunching numbers...
grindel is offline Find More Posts by grindel
Old Dec 21, 2004, 07:42 PM
raptor22 is offline
raptor22's Avatar
Joined Apr 2003
The twist generally isn't used for the lift distribution, though. It is used to counteract the downwards pitching coeffecient of the non-plank airfoils.
--Alex
Old Dec 22, 2004, 12:15 PM
grindel is offline
Joined Nov 2004
With correct design (I.E. change your sweep to give the correct moment arm for the downforce),it can be used for both. You can get a bell shaped lift distribution (if your not familiar, it is similar to the eliptical lift distribution in that it is optimised for drag but has the added benefit of being suitable for trimming swept flying wings) while in trimmed flight.
In essence I am talking about the same thing you are...
ok...so anyway, reasons for the twist asside; what about changing the airfoil along the span instead of spanwise twisting? It might yield a stronger structure (at least a structure less sensitive to torsional loads) and less frontal area (reducing drag)
Old Dec 22, 2004, 12:56 PM
hkrussell is offline
Find More Posts by hkrussell
United States, CA, Tehachapi
Joined May 2002
Modern airfoils nave their aerodynamic center at 25% (generally). That means they will twist around the 1/4 chord (25%). If the 1/4 chord is straight (i.e. plank wing), the wing is best able to resist this twisting force. This could be really important with EPP that doesn't have much natural strength.
A swept wing is easier to balance. No need for a nose hanging off the end (like JW's etc) to get the balance right.
Ken
hkrussell is offline Find More Posts by hkrussell
Question Why AMA banning Epp combat? not safe? Ming Slope 40 Jan 30, 2006 12:34 PM
Why AMA banning Epp combat? not safe? Ming Foamies (Kits) 5 Jun 12, 2002 06:31 PM
Polyurethane glue for EPP / EPP / Wood? JensJakob68 Foamies (Kits) 9 Feb 19, 2002 11:40 AM
A skin[sprayable] for epp foam ? Gman2 Power Systems 11 Jan 19, 2002 10:05 AM
Why do other EPP planes need tape covering and PicoJet Combat doesn't? WAR Foamies (Kits) 3 May 12, 2001 12:13 AM
