Espritmodel.com Heli Air
Old Nov 24, 2004, 01:38 PM
Spudboy
El Segundo, CA
Joined Nov 2004
CD-ROM Motor runs rough at low throttle
I just finished a GBv1.1 with 20 turns Y connection. I am using the CC10 speed control.
The motor seems to make a lot of noise at 1/3 throttle and below but runs nice and smooth above that. Seems to make plenty of power also.
Any ideas? do I need to adjust the speed control timing?
This is on a new Shocky so I'm looking forward to flying it but I don't want to let the magic smoke out of anything.
TIA
spudboy is offline Find More Posts by spudboy
Old Nov 24, 2004, 01:41 PM
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
What prop you got on that?
RobDog is offline Find More Posts by RobDog
Old Nov 25, 2004, 08:44 PM
Parrothead Extraordinaire
Mark Gund's Avatar
Island of Margaritaville.No parallels of latitude or longitude mark the spot exactly. Passports are not required
Joined Sep 2002
Prolly speed control issues.
Mark Gund is offline Find More Posts by Mark Gund
Old Nov 25, 2004, 09:04 PM
Evil Plane Doer
jskrebs's Avatar
Westport, Pennsylvania, United States
Joined Dec 2002
Happens,
What is your setup?
jskrebs is offline Find More Posts by jskrebs
Old Nov 26, 2004, 12:58 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I gust built a GB v1.1 12T. I am using a 8x4DD, 2 cells and a CC controller. Starting with 3 cells and with the timing retarded all the way it would not run above 1/3 throttle. With the timing at the mid setting it would not run above 1/2 throttle. With the timing advanced fully it would run full throttle but rough between 1/3 and 1/2. I then dropped to 2 cells and it runs rough for the upper 1/2 of the throttle range. I will next try changing the PWM switching rate. I will post my results when I get a chance.
motorhead is offline Find More Posts by motorhead
Old Nov 26, 2004, 06:38 AM
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
a 12T will not run a 8x4 on 3S even on 2S try a 4 or 5 " prop. FOr an 8x4 try at least 17T on 2S. Check the DB on the GObrushless site.
I did a 12 T for my tie fighter prototype and if spun the 4.5 at 13000 rpm at 6 amps.
Old Nov 27, 2004, 12:02 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I rewound to 15T Wye and it runs good now. It has about 8oz of thrust on 2s. It should do better when I get a better pack on it. Next I need to hook up my amp meter so I can see where it is at. If I am much below 6A then I might try 13T.
Old Nov 27, 2004, 01:09 AM
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
Other obvious faults would be having missed a turn somewhere, or a small short. When I over-prop mine they tend to run rough at high speed but OK at low power.
RobinBennett is offline Find More Posts by RobinBennett
Old Nov 30, 2004, 03:56 PM
Spudboy
El Segundo, CA
Joined Nov 2004
Found the problem.... speed control needed to have the advance set. The motor runs like a champ!
Plenty of power on a 8X4.3 and my Shocky flies great!
One dissapointment.... had to add one ounce of lead to the nose making the AUW 6.375 oz.
Fortunatly I traced the pieces and have some Depron on the way. I'll make a new one and move all of the gear forward.
For Sale Scram-Blur wing kitwith CD Rom motor at Reduced Combo Price sylair Aircraft - Electric - Airplanes (FS/W) 4 Apr 29, 2006 08:59 PM
Discussion Partial Throttle/Gov: motor runs cooler at full derway Castle Creations 11 Apr 28, 2006 08:59 PM
Question cd rom motor smokes and cogs at med throttle puspuss121 Power Systems 1 May 10, 2005 01:54 PM
WTB - Double CD ROM Motor at SEFF Kevin Murray Aircraft - Electric - Airplanes (FS/W) 1 Apr 20, 2005 11:54 AM
Brushless motor kicks back at low throttle settings??? New Park Pilot Power Systems 5 Aug 28, 2004 08:55 AM
