Old Dec 21, 2004, 06:50 PM
Mr. Boogie is offline
Find More Posts by Mr. Boogie
Mr. Boogie's Avatar
Morristown, New Jersey (excl EWR), United States
Joined Oct 2003
AirX,
Thanks for jumping in with the intake lip info. Looking forward to your micro F18E. Better start doing my eye excercises . These small planes sure are fun to track in the sky.
When you get around to the F35, I'd love to see your progress .
Mr. B
Mr. Boogie is offline Find More Posts by Mr. Boogie
Old Dec 21, 2004, 06:54 PM
Mr. Boogie's Avatar
Joined Oct 2003
Originally Posted by jmralves
Hi again,
I'm one of the people who use cdrom and EDF in nano thread
trade GWS EDF40 for microfan to improve thrust, in fact, thrust improve but not enough
Jorge
PS already have the plans, thanks!
Sorry,
I need to pay a little more attention when reading. Please let us know the results of your intake lip installation.
Boogie
Old Dec 21, 2004, 07:14 PM
Mr. Boogie's Avatar
Joined Oct 2003
Depron construction Info
For those unfamiliar with working with thin depron.
All of my bends were created by first placing a strip of packing tape on the outside of the bend. If you do not do this the depron will crack/tear.
Then the bend line was scored with a metal edged ruler. Slowly work the bend along the length of the fold lines. While the tape is still on I like to exercise the bend by flexing it a few times.
All rolled pieces had packing tape on the outside curvature (similar to above), prior to rolling over the edge of my stair rails . No heat forming is necessary at this thickness (3mm).
Tape can be (carefully) peeled off after the bends/rolls are made.
Mr. B
Old Dec 21, 2004, 07:48 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Will install the lip tomorrow, if I don't get 250g, I quit! start a new hobby!
just joking
Eric did you measure RPM in your microfan with you r setup?
Jorge
I can figure the rpm off of voltage and KV but I dont have any way to measure rpms ATM(at the moment). Looking at the figures from the last test on the stand it was holding 10.9volts if it ws 82% efficient then the rpm's would be 46000 or so.
Eric B.
AirX is offline Find More Posts by AirX
Old Dec 21, 2004, 08:20 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Originally Posted by Mr. Boogie
AirX,
Mr. B
When I get to builidng it I will post it. I hear you on the small fast planes that are hard to see and keep track of, I had a pylon racer last year and for me that was definitely a challenge, it flew arround 60 with a speed 400 in it with only 28in wingspan and fuselage length. Keep the ideas flowing Mr.B because we are getting into a new realm with Thomas Nelson leading the way...
Eric B.
Old Dec 24, 2004, 08:49 AM
Mr. Boogie's Avatar
Joined Oct 2003
Color Schemes
I'm looking for a color scheme, it does not need to be scale but I don't want it to be cartoonish. Initially I'm thinking something along the lines of the paint schemes for the early F16/F18's (red and white, I believe).
Does anyone know of any good color scheme references that I can tap into?
Mr. Boogie
Old Dec 24, 2004, 09:02 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
The F-35, in time, could be the replacement for the Thunderbirds and Blue Angels, so.....
I'm thinking of repainting mine
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 24, 2004, 09:04 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Hi Folks,
good and Bad news,
I install a depron lip in the microfan, Run 1 test, and guess what:
at 273g the lip was partially sucked in
So, the installation of the lip yields an increase in static thrust from 169g to 270g (wich can be improved with a tougher lip).
Now I'll try two things, a new cdr motor (8mags and AaABbBCcC) #turns in doubt yet and a new lip build with a mix of depron and balsa)
Jorge
jalves is offline Find More Posts by jalves
Old Dec 24, 2004, 09:07 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Mr. B.
Try this one http://www.airliners.net/
Jorge
Old Dec 24, 2004, 09:45 AM
Mr. Boogie's Avatar
Joined Oct 2003
Hey Kevin,
Just got my latest issue of RCM! Your F35 looks good in print .
16 oz AUW for your bird, is your power system putting out more than that? I've got a TP2100 and thought it might be to big.
Boogie
Old Dec 24, 2004, 09:48 AM
Mr. Boogie's Avatar
Joined Oct 2003
Hi Folks,
good and Bad news,
Jorge
Jorge,
Your numbers sound much nicer. You can also try coating your intake lip with WBPU or a thin coat of epoxy. You might also want to tack glue it with CA (foam safe) to the microfan shroud. Then let her rip.
Thanks for the link!
Boogie
Old Dec 24, 2004, 10:10 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
you welcome!
Mr. B what's WBPU?
Jorge
Old Dec 24, 2004, 10:50 AM
Mr. Boogie's Avatar
Joined Oct 2003
Jorge,
WBPU is water based polyurethane. It's typically used to seal wood floors/furniture. You can dilute 50/50 with water to a milk like consistency and paint on, let dry and sand to a smooth finish.
Lots of info about it's usage in the foamies forum.
Mr. B
Old Dec 24, 2004, 10:55 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Ok, thanks Mr. B
Jorge
Old Dec 24, 2004, 11:36 AM
Kevin Cox's Avatar
Joined Jan 1997
Hey Kevin,
Boogie
Cool Boogie I will have to look for it. Thanks
My model is setup for max velocity which is why handlaunching is out. I don't recall what the thrust is but it is low, maybe 10oz at best.
Pics of my first EDF F5 Tiger 11 RCKing Electric Ducted Fan Jet Talk 5 Dec 30, 2003 12:57 PM
I am a Dork...or my first flight of the New year! 12:23 am kepople Parkflyers 14 Jan 01, 2003 09:59 PM
Pibros Twinn EDF-50 "My first EDF project" Appie Electric Ducted Fan Jet Talk 13 Oct 25, 2002 04:57 PM
Got my first EDF - T33 Wantab Electric Ducted Fan Jet Talk 8 Feb 02, 2002 10:15 PM
My First EDF Which one... kepople Electric Ducted Fan Jet Talk 8 Jun 30, 2001 01:43 AM
