Old May 10, 2010, 12:04 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
The Maiden!
Great Plane! Great Design! -- Thanks Mr. Boogie!
Definitely gonna add those ailerons now!
My modifications to the original plans are as follows:
-Increase size (125%) to fit 64mm fan
-install 360deg thrust vectoring nozzle unit
-add extra ducting to inlet to smooth out airflow
-mount motor further forward
-one piece wing with KFm4 airfoil (50%)
The Walkaround:
F-35 Scratchbuilt from Plans with Thrust Vectoring pt. 1:the walkaround (3 min 21 sec)
The Maiden & CRASH:
F-35 Scratchbuilt from Plans with Thrust Vectoring pt. 2: Maiden & CRASH!!! (4 min 26 sec)
Post maiden report:
torque roll was not a problem -- control surfaces were! This plane needs the linked ailerons!
Plane has been repaired. I will hold off on the paint! The only damage was to the front part of the nose. It acted as a "crumple" zone and absorbed the plane's weight on impact. I think it saved the rest of the plane!
Prior to next flight, I will add linked ailerons to the tailerons for better roll control! She will be back in the air in no time!
Stats:
26" WS
2200 3S 25C lipo
64mm fan
5250KV BL motor
50A ESC (only need 40A)
4 servos
delta mixer
AUW 23oz
Once I get her back in the air, hopefully I'll be able to utilize the thrust vectoring for tail slides, high alpha, flat spins, cobras, etc...
Photos of damage and repair below...
SNice is offline Find More Posts by SNice
Old May 10, 2010, 09:20 PM
Mr. Boogie is offline
Find More Posts by Mr. Boogie
Mr. Boogie's Avatar
Morristown, New Jersey (excl EWR), United States
Joined Oct 2003
SNice,
First off congrats on the maiden! She really looked under control and piloted well up until that low level roll attempt.
Good to see the damage is repairable. Nice job for your first edf, and you did a nice job with the build.
Cheers,
Mr. B
Mr. Boogie is offline Find More Posts by Mr. Boogie
Old Oct 20, 2010, 06:05 AM
Lt.Aki is offline
Find More Posts by Lt.Aki
Joined Oct 2010
I new to rc airplanes a i have few questions to ask: what is bluecore and depron and where i can buy it , how much time i need to build this airplane , what i need of electronics , can i make alerions and elevaton in place of tailerions , how it costs to build it and is it hard (i am very good non flying airplanes modeler).
Tnx for plans Mr.Boogie
P.S sorry for my bad english i don't live in english speaking country
Lt.Aki is offline Find More Posts by Lt.Aki
Old Oct 21, 2010, 07:41 AM
Mr. Boogie's Avatar
Joined Oct 2003
Hi,
Bluecore and Depron are sheet foams used in building construction projects and in our case RC plane builds. Depron can be purchased online in varying sheet sizes and thicknesses. Bluecore can be purchased in home improvement stores such as Lowes in the US. The plans detail what you need for electronics. At a minimum 2 9gram servos for taileron control, a motor, fan and esc. Build time depends on your skill level (as a builder), but once the parts are cut build moves fairly smoothly. Ailerons and elevator are fine just a slight weight addition. No idea on the cost, depends on your equipment selection.
Cheers,
B
Pics of my first EDF F5 Tiger 11 RCKing Electric Ducted Fan Jet Talk 5 Dec 30, 2003 12:57 PM
I am a Dork...or my first flight of the New year! 12:23 am kepople Parkflyers 14 Jan 01, 2003 09:59 PM
Pibros Twinn EDF-50 "My first EDF project" Appie Electric Ducted Fan Jet Talk 13 Oct 25, 2002 04:57 PM
Got my first EDF - T33 Wantab Electric Ducted Fan Jet Talk 8 Feb 02, 2002 10:15 PM
My First EDF Which one... kepople Electric Ducted Fan Jet Talk 8 Jun 30, 2001 01:43 AM
