Old Dec 19, 2004, 07:34 PM
Mr. Boogie is offline
Find More Posts by Mr. Boogie
Mr. Boogie's Avatar
Morristown, New Jersey (excl EWR), United States
Joined Oct 2003
AirX and Wayno-san,
Thanks for the encouragement. I've been watching the nano thread with great interest! Lots of good ideas and tips there.
P.Richards,
Could you please elaborate a bit more about the pitch down from root to tip? Could this be responsible for the side to side rolls?
I'm currently using full flying horizontal stabs, with about an inch of throw for pitch.
Mr. B
Mr. Boogie is offline Find More Posts by Mr. Boogie
Old Dec 19, 2004, 07:59 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Congrats Mr. B and welcome to EDF.
The side to side roll/banking is a sort of stall trait. My F-35 does it too, I use it too let me know that I'm about to stall, i.e. don't give it any more 'up' input.
Enjoy
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 20, 2004, 08:33 AM
Mr. Boogie's Avatar
Joined Oct 2003
Enjoy
Thanks for the welcome Kevin!
Your projects have been a great source of inspiration to me.
Also thanks for the tip on the side to side rolling. It was the first time I had experienced anything like this.
Mr. B
Old Dec 20, 2004, 01:18 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Congrats Mr B! Now you can start getting aquainted with your new creation. Looking forward to seeing it in the air!
Originally Posted by Mr. Boogie
T ... I hate maidens, and I love maidens!
Boogie
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Dec 21, 2004, 02:10 PM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
Congrats on the maiden glad everthing went well for you!!
RCParkflyer is offline Find More Posts by RCParkflyer
Old Dec 21, 2004, 05:24 PM
Mr. Boogie's Avatar
Joined Oct 2003
I got another flight in today, 30 degree weather makes for some interesting flying.
I moved the cg forward about 1/8 of an inch and she still flies slightly nose up at full throttle. I did not need any up/down trim and speed seemed a little faster. There was a slight breeze so this may be responsible for climb under power.
Tried some WOT rolls and almost plowed her in, so I reduced the roll throws from 1 inch to 3/4 inch. I don't quite have a 1:1 T/W ratio but loops are nice, big and round. Threw in a few split esses (sp) the wings did not flex.
Flew for 8 minutes and then I found myself losing concentration, so I brought her in. 3 passes later I had a nice sliding touchdown in the grass, still trying to adjust to the glide .
434mah put back into the battery on a recharge.
I hope to have plans up shortly for anyone interested in having a go.
Mr. Boogie
Old Dec 21, 2004, 05:34 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Hi Mr. Boogie
Nice plane you have there, congratulations!
You are using a microfan and a astro motor (9,5oz of thrust, as I read before), did you measure power consumption and maximum rpm?
I concluded today my microfan/cdr setup but I'm not satisfied with maximum thrust obtained, only 169g without lip at 10A.
what you think about this numbers?
TIA
Jorge
jalves is offline Find More Posts by jalves
Old Dec 21, 2004, 05:51 PM
Joined Nov 2003
Mr Boogies F-35 PDF Plans
I've Hosted Mr. Boogies F-35 Plans for your downloading and building enjoyment
Old Dec 21, 2004, 06:14 PM
Mr. Boogie's Avatar
Joined Oct 2003
Originally Posted by jmralves
Hi Mr. Boogie
TIA
Jorge
Thanks Jorge!
I am unable to measure rpm, but I did measure amp draw. I get 9.6A and 9.5oz (269g) of thrust at full throttle using a 11.1V 3 cell Lipo battery.
169g at 10A sounds a bit anemic (but I am no EDF expert).
What battery are you using and do you know the voltage your system draws? Also can you provide a little more info about your cdr motor?
You should also check the nano thread, I've noticed a few cdr's being used there.
Mr. B
Old Dec 21, 2004, 06:22 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Mr. B and JMRalves,
The amps will drop and the thrust will go up with a lip of just about any kind, when the airhist the mouth of the fan without a lip it is starving the fan at high throttle because the air cannot curve arround the thin(1mm) lip of the shroud, it just wants to continue to flow past therefor starving the rotor for airflow and running the amp draw up. My Microfan installed in the S-54 was starving the a little bit less than his due ot the ducting and the external lips on each side to help airflow at zero airspeed. With you lip on it it is very near your experience of 9oz and 11amps (running a Himax 2015-5400 on 3s-10.8 volts) and 120 amps. Sweet... it is now going into an F-18E that I drew up. Almost 1-1 thrust/weight.
Eric B.
BTW I will be building one of the F-35's from your plan...
AirX is offline Find More Posts by AirX
Old Dec 21, 2004, 06:25 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Hi again,
numbers:
169g thrust (to be confirmed tomorrow), 10.37A, 9.51V, 37300RPM, 3s2P 1200mA ETec 1stg gen
cdr 20mm, 8T 0,6mm Wye, 12 4x5x1 magnets 6poles (NNSSNNSS...).
I'm one of the people who use cdrom and EDF in nano thread
trade GWS EDF40 for microfan to improve thrust, in fact, thrust improve but not enough
Jorge
PS already have the plans, thanks!
Old Dec 21, 2004, 06:26 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Hi Eric!
Old Dec 21, 2004, 06:28 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Jorge,
Unfortunately the standard motors are working best in this fan an in the EDF 40, The Himax runs about $50us here in the States, you might think of going conventional for this.
Eric B.
Hi again,
numbers:
Jorge
Old Dec 21, 2004, 06:32 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Will install the lip tomorrow, if I don't get 250g, I quit! start a new hobby!
just joking
Eric did you measure RPM in your microfan with you r setup?
Jorge
Old Dec 21, 2004, 06:44 PM
Mr. Boogie's Avatar
Joined Oct 2003
Thanks for the help in getting the plans up RC!
Mr. B
Pics of my first EDF F5 Tiger 11 RCKing Electric Ducted Fan Jet Talk 5 Dec 30, 2003 12:57 PM
I am a Dork...or my first flight of the New year! 12:23 am kepople Parkflyers 14 Jan 01, 2003 09:59 PM
Pibros Twinn EDF-50 "My first EDF project" Appie Electric Ducted Fan Jet Talk 13 Oct 25, 2002 04:57 PM
Got my first EDF - T33 Wantab Electric Ducted Fan Jet Talk 8 Feb 02, 2002 10:15 PM
My First EDF Which one... kepople Electric Ducted Fan Jet Talk 8 Jun 30, 2001 01:43 AM
