Old Nov 23, 2004, 07:01 PM
Mr. Boogie is offline
Find More Posts by Mr. Boogie
Mr. Boogie's Avatar
Morristown, New Jersey (excl EWR), United States
Joined Oct 2003
Depron JSF F35 :or my first EDF
I now feel like I'm far enough along to show my current project. This build is inspired by great work demonstrated by my fellow ezoners. I can only hope to one day be as good as they are .
and...
By the desire to try my hand at an EDF model. If this doesn't work I can always buy a FS F16 to learn on .
Materials:
I'm using 3mm Depron and Blucore (It's still a foamie after all!)
Some 1/16 lite ply.
Foamsafe CA
5 min epoxy
1/8" carbon tube, and slightly larger aluminum tube
I used Rhino and 3 views to generate a planform based on the F35 C model.
3mm depron is used for most of the plane, Blucore FFF used for some formers and motor mount.
Stats:
Wemotec Microfan/Astro 010 combo.
3S TP 1320 Lipo
21 inch wingspan. Full (semi-symetrical) airfoil.
Estimated AUW is 10 - 11 ounces ready to fly.
With the top off, holding the plane 3 inches above my digital scale I see 10oz static thrust. I expect this to decrease when I close the top up, but it looks promising.
Edit: Plans are here
Edit: Video here
Many thanks to Rcparkflyer for hosting.
Mr. Boogie
Mr. Boogie is offline Find More Posts by Mr. Boogie
Old Nov 23, 2004, 07:04 PM
Tomcat Fan is offline
Find More Posts by Tomcat Fan
NY, NY
Joined Jul 2004
Looks pretty sweet.
Glad to see you went with such a basic, conservative design for your first scratchbuild.
We call that sarcasm.
Pretty sweet looking plane, though.
Good luck with it.
Tomcat Fan is offline Find More Posts by Tomcat Fan
Mr. Boogie's Avatar
Joined Oct 2003
Controls will be full flying tailerons motivated by 2 JR 241 servo's.
Old Nov 23, 2004, 07:13 PM
Mr. Boogie's Avatar
Joined Oct 2003
I'm using a semi ducted setup:
I've got a duct with a vacuum formed intake lip midway into the fuse.
The duct intake lip has a 5mm radius.
The intake tube is heavy photo paper and the efflux cone is cut transparency sheet.
Lining the walls of the fuse and also acting as structural supports for the top fuse is a funnel of sorts. Time will tell if this setup works, but it allowed me to quickly and painlessly duct this plane.
Pic One is the vacformed intake ring
Pic Two is the thrust cone
Pic Three shows the psuedo ducting
Old Nov 23, 2004, 07:20 PM
Mr. Boogie's Avatar
Joined Oct 2003
Thanks Tomcat,
It's actually not my first scratchbuild, just my first EDF bird. I've done a few pusher jets and a couple of warbirds.
I forgot to mention that the fuse and wings are folded single sheets of depron, I am trying to minimize adhesive use and hopefully keep my weight down.
The wing tubes slide into the center former, which is a depron/ply sandwich.
Old Nov 23, 2004, 07:27 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Nice work Mr. Boogie..
Eric Barnett
AirX is offline Find More Posts by AirX
Old Nov 23, 2004, 08:34 PM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
Fantistic craftmanship......good luck on the maiden
Ralph
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old Nov 23, 2004, 08:54 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
Mr Boogie,
You must be bursting at the seams Very nice indeed.
The wing section is very cool, the semi-symetrical root section transforms to a symectrical section effectively creating a mild amount of washout. Should work very well. If you meet your 10-12auw target you'll have a big winner!
I'm working on a slightly larger mini480 thing
Bob.
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Nov 24, 2004, 07:55 AM
Mr. Boogie's Avatar
Joined Oct 2003
Thanks AirX, Ralph, and RCjetpilot,
I'll be tossing her about trying to find the CG, and would like to maiden this weekend weather and family permitting.
Mr. B
Old Nov 24, 2004, 08:03 AM
Mr. Boogie's Avatar
Joined Oct 2003
Originally Posted by rcjetpilot
Mr Boogie,
Bob.
Rcjetpilot,
That slightly larger mini480 thing, wouldn't happen to be a F35 or F22 would it?
I followed your F22 build and even though you shelved it thought the thread and craftsmanship were top notch.
Mr. Boogie
Old Nov 24, 2004, 09:12 AM
Stefan lamers is offline
Find More Posts by Stefan lamers
Groningen, The Netherlands
Joined Aug 2004
Hi mr boogie
Looks very nice, i'm very curious how your first EDF will perform. Sofar i have only built propellor planes but i would like to make the step too.
greetings
stefan
Stefan lamers is offline Find More Posts by Stefan lamers
Old Nov 24, 2004, 10:01 AM
NY, NY
Joined Jul 2004
This is just looking truly beautiful, Boogie.
Old Nov 24, 2004, 12:24 PM
Joined Sep 2003
Mr Boogie,
The pictures are from a F-2 "Super Falcon" which survived one flight due to rx glitching. I knew better then to fly but.... Lesson learned. AUW 43 ozs and had 245sqr wing area. Wing loading was quite good with 12 faups but I never did get a chance to see how foam holds up when landing normally
I'm conviced that fff is good build material but only up to a AUW weight of 30oz. And I'm equally convinced that my raptor will only last for few flights simply from the weight of 12 FAUPS. So I shelved it until a time when I'm bored
So the mini480 thing is a smaller sport version of the original F-2. As soon as I finish up my remodeling work-build room its first on list.
http://www.rcgroups.com/forums/showthread.php?t=298399
I'm really looking forward to watching your project.
Bob.
Old Nov 26, 2004, 08:34 PM
Mr. Boogie's Avatar
Joined Oct 2003
Originally Posted by Stefan lamers
Hi mr boogie
greetings
stefan
Believe me Stefan, I am more curious than anyone right now concerning the "flyability" of this plane. It should be a great learning experience one way or the other.
Mr. Boogie
Old Nov 26, 2004, 08:47 PM
Mr. Boogie's Avatar
Joined Oct 2003
Tomcat,
Thanks again, where in NY do you fly? I grew up in Brooklyn, NY but now call NJ my second home.
RcJetpilot,
I wish my garage was as neat as your's now is, my garage and dining room are overun with plane related items.
Update
Hope everyone enjoyed thier Turkey Day, I didn't get much done except for closing up the top of the F35. My templates were a little oversized and needed to be trimmed (no big deal).
My AUW as measured by my trusty digital scale is 10.5oz. With the top open and the thrust/efflux cone attached, I measured 10.2oz of static thrust. Sealing the top and measuring thrust in the same manner, I see 9.5oz of static thrust (we don't need no stinking cheater holes! ). This should be more than enough to get/stay airborn, I'm still trying to determine a good conservative CG point and initial control throws.
Mr. Boogie
Pics of my first EDF F5 Tiger 11 RCKing Electric Ducted Fan Jet Talk 5 Dec 30, 2003 12:57 PM
I am a Dork...or my first flight of the New year! 12:23 am kepople Parkflyers 14 Jan 01, 2003 09:59 PM
Pibros Twinn EDF-50 "My first EDF project" Appie Electric Ducted Fan Jet Talk 13 Oct 25, 2002 04:57 PM
Got my first EDF - T33 Wantab Electric Ducted Fan Jet Talk 8 Feb 02, 2002 10:15 PM
My First EDF Which one... kepople Electric Ducted Fan Jet Talk 8 Jun 30, 2001 01:43 AM
