Old Nov 23, 2004, 05:28 PM
mohammad_sa39 is offline
Find More Posts by mohammad_sa39
Joined May 2004
ducted fan pitch?
hi friends.
i heard that the ducted fan or any thing such as them can provides a LESS pitch and torque than common props we are using for palanes,is it correct? if yes so why? i saw some of them mounted on the hover crafts and r/c wings but i dont know why?
thanks for any input ,Mohammad
mohammad_sa39 is offline Find More Posts by mohammad_sa39
Old Nov 23, 2004, 06:22 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Well, ducted fan impellers need to be at a much lower pitch (typically 1630x3, 2030x3, 2030x5) than most aircraft props because they run at such high rpm.
They provide lower thrust (for the amount of power put in) than large slow revving aircraft props, because they are very inefficient. Electric motors like to run fast (30,000-50,000rpm), but props are most efficient when they are large and run slowly - hence the need for gearing (a 12x8 prop, on say, 6.6:1 running at 5000rpm - on 10A that will provide 10x the thrust of a 50,000rpm ducted fan or tiny direct drive prop spinning at 20,000rpm but using the same current).
Impellers and tiny DD props are basically boring holes in the sky - but if one needs speed or scale looks - then use a ducted fan or DD!
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 23, 2004, 06:51 PM
Joined May 2004
thanks my friend Phil
but really i couldnt understand you
do you can talk another kind!?
thanks,Mohammad
Old Nov 24, 2004, 09:50 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
These are all very interesting generalizations aplying mostly to GWS products. Fans are not ineffiicent. Static thrust alone is not an indicator of efficiency. Fan pitch is just a fan variable. Highly loaded fans will have much more "pitch" than most props.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Nov 24, 2004, 10:13 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Greg
One of the biggest problems which I keep seeing on these threads is that everyone wants to be a critic,myself included.
If someone makes an attempt to provide a simple answer to a complex question then someone desides to debate the issue then the issue becomes more cloudy for the thread starter. This is especially true when ther is a language barrier to start with.
Yes fan units can have high pitched blades however most of the ones used in small electrics are low pitched designed to operate in the 30,000 plus rpm range for speed not thrust.
Many of the models which use such fan unit have to be launched with a device which provides 20 mph plus air speed. The reason is simple air speed equals lift produced by wings.Ever wonder why aircraft carries have that big steam driven cylinder that they hook to jet aircraft to launch?
Charles
Old Nov 24, 2004, 10:53 AM
umrk is offline
Find More Posts by umrk
umrk's Avatar
Paducah Barkley, Kentucky, United States
Joined Sep 2003
It also comes with people asking general questions and others answering with spacific examples. myself included. See attached pic of a EDF55 impeller, in this case its high pitched, roughly 45degrees at the base mount of the blade which is 55mm diameter and driven by a 350 class motor.
I've been under the impression, which could be wrong... that ducted fan impellers were typically higher pitched and get their high RPM from the small diameter, just as we do with small diameter props. IOW, DFs are designed for speed which sacrifices thrust. The duct is there to focus the thrust and improve efficency, same as a Kort nozzle on the wheel (prop) of larger boats. http://www.fairplay-tugs.com/main/fa...aq=Kort+Nozzle
Of Course that will depend on the fan diameter and the motor used to drive it. A smaller motor for the same fan will require a lower pitch to get the high RPMs, and vice versa.
mike
umrk is offline Find More Posts by umrk
Old Nov 24, 2004, 11:05 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Sure but if you like to answer questions because you can type rather than providing a proper answer that is your choice.
So to answer Mohammad's question. Pitch of a fan is dependent on may factors. It dictates how much torque it takes to turn the rotor. Matching the motor torque to the fan torque is the reason for having different pitches. In general the smaller motors used in GWS edf50 fans make little torque and must have low "pitch". Other fan units may have much greater torque requirement. It depends on which motor and what kind of performance the designer had in mind.
Greg
Old Nov 25, 2004, 10:26 AM
Joined May 2004
thanks all friends for answers,
before i start this thread i wanted to build a small hovercraft, i saw 2 kind of props for this task, one kind was a multi blades fan and other kind was a common 2 blades prop,i was woundered what kind of these props are better for lifting force part.
i couldnt get any idea from your inputs.
i couldnt understand your means about that pitch and torque!? for this job?
Old Nov 25, 2004, 11:09 AM
umrk is offline
umrk's Avatar
Joined Sep 2003
I have no experience with hovercraft... but it seems to me that the design of a ducted fan will give more pressure for lift, the airs speed hitting the ground may also help with the lift. Bottom line is you'll need answers from experienced hovercraft guys.
mike
Automotive Related Ducted Fan Question subarumantoo Electric Plane Talk 20 Apr 05, 2008 05:47 AM
Twin-Ducted Fan WB-57 electricrcflyer Electric Ducted Fan Jet Talk 22 Jul 02, 2006 10:58 AM
Anyone tried a variable pitch propeller in a ducted fan Mat Power Systems 7 Jul 10, 2005 01:06 AM
good first ducted fan Paul Penney Electric Ducted Fan Jet Talk 7 Jun 30, 2001 10:39 AM
my ducted fan model bruce ryan Electric Ducted Fan Jet Talk 16 May 21, 2001 07:57 PM
