Old Jan 02, 2005, 10:57 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
I'll be building some new stabs for the new one. I have these covered and I don't like the way they cameout. I have done some further study and Chuck is correct. I need to have the stab pivot a bit more forward in the stabs. Where I have the pivot mounted in the fin, this won't be a problem. I usually build pretty fast so this will be just a bump in the perverbial road.
No plans available for these stabs, yet. I'll get the bug exterminated and see about the rest.
Jack
schrederman is offline Find More Posts by schrederman
Old Jan 03, 2005, 01:49 PM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
Hey Jack,
I have a Compulsion fuse coming back together after a hard learned lesson. Do you think it would match nicely with a set of Hawk wings?
Dan in Dallas ...
Hostage-46 is offline Find More Posts by Hostage-46
Old Jan 03, 2005, 02:31 PM
Joined Nov 2002
Dan,
I think you'd be fine with a compulsion fuse. The wing roots probably wouldn't match exactly but that won't make much difference. The moments are 16" tip of nose to center of main joiner; center of Joiner to center of stab axle pin is 32". Decalage is 1 to 1.5 degrees.
Jack
Old Jan 03, 2005, 03:36 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Good deal, I'll have a closer look with a ruler. What is the cord at the root?
Old Jan 03, 2005, 03:38 PM
Joined Nov 2002
Root chord is 9.75"
JW
Old Jan 03, 2005, 09:49 PM
Joined Nov 2002
Dan,
Anywhere close to that and you'll be OK. I wouldn't want to go too much beyond or shorter on the tail moment. The nose moment is important, but not as important as the tail moment. I'll be on Cowtown on the 11th of you want to meet and copy my plans. The short kit's available from LaserArtCo.com if you want a set of wings and so on, that's the way to go.
Jack Womack
Old Jan 04, 2005, 03:28 AM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Excellent,
I'll drop you a PM to set up a meet.
Dan
Old Jan 07, 2005, 12:16 AM
gdjsky01 is offline
Find More Posts by gdjsky01
Jeff
USA, CA, Redondo Beach
Joined Aug 2003
Jack
I am ordering the 1/2 inch rod from Don at hilaunch. The angle is 7 degrees right? And when you say sand relief you mean wrap some sand paper around the rass tubing and sand a rounded channel in the center of the ply spar boxes yes?
Best wishes
Jeff
gdjsky01 is offline Find More Posts by gdjsky01
Old Jan 07, 2005, 01:36 PM
Joined Nov 2002
Yes, that's correct. Be sure to do both webs so the center of the joiner stays in the center of the spar.
JW
PPP (proud Pik pilot)
Old Jan 07, 2005, 01:50 PM
ejett is online now
Find More Posts by ejett
TLAR Black Belt
ejett's Avatar
Athens, LA, United States
Joined Apr 2002
You flown it already then I guess? (The Pik)
EJ
ejett is online now Find More Posts by ejett
Old Jan 07, 2005, 01:59 PM
Mauilvr is offline
Find More Posts by Mauilvr
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
Jack,
Stop teasing us - show us a pic of the Pik!
(as the moderator takes the thread completely off topic )
Mauilvr is offline Find More Posts by Mauilvr
Old Jan 07, 2005, 08:15 PM
Joined Nov 2002
Tomorrow.......Jack
Old Jan 07, 2005, 08:29 PM
gdjsky01 is offline
Jeff
Joined Aug 2003
JW
Hilaunch is out of the joiners until end of Jan. So... do I wait? Build the midsections and tips while waiting? Build the horizontal stab as shown on the plan and forget the new stab plans? Or to heck with it and use the 7/16th joiner that came with it? Or get started on the Mirage and wait?
Advice?
Jeff
Old Jan 07, 2005, 08:38 PM
ejett is online now
TLAR Black Belt
ejett's Avatar
Joined Apr 2002
Jeff:
Use the 7/16 joiner with some 7/16" ID tubing on it until the 1/2" joiner is available. Glue it to the 7/16" rod and use it as if it were the 1/2" rod.
Regarding the stabs, I'll defer to Jack on that one.
EJ
Old Jan 07, 2005, 08:40 PM
Joined Nov 2002
Mirage Shmirage! Go ahead and sand the channel out and build the wings. You need only the 17/32 receiver tube to build the wing. The tube is inserted into the wing center sections without being cut, so the jonier isn't needed for alignment. Just be sure the channel is opened enough not to cause any binding. I like about 1/32 out of the middle of each, so the tube fits loosely enough to get epoxy all around it.
Enjoy...
Jack
Discussion Winter Project, newest Houston Hawk erichj Sailplane Talk 15 May 06, 2007 04:49 AM
The Houston Hawk Project schrederman Thermal 1004 Nov 23, 2004 02:01 AM
Schreiner F-18 Project - Part #2 TedLarson Electric Ducted Fan Jet Talk 115 Feb 22, 2003 01:52 PM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 02:00 AM
