Old Nov 22, 2004, 04:23 PM
Shroomer is offline
Find More Posts by Shroomer
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
Need some help identifing retracts and more
can some one identify the retracts I have pictured here ? and also is this SuperTigre G21 .46 worth repairing ? it has great compression and feals really snug...
Shroomer is offline Find More Posts by Shroomer
Old Nov 23, 2004, 07:39 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
If you can get a carb or yours is still good the crankcase part can be replaced by using Devcon aluminum putty. It can be filed and/or machined after it hardens.
GregG is offline Find More Posts by GregG
Old Nov 23, 2004, 10:05 AM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
That would hold up to the tightening of the carb retention bolt... Sorry if that is not what it is called still gettin use to the termanalogy lol.
Anyone else on the retracts ?
Old Nov 24, 2004, 05:46 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Yes it will hold up. I've seen intake manifolds made of Devcon aluminum putty on go-kart racing engines. They were formed, machined, drilled, and then tapped. I used it on the forward side of my boat outdrive. It was formed into a sharpened cone of sort that allowed the boat to attain 2 mph more in top speed. I accidentally scraped it hard on the pavement at a launch ramp one time. It acted as if it was made of the same metal the the outdrive case was made, just a small bend in the tip.
Old Nov 24, 2004, 07:03 AM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
Any idea where to get that ? and would the engine have to be fully disasymbled ro do this ?
Old Nov 25, 2004, 05:48 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
I just did a Google Search for "Devcon Aluminum Putty" and came up with quite a few places that sell it.
I was at our airfield yesterday and saw a damaged engine that was fixed with JB Weld. He had broken off one of the muffler bolt thing-a-ma-bobs and had molded a new one from JB Weld. It was drilled and tapped to hold on the mufler. It seemed to be holding up well.
Old Nov 25, 2004, 05:59 AM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
Thanks for all the help on the Super Tigre now i jsut hope someone will ring in on the retracts lol
Old Nov 26, 2004, 01:11 PM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
no one has a clue on the retracts ? is there a better place to ask about them ?
Old Nov 26, 2004, 09:01 PM
flyathome is offline
Find More Posts by flyathome
United States, OK, Edmond
Joined May 2003
The green retracts are Supras made by OK Models. The red ones are made by MK. Both are made in Japan. The Supras are probably for 60 size planes. The MKs are for 20-30 size. Both of them are pretty good units.
Steve
flyathome is offline Find More Posts by flyathome
Old Nov 26, 2004, 09:48 PM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
nice thanks for the info....
is there a nice War bird i could fit the red ones on ? P-39 maybe ? link if posiable
and the green ones should work on any 40 to 60 warbid tail dragger right ?
these are manual right ? not air comression setups ?
Old Nov 26, 2004, 10:50 PM
Joined May 2003
The red, MK, retracts should work on any plane in the 20-30 size range. Yes, the green, Supra, units should be satisfactory for a 40 - 60 size war bird. They are both mechanical. They work best with a retract type servo, that rotates 180 degrees.
I hope this helps.
Steve
Old Nov 26, 2004, 10:56 PM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
great verification on what i thought... not to take away from anyone's post but I am still new to this and just figured as much but still needed varification...
Old Nov 26, 2004, 10:58 PM
Shroomer is offline
Shroomer's Avatar
Springfield, IL
Joined Jun 2004
i was thinking a cesna for he red ones but the direction of the wing gears is the problem to me what is the best for the red ones ?
Help! Need some help identifing a 4S engine. sneasle Engines 5 Apr 30, 2007 09:04 PM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
A-10 glitching issue...need some help!!! David Hogue Electric Ducted Fan Jet Talk 5 Aug 07, 2001 09:51 PM
Upgraded Zagi 400X.....now I need some help. futurvet Foamies (Kits) 1 Jun 06, 2001 09:19 PM
need some help finishing my mini ifo. Jeremy_D Parkflyers 4 May 28, 2001 05:49 PM
