Old Nov 20, 2004, 03:17 PM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
Simple F-22 Raptor EDF
I am about to finish a simple Raptor foamie. It is based on the plan of Guy Perez . As the original was a propjet, it needed some modifications, because the EDF requires much thicker fuselage etc.
Data:
Wingspan: 50 cm (the biggest foam sheet I have...)
Weight: 350g
EDF: 60 mm, Alfa (the edf of the famous Alfa MIG15)
Motor: MPJet 25/25-26
Akku: Etec 1200HD or PolyQuest 1500 LiPo
Thrust: 240g
mmormota is offline Find More Posts by mmormota
Old Nov 20, 2004, 03:22 PM
RcAroPlanes is offline
Find More Posts by RcAroPlanes
Joined Sep 2004
oh man that is cool!! I wish I had time and skills to build lol.
RcAroPlanes is offline Find More Posts by RcAroPlanes
Old Nov 20, 2004, 03:24 PM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
Nice subject It would look a bit better if you could get rid of that bend line "point" over the motor. Can you show us more pictures the the Ducting?
RCParkflyer is offline Find More Posts by RCParkflyer
Old Nov 20, 2004, 03:53 PM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
Sure. The intake side is just the rectangular bottom of the fuselage. As the top of the duct is above the sheet of the wing, I glued a foam cone to the triangle (see my 2nd picture in the first message).
The output duct is just a bended foam tube, with a little cone.
The edf unit is removable, fixed by 3 screws.
All of the electronics are in the tail side, easy to service them, no need for service holes in the fuselage.
The LiPo is in the nose, its weight (104g) is enough to set the proper balance. (the center of gravity according to the original plan).
Old Nov 20, 2004, 07:09 PM
Willmsy is offline
Find More Posts by Willmsy
I am the BBQ Ninja
Willmsy's Avatar
United States, MN, Woodbury
Joined Jan 2003
Cool!
Willmsy is offline Find More Posts by Willmsy
Old Nov 20, 2004, 08:28 PM
hawaiianspork226 is offline
Find More Posts by hawaiianspork226
hawaiianspork226's Avatar
Orlando Int, Florida, United States
i agree, very cool!
i think it looks more like an F-35 though! still cool!
-David
hawaiianspork226 is offline Find More Posts by hawaiianspork226
Old Nov 20, 2004, 10:45 PM
hummingbird111 is offline
Find More Posts by hummingbird111
what wing man??
hummingbird111's Avatar
Nashville Tennessee
Joined Jul 2003
F-22
Very nice ,, let us know how it goes,, maiden?,,flight stabilities?,, work out the bugs?,,
hummingbird111 is offline Find More Posts by hummingbird111
Old Nov 21, 2004, 11:23 AM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
Maiden
The maiden was today.
The weather was rather windy, almost storm. Just before sunset it improved a bit, so I went to the airport. Unfortunately I was alone, no other pilots take the risk...
Ok, at least easy to handlaunch it in the wind... Full throttle, start.
First impressions:
- I have to glue sometghing to the fuselage, because the trapezoid slips, not easy to hold the plane.
- up trim is necessary, about 3 degree, maybe better to move the center of gravity backwards?
- too sensitive to the aileron (surprised me, as no ailerons just elevons), after -60% expo it is perfect
After trimming, the 2. and 3. flight was very pleasant. Easy handlaunch, just a toss and it is flying. Very stable, even in the wind. Level flight at about 50% throttle. No bad habits. Best of all, it is just not stalling. If I pulled the elevator too hard and it lost speed, it stabilized at a high angle. Just dropped some altitude, but followed the stick. Pulling (or pushing?) out no problem with higher throttle. It makes the landing really easy - thottle down, glide near to the grass, pull step by step the elevator, finally it sits down at almost zero speed.
After sunset it was hard to follow the plane. It is small, rather strange shape, and all white. (I decided to check first if it is flying - if not, why waste my time with painting... ) So I didnt take the risk of trick-flying, just enjoyed the flight.
After the flights I recognised that the wind just not disturbed me at all, the plane was very stable, and the speed was well above the wind speed.
Old Nov 21, 2004, 12:27 PM
Iswald is offline
Find More Posts by Iswald
FLY FREE!!!!!!
South Africa
Joined Sep 2004
Congrats!!!
Looks very cool, how r u gonna paint it??
Iswald is offline Find More Posts by Iswald
Old Nov 21, 2004, 12:32 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Congrats..
Eric B.
AirX is offline Find More Posts by AirX
Old Nov 21, 2004, 02:02 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Good job! How's about posting some plans or templates for it?
Justin
roccobro is offline Find More Posts by roccobro
Old Nov 21, 2004, 04:09 PM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
Justin
I have no real plans, however I collected together some drawings and construction photos to a pdf file. The plane is rather simple, hope it is enough for building a similar beast... The templates are in OpenOffice drawing format, I attach them too if you need them. Enjoy.
Raptor plans
Old Nov 21, 2004, 05:04 PM
Terryoc is offline
Find More Posts by Terryoc
Melbourne Australia
Joined May 2003
Great job I am about to start the same plane today ,it would have been sooner but I spent 2 days in autocad try to tile Guy Perez's original plane he put up .I finnally got the plane all printed and joined up late last night and building today .
Mine will be for mini fan as that is what I have .
Good one mmormota
Terry
Terryoc is offline Find More Posts by Terryoc
Old Nov 22, 2004, 02:09 AM
Rudi is offline
Find More Posts by Rudi
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
Raptor plans
Thank you very much for this wonderful plan !!
Greetings from vienna
Rudi
Rudi is offline Find More Posts by Rudi
Old Nov 22, 2004, 02:47 AM
what wing man??
Nashville Tennessee
Joined Jul 2003
maiden
Congrats' on the maiden,,,nice plans ,, think i'll try it out
F-22 Raptor gregM Sport Planes 3 Nov 22, 2008 11:28 AM
Discussion Wattage F-22 Raptor Edf latinflyer Foamy EDFs 1 Aug 14, 2007 03:35 PM
Video Twin EDF-40 F-22 Raptor 3D Devil Electric Plane Talk 0 Feb 27, 2006 07:22 AM
Spotted a new F-22 Raptor EDF kit in UK-- anyone know about this? EpowerFan Electric Ducted Fan Jet Talk 7 Nov 16, 2005 01:41 AM
wattage f-22 raptor- anybody flying it? ghoward79 Electric Ducted Fan Jet Talk 7 Dec 26, 2001 10:57 PM
