Old Nov 19, 2004, 08:23 AM
AstroNut is online now
Find More Posts by AstroNut
United States, FL, Cutler Bay
Joined Sep 2001
Power Supply for Power System Bench Testing
Hi, Everyone!
This is just FYI.
Recently I purchased a Himax 2025-4266 motor/gearbox combo for my Yard Bee. The pack Iím using is a Kokam 2s1p 1500 lipo pack. My prop/gearing selections were based on a motor chart found on parkflyermotors.com, I found that the chartís numbers did not match reality. In some instances the amp draw differed enough that it exceed the rating of the pack. Needless to say that this proved to be a bit of a hazard for the lipo pack. This brought me to the conclusion that there has to be a better way to test known and unknown parameters without having to worry about the following:
∑ Amps exceeding pack rating.
∑ Having a consistent voltage throughout your testing.
∑ The right size pack at hand.
What I found was a regulated variable voltage (6 to 15 volts) power supply capable of 22 amps continual and 25 amps surge by Pyramid (I have their 12volt/14amp unit that Iíve used with no problems for over three years). Its has both (analog) volt and amp meters. I purchased the unit at etronics.com for 79.99 plus shipping. I received it last night and immediately gave a try. Let me tell you, this unit is AWESOME! You can easily control the voltage to tenth of a volt. Just plug your Watt Meter to it and you're ready to go.
http://www.etronics.com/product.asp?...re=&catid=4071
I just wanted to share this find with those who have similar situations/issues.
All the best and happy flying.
Angelo
AstroNut is online now Find More Posts by AstroNut
Old Nov 19, 2004, 01:37 PM
Joined Sep 2001
Here's a photo of the unit.
Old Nov 19, 2004, 02:19 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Sounds like a good deal - I bought one of these and it seems pretty good - I guess it should be at the price!
http://www.allelectronics.com/cgi-bi...512&type=store
How does yours cope with voltage drop with increasing amp load? - I set mine at, say, 11v and it drops to 10.8v at ~5A, and as low as 10.3v at ~22A. Obviously one can adjust back up to the nominal 11v, but that's a pain in the a... while one is running a test! - how many hands does one have?
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 19, 2004, 02:45 PM
Joined Sep 2001
Phil,
My voltage drops is about .3 volts @ ~15 amps.
All the best.
Angelo
Old Nov 20, 2004, 09:46 AM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Phil, is that at the motor or the power supply? Power loss in smaller gauge wire can be substantial in a 5 to 6 foot run.
Pete
peterv is offline Find More Posts by peterv
Old Nov 20, 2004, 09:58 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
That's at the Medusa Analyzer - two banana plugs, one foot of 16ga wire and a Deans Ultra connector away from the power supply. I naively thought that a Power Supply like this could be set on, say 11.0v at no-load, and maintain EXACTLY that no matter how many amps I pulled from it. Is this voltage drop an inevitable characteristic? or should the PS do better than this? An e-mail to the supplier asking this question ellicited no response.
Cheers, Phil
Old Nov 20, 2004, 10:10 AM
rmteo is offline
Find More Posts by rmteo
User
Colorado
Phil,
All PS will sag under load. The parameter that matters is the load regulation. I use this PS:
http://www.xantrex.com/web/id/80/p/3...19/product.asp
It's load regulation is:
Load Regulation:
Voltage (0.02% of Vmax + 5 mV) 13 mV
Current (0.02% of Imax + 5 mA) 11 mA
In order words, the voltage will not deviate by more than 0.013V no matter how much current is drawn (up to a mx. of 30A). However, this PS sells for about $2,800. Less expensive hobbyist PS generally have much poorer performance in this regard (they will typically drop about 0.1V for each Amp).
As with everything in life, squeezing the last 5% of performance out of a product accounts for 95% of its cost (think LittleScreamers).
Cheers, Phil
rmteo is offline Find More Posts by rmteo
Old Nov 20, 2004, 10:11 AM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
Phil,
I am looking to buy a power supply too,
As I need to run to many tests to use the batts,
By the way, That was your motor that were trying to destroy
Just kidding
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Nov 20, 2004, 10:14 AM
Joined Nov 2003
Rene'
That's not a power supply that's a piece of art!
scott
Old Nov 20, 2004, 11:20 AM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
I have a couple of HP Lab Grade PSs over 30 years old a 0-40v 10 Amp and a 0-20v 50 Amp rack mounts sim specs. Have many other DC supplies, some I built. Have found many of the adjustable high current bench supplies under $200 to be lucky to keep 5% acuracy under a 10 Amp load!
Pete
Old Nov 20, 2004, 11:22 AM
Joined Nov 2003
I am trying to get a nice one with digital readout and 0-18v 29ampsmax
Will make my testing so much easier,
I should have bought one a long time ago
Scott
Old Nov 20, 2004, 11:39 AM
Joined Sep 2001
Hey, Scott,
My Watt Meter is my digital display.
Angelo
Old Nov 20, 2004, 11:59 AM
umrk is offline
Find More Posts by umrk
umrk's Avatar
Paducah Barkley, Kentucky, United States
Joined Sep 2003
I'd search for further specs on that Pryramid PS before ordering it. Yesterday I checked Astron's variable voltage metered supply's specs and was supprised at how much they derated the current as you dropped the voltage (abt -50% of the 13.8v A rating at 10v and went down fast from there), and the Pyramids are a lower quality supply so... ?
Aparently they're limited to what power the heatsink and power transistors can dissapate, and the lower the volts the more that they have to.
In my experience with Astron's which use the LM723 voltage regulator with output voltage sensing at the output terminals (typical for this type supply, and the Pyramids I've seen use the same reg, IC), under heavy loads, 0.1v is a typical drop.
And like AstroNut says, a Whattmeter, or in my case a MR Power Analyzer Plus, is the digital readout.
mike
umrk is offline Find More Posts by umrk
Old Nov 20, 2004, 12:52 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
And as Mike and AstroNut say, in my case, too, a MR Power Analyzer Plus, is the digital readout. [I made extensive enquiries about digital read-out on a PS, and giant $$$ signs were flashed in front of me at every turn - it's actually not very useful since the Analyzer or Whattmeter is what one looks at, not the PS which could be hidden behind a wall for all I care]
My Zurich Power Supply is an excellent machine, don't get me wrong - it is obviously not Rene's "Rolls-Royce" though! Mine says "1% line load regulation" - what exactly should that translate to if I'm setting it at say 10v and 20A load???? Mine seems to drop perhaps 1-2% (0.1-0.2v) for the every 5 amps increase in load.
Cheers, Phil
Old Nov 20, 2004, 01:50 PM
umrk is offline
umrk's Avatar
Joined Sep 2003
How important is tight V regulation?
I mean, the battery packs were going to use in flying sure aren't close to 5% from no load to max load?
With all the variables considered (batteries, props, motors, wires, ESCs... scales, meters, temp, humidity... not being exactly the same), is getting very tight voltage regulation really that important? Won't we still see variations as folks do their own testing, or even as we do our own repeats?
mike
Discussion Power Supply For Bench Testing himszy Submarines 15 Feb 07, 2006 12:02 AM
For Sale Power Supply for charging system Curiousgeorges Aircraft - Electric - Helis (FS/W) 3 Oct 25, 2005 02:04 AM
For Sale FS Power Supply for charging system Curiousgeorges Aircraft - Electric - Airplanes (FS/W) 3 Oct 17, 2005 02:30 PM
FS Power Supply for charging system Curiousgeorges Aircraft - Electric - Airplanes (FS/W) 72 Jun 02, 2005 02:52 PM
Power supply for bench testing Phoenix controllers rakm Castle Creations 5 Mar 10, 2004 10:33 PM
