Old Nov 19, 2004, 12:20 AM
abdulf is offline
Find More Posts by abdulf
Joined Nov 2004
b-29 - rudder control on a 2-channel?
Hi,
I was wondering if I could change a differential thrust plane to one with rudder control.
Basically, the plane would be controlled by thrust and rudder.
I would like to retain original parts and cheap 2-channel radio and use 1 servo. Is this possible if I solder a few things?
abdulf is offline Find More Posts by abdulf
Old Nov 19, 2004, 08:41 AM
die fliedermaus is offline
Find More Posts by die fliedermaus
die fliedermaus's Avatar
Kansas
Joined Jul 2002
If you have one of the B-29s for sale on Ebay, they turn pretty good on just thrust differential.
I don't know if you could convert the thrust differential "channel" to operate an actuater or coil.
You don't want to get acused of flooding, but you might pose the same question in the Indoor Model forum. Some lightweight planes use pretty novel methods for control.
die fliedermaus is offline Find More Posts by die fliedermaus
Old Nov 19, 2004, 03:27 PM
bluesilver30 is offline
Find More Posts by bluesilver30
bluesilver30's Avatar
Rumson, NJ
Joined Dec 2003
i don't know how the electronics are on that plane, but with only differential thrust you have no servo's installed. you may be able to install one into the electronics, but once again i dont know if they will accept a servo.
im going to go ahead and assume no. by the time you got it flying, you would have all new electronics.
bluesilver30 is offline Find More Posts by bluesilver30
Old Nov 19, 2004, 06:01 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
Originally Posted by abdulf
Hi,
Hello, I have the same plane waiting to be converted as well. I don't think you can do the conversion as you described easily. However I do have a set of one-channel rudder only receiver/esc combo with transmitter. I think you can combine the parts to do rudder control easier. If you are interested I can send them to you, you just pay the shipping. PM me if you are interested.
shschon is offline Find More Posts by shschon
Discussion Rudder servo control on (left)throttle stick -vs- rudder control on (right)stick. chewbaca Electric Plane Talk 17 Feb 01, 2006 08:16 PM
Easy Rudder Control on L/R Stering macquen Scratchbuilt Indoor and Micro Models 0 Apr 07, 2005 06:10 PM
Rudder control with a 3 channel airplane mccorml Beginner Training Area (Aircraft-Electric) 9 Dec 18, 2004 04:02 PM
SS Question/Learning on a 2 channel. Ralph_D Parkflyers 8 Sep 24, 2003 02:37 AM
