Old Nov 18, 2004, 04:07 PM
gravitic anomaly is offline
Find More Posts by gravitic anomaly
Freezing my Lipo's off.
gravitic anomaly's Avatar
Princeton,Minnesota USA
Mini Mustang feasibility study
Fiddlersgreen has released a wonderful collection of racing mustangs for the paper folding crowd. The artworkis very well done.
I sure would like to convert one of these little gems to R/C. Here are my calculations.
Let me know if this seems feasible. I am not expecting a "floater".
Airframe 110# card stock fusalage, 67# tail feathers & canopy. single surface underchambered foam or clear acetal wing with printed condenser paper artwork applied.
Weight approx. 24 grams.
Blue arrow reciever 4 grams
Blue arrow servos 2x 8 grams
Blue arrow ESC 6 grams
Motor 7 grams
2 cell Lipo 11 grams
Approximate flying weight 60 grams (2.1 oz)
Wing area extended to approx. 35 in-sq
Wing loading approx 8.2 oz sq-ft
Which motor would be appropriate? Could it fly? Wanna Race?
gravitic anomaly is offline Find More Posts by gravitic anomaly
Old Nov 18, 2004, 05:57 PM
The link http://fiddlersgreen.net/AC/aircraft/North-American-P51-Racers/p-51Racers.htm[/URL]
Old Nov 19, 2004, 03:27 AM
Hooters Driver is offline
Find More Posts by Hooters Driver
Dallas, TX
Joined Jun 2003
That sounds very heavy. I had the same thoughts but using their J-3 Cub. I put the model together and came up with an airframe and motor weight of 5 grams. My hope is to add micro electronics and actuators to get an AUW of about 15 grams. Even at that weight I figured it would be tough to make it fly.
Hooters Driver is offline Find More Posts by Hooters Driver
Old Nov 19, 2004, 02:36 PM
TheDudeVT is offline
Find More Posts by TheDudeVT
Burlington VT
Joined Aug 2003
switch to 3-4mm depron or the core of FoamCore poster board (succesfully used for park flyer size planes- if you go smaller, use smaller depron or wall insulation foam) and use the fiddlers green sheet as a template.
There are lots of people that have done this in the foamies forum. Do a search for fiddlers green. You won't get the sweet paint job though unless you transfer that too- I recommend "PermOpaque" markers for depron- nice light opaque dye, foam-safe, and not as heavy as paint pens.
If you're not into foam, you can transfer them to thin contest balsa if you don't mind steam bending. you can print the FG plan directly to the balsa if you have the right kind of printer with a straight-thru feed.
TheDude
TheDudeVT is offline Find More Posts by TheDudeVT
Old Nov 19, 2004, 02:40 PM
gearup is offline
Find More Posts by gearup
Joined Sep 2003
look for the HE-111 thread ..LARGE paper model converted, looks great, flys nice ( and he has done Corsair and Stuka)
gearup is offline Find More Posts by gearup
Old Nov 21, 2004, 07:42 AM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
I want to scale up the fiddlersgreen cub can this be done at Kinkos or some printing shop like that?
I really would like to print it on some kind of thin plastic transfer film and stick that to .125 depron foam.
sure would make for a cool large park flyer wouldn't it?
Bill
Bilbobaker is offline Find More Posts by Bilbobaker
Old Nov 21, 2004, 08:11 AM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi all,
yes, I've already bought the Mustang plans, too!
Here is my Tri Pacer. I have used 2mm wall foam (styrofoam), covered with printed tissue. The wing and tail are made from 1mm balsa. The model is shown shortly before finishing, but has flown well in the meantime, although I've had problems with the PU04 drive.
I have scaled up the plans using features of my printer driver (HP940C).
weight 17g ready to fly
span 330mm (peanut size)
DIY IR receiver
homemade actuators
PU04 drive
90mAh lipo cell
Regards, Jochen
jberg is offline Find More Posts by jberg
Discussion GWS Mini Mustang N827TM Electric Warbirds 149 Dec 21, 2011 05:30 PM
Wanted Wanted Daw Mini Mustang SkyKing RC Aircraft - Sailplanes (FS/W) 0 Nov 24, 2006 09:56 AM
Discussion Got a new idea and GWS mini mustang. sirdirk007 Slope 13 Oct 14, 2006 01:31 PM
A Mini Mustang From Gws agapornis GWS (Grand Wing Servo) 1 Jan 05, 2005 02:48 AM
Mini Mustang Foamy STRINGFLY Foamies (Kits) 14 Oct 18, 2004 10:02 PM
