Thats a hard question to answer, because it depends on you, your shop area and $$$.
![]() A Mill Drill is a good compromise between a floor model mill and a mini mill. Although it does both functions fine it doesn't need the abuse a drill press gets. I cringe at the thought of doing some of the drilling on a mill that I'd not blink an eye at with a drill press, mainly larger cruder stuff. Chances are you'll end up with a seperate drill press even if you get the mill drill, so if funds are limited get the mill drill first, and the drill press later. Also you'll end up spending several dollars on tooling, cutters, indicators, ect... for your mill and lathe no matter what size you get, so factor that in also. Check this out, a inexpensive Digital Read Out that uses inevpensive Chineese scales/calipers... http://www.shumatech.com Once you have run a mill with a DRO, you'll love it, and never want to go back! It can even do some functions that you'd usually use a rotary table for, like for drilling holes in a round pattern it tells you where to put the next hole. And much easier to get accurate movements with. BTW, my dedicated machine shop area is my kitchen, thats right, I'm single and Can! ![]() mike |
I havent gotten my Sumatech DRO finished and installed yet (and never tried it on my friends mill with that capibility and a different DRO) but as I understand it...
You input the diameter of the pattern, and number of holes, either center up on where you want the pattern or on the first hole, and it tells you where to go for the next one. I think it actually calculates the offset (X,Y) and you move the table to zero for the next one, drill, then the next one... You could calcuate the same thing, BUT a DRO reads off of the table and the backlash in the tables movement is ignored. Unlike reading the scales on the wheels. You could do the same thing with dial indicators and calculating the holes placment yourself. But a DRO is much more handy! ![]() For more info... http://groups.yahoo.com/group/ShumaTech/ These guys can answer more accurately for this DRO. BTW, Scott Shumatech is the brother of Jetset44 on this forum. mike |
Investing in better or more versitale tools/machines is rarely if ever regretted. I hate to see guys buy a drill press and one of those cheap X Y tables thinking they'll end up with a mill. IMHO your better off buying fewer and better, and add as you go.
mike My Enco gearhead mill drill right after getting it inside and bolted back togeather...
Edmonds Wa. (Seattle)
Joined Nov 2003
I think I have used mine maybe 3-4 times since buying it and getting the tooling needed to run it.
Not bad for $399 but if I was to use it every day I would have bought the better one. I also bought a lathe and tooled it up to death and that is my favorite machine at the moment, And now that my new Partner is TS engineering, And is the the maker of the famous QCTP for the mini lathes, I have some more tool holders on there way :"D Thanks Rene Funny thing is that I ordered and received my QCTP before my lathe even showed up. And this was before I had the chance to become friends and partners with Rene. Funny world we live in. Now if we need a part we use these (see pic) Scott PS We make these too (see other pic) |
Man, those look like some expensive sand blast cabinets!
![]() One of these days I hope to make up a CNC lathe and mill, but nowhere in that class. I'm happy for you, sweet, but those won't fit in my kitchen, errr...machine shop. ![]() mike Its nice being single, no one to say" NO, You cant do that!"
Must be nice just having access to those!
One bedroom is my computer room (and ex-hobby shop), another is my Hobby Shop now (used to be her hobby room), and the Kitchen the Machine Shop. I've been wondering if I really need that couch in the Living Room lately. Works for me! ![]() Too many projects and too little time. I've been scrounging parts for a CNC router for a few years. Hope to get a mini mill to convert to CNC one of these days........ It never ends. mike |
| Thread Tools | |
| Data Dualsky vs Neu vs Tp Dischage Graph | 2dogrc | Batteries and Chargers | 10 | Aug 21, 2007 08:58 AM |
| HF drill/mill | ICRSHLTS | The Builders Workshop | 2 | Aug 07, 2003 08:46 AM |
