Old Jun 27, 2006, 01:48 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Jon, you have to count. The "working diameter" (as I called it) is not the outer diameter but the diameter at about (not exactly) half of the height of the teeth. For getting the count of the teeth by measuring the diameter of the gear you need special mathematics or special tables and exact micrometer calipers. In the case of watch gears you also need a loupe. And you might fail anyway because you don't know to which standard the gear is manufactured. A watch gear can easily be based on cycloidic curves or on involute curves, both are difficult to calculate, and you don't know which amount of addendum modification was applied.
At the end of the day counting is the easiest way. The exact dimensions of gears and the shape of the teeth are a complex matter, as you can easily see on that page MegaTesla pointed to.
And, I wrote "(50+10)/2*0.2 = 6mm", you interpreted it as "(50+10)/(2*0.2) = 150", which is, I'm sorry, something different.
Regards, Jochen (mechanical engineer)
jberg is offline Find More Posts by jberg
Old Jun 27, 2006, 04:55 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Jonathon
You can use my gear center calculator to calculate the gear centers and mod.
It is pretty close or close enough for our purposes to use the following formulas
Mod = module = the lenght in mm, of the pitch circle diameter per tooth
PCD = Pitch Circle Diameter
PCD(s) = PCD of spur
PCD(p) = PCD of pinion
C = Center Distance, this is the calculated value of the center to center distance
MA = Mesh Allow Distance, this is how much you want to add to C to allow the gears to run smoothly
Didel recomends 0.02mm for 6.67:1 and lower ratio 0.3mod gears
For the 0.2 module gears the mesh allow distance is 0.01mm
Formulas:
Mod = OD /(N+2)
PCD = N x Mod
C = (PCD(s) + PCD(p)) / 2
http://geocities.com/billy_stiltner/gearboxes.html
There was a problem with the javascript that caused errors in the calculator results on my site but it is fixed now.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Jun 27, 2006, 04:57 PM
jonathan8388 is offline
Find More Posts by jonathan8388
Elmwood Park,NJ, United States
Joined Nov 2004
Wow, thanks Billy. that will make it much easier. For some reason, I didnt see that on your site. thanks though. It kind of sucks that i will have to count the teeth by eye to find the mod. oh well
jonathan8388 is offline Find More Posts by jonathan8388
Old Jun 27, 2006, 05:08 PM
Joined Nov 2002
Jonathon your PM box is full.
Billy
Old Jun 27, 2006, 06:22 PM
rguillot is offline
Find More Posts by rguillot
rguillot's Avatar
Brooklyn NY
Joined Feb 2004
Jon, you have to count the teeth with your naked eye. Using any kind of magnification is cheating
Robert
rguillot is offline Find More Posts by rguillot
Old Jun 27, 2006, 07:25 PM
Joined Nov 2002
It really is cheating just like using your prop instead of carving my own.
Billy
Old Oct 08, 2006, 08:04 PM
Joined Nov 2002
Hey
I looked for the 1/4 bag of watch part soup at clockworks.com and cant find it.
Does anyone know if you can still get a 1/4 lb bag of assorted watch parts?
Billy
Old Oct 08, 2006, 11:37 PM
shoutchen is offline
Find More Posts by shoutchen
mudville
Joined Nov 2002
billy,
try www.scotchwatch.com
for gears, etc.
steveh
shoutchen is offline Find More Posts by shoutchen
Old Oct 09, 2006, 08:33 PM
rguillot is offline
rguillot's Avatar
Brooklyn NY
Joined Feb 2004
great site...no gears???
EDIT: sorry just saw the gears
Old Oct 09, 2006, 09:04 PM
mudville
Joined Nov 2002
they call them
train wheels (spur gears)
, clutch wheels ( crown gear...)
, cannon pinions (pinions...)
Old Oct 10, 2006, 04:07 PM
Joined Nov 2002
Steve
Thanks for the link.
The bulk watch parts are no longer available from clockworks or slarose.
clockworks supplier was slarose and they are out of business it seems.
The phone message at slarose says closded for inventory for 2 weeks.
Robert
Check out page 2 of there bulk items.
They have the ruby bushings 70 for $40.00.
Billy
Discussion Watch gear gearboxes for sale billystiltner Scratchbuilt Indoor and Micro Models 13 Aug 28, 2006 08:22 PM
DIY bit gear gearboxes billystiltner Scratchbuilt Indoor and Micro Models 26 Apr 02, 2004 03:57 AM
