Old Nov 24, 2004, 07:13 AM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Graham
That thread is some very good reading. I read it again and picked up some things I had forgot. I seen I was having trouble with the wire insulation glue then as well. I remember I had good results with Duco and CA later with the wire insulation. I must have some grease or sweat on the insulation now. However I did not find the post that Robert mentioned using the calipers to mark the ply for center distance. I think someone else actually posted the technique and Robert explained to me how to do it.
JMP
I will try to explain in babelfish freindly terms. (I know you know english very well though)
Example: center to center distance is 5.15mm
1. On a sheet of paper draw a line
2. Mark 51.5mm points on line.
3. Set divider close to 5.15mm(use magnifier and caliper)
4. Step out the divider 10 paces on the line to check distance.
5. If too wide - close divider
6. If too narrow - open divider
7. Repeat steps 4 to 6
For more accuracy mark out 515 mm and step the divider 100 times.
Divider may open or close with 100 steps if you are not careful.
Billy
Billy
billystiltner is offline Find More Posts by billystiltner
Old Nov 25, 2004, 02:33 AM
jmquetin is offline
Find More Posts by jmquetin
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
Thanks Billy for your efforts ! I almost got it but I am still a little bit confused as my English (dictionnary) does not make a difference between a divider and a caliper !
I think the method you mention is based on the same principle as a calliper square (pied coulisse in French). So I think I can get the same result just using a calliper square, a compasses and a magnifier, right ?
Jean-Michel.
jmquetin is offline Find More Posts by jmquetin
Old Nov 25, 2004, 03:41 AM
Joined Nov 2002
Jean-Michel
Divider: device that divides a line
Looks like a compass with 2 needle like points.
Caliper: device to measure distance
Has a scale on it.
I used to call a divider a caliper for some reason.
I looked up pied coulisse , the picture showed what appeared to be what I am refering to as a caliper.
Maybe this diagram will help.
Billy
Old Nov 25, 2004, 04:26 AM
jmquetin is offline
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
Originally Posted by billystiltner
...Example: center to center distance is 5.15mm
3. Set divider close to 51.5mm(use magnifier and caliper)
Billy, I think I got it if I read your step 3 as "Set divider close to 5.15mm" (and not 51.5 mm). Right ?
Thanks again.
J.M.
Old Nov 25, 2004, 05:25 AM
Joined Nov 2002
JM
Yes
Thanks for pointing that out.
I uploaded a diagram that may be more clear.
Billy
Old Nov 25, 2004, 05:33 AM
jmquetin is offline
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
Billy, it cannot be clearer .
Thanks.
J.M.
Old Nov 25, 2004, 06:12 PM
Joined Nov 2002
Here's a new gearbox.
Without prop or wires it weigherd in at .64g.
The motor is the long 4mm Electronics Goldmine cored pager about 14 ohms.
I tested with a 3.5" x 2" prop at around 3.7V 190ma. The gears do not run as smooth as the previous drive. May have reamed the spur coencentric trying to match it up to a tiny plug for a spacer. I ended up reaming too far and had to use wire insulation again. I modeled this gearbox from the one on David Dewitt's 1.48g plane. I did add an extra ply disk to the back of the upright for a bit more sturdiness. It seems that teflon glues to ply with duco I would have never imagined. Maybe it's just a tight fit. Dave D what did you use as a bushing and bushing tube on your gearbox if there is a bushing tube? Again I'm not sure what this thing will fly have not done any thrust measurements. 190ma is quite a bit of curent draw for this motor/gear/prop I think. I did connect it up to a 40maH lipoly which was charged to 4V and curent draw was only 140ma with reduced rpm and thrust of course. Not sure if it would pull a little 5 or 6g plane around with the 40maH cell.
Billy
Old Nov 25, 2004, 09:00 PM
Joined Nov 2002
I was sitting here spinning the prop on the new gearbox and started spinning smooth. I think I may have had some glue get in the gears from previous glueing and squirting with acetone. The prop will spin freely now but not as freely as the dual upright gearbox.
There are 2 other non apparent differences that may cause the single upright box not to spin as freely as the dual upright box -
1) The bushing is a tighter fit
2) The bushing was sanded instead of cut for true alignment with the retainer.
(there is also a teflon washer on the single upright box).
Reasons:
1) I thought the wobbling of the first gearbox may have been caused by:
(a) poor alignment of retainer and bushing.
(b) loose fit of the bushing and axle
2) No matter what kind of jig I have used, have I been able to cut teflon
tubing perfectly straight. I can get them close sometimes by eye.
Anyways the sanded teflon tube may cause a bit more friction than a cut tube even if the sanded tube is straight as can be. I did polish with 600 grit testors sand paper. Technique was same as that of polishing fiber optic cable - figure 8s.
I ran the new gearbox in front of my monitor and did not notice any wobble.
Allthough
When I first ran the new gearbox the prop was not secure and it made the weirdest wobbling sound which repeated at about 0.5Hz then sped up to maybe 4Hz then slowed back down to 0.5 Hz for a bit then stopped. I could see the prop tilting in proportion to the wobbling sound. I imagine the small helis do something similar.
Dave W
You asked earlier on in the thread about the weight of the watch gears.
Well my new gearbox with the long 4mm motor weighs the same as my gearbox with Didel .2mod thinned gears and 4mm short motor. It is not a good comparison though as different materials were used. Plus the wires are still on the short pager motor.
Jean-Michel
The divider/caliper/magnifier thing is great for marking out gear centers.
I used to draw plans and print them out then paste the plans to ply.
With 600DPI printer lines can be 0.00167" but the program I use to draw
the gearbox plans makes much thicker lines when printing small scale drawings at 1:1( I have overcome this for drawing small masks by scaling the drawing up and exporting the image then increasing DPI to get back to correct scale ). I would have never thought to use dividers and step out 10 paces to check. It is a neat idea wonder where it comes from?
Billy
Old Nov 25, 2004, 10:30 PM
Joined Nov 2002
I think my bushing is too long. I reckon a shorter one would produce less friction and the extra bushing sticking out the back of the ply spacer is not necesarry to hold the axle steady correct?
Well I came up with a new gearbox idea.
It is a conglomeration of other ideas I have seen.
Spured from what Ralph and Jochen said about drag and friction.
Plus I read about making bushings from brass sheet somewhere.
As well as Dave W''s idea for adjustable mesh.
Now that I think about Dave's idea it would not be that fiddly if the ply spacers were a tight fit on the bushings or bushing tube.
Heres the idea.
Make a ply upright that fits on the front of the motor.
On ply upright drill hole a tad larger dia than shaft for shaft to go through.
Cut 2 ply discs with hole larger dia than shaft.
Cut out 2 brass sheet squares or discs if you can cut circles that small.
Brass squares need to be larger than hole in ply discs.
Start hole in brass with nedle file.
Ream out to perfect fit for shaft.
Glue brass bushes to ply disks.
Put upright on motor.
Put shaft(with gear attached) through first bushing/ply disc then through upright then slide remaining bushing/ ply disc over end of shaft. Adjust for good mesh with condensor paper or by eye then glue.
Attached is a drawing for clarity.
Billy
Old Jan 27, 2005, 01:39 PM
scharlach is online now
Find More Posts by scharlach
United States, GA, Sharpsburg
Joined Jan 2005
Where do you get the watch gears? I assume you are getting a particular
brand analog watch and removing gears>
Thanks, Dan dblove98@juno.com
scharlach is online now Find More Posts by scharlach
Old Jan 27, 2005, 02:24 PM
planeman is offline
Find More Posts by planeman
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
I've been following this thread from time to time and noticed the numerous requests for a source of small clock gears. A couple of years ago I was looking for a source of these gears for my planes and found them on - what else - E-bay. From time to time a watchmaker dies and someone is selling his collection of old watch gears and stuff. You have to examine the photos carefully. I made two purchases and have a lifetime supply of gears.
Planeman
planeman is offline Find More Posts by planeman
Old Jan 27, 2005, 03:19 PM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
I just checked ebay and there are a few auctions for watch gears. Here is a link for a huge selection of gears!
Josh
j8m8l is offline Find More Posts by j8m8l
Old Jan 27, 2005, 04:32 PM
peter frostick is offline
Find More Posts by peter frostick
peter frostick's Avatar
south shields. England
Joined May 2004
Josh
Billy's micro gear work is certainly inspirational!!! ---- Graham Stabler told me there is a product known a "Watch-Soup" available on the web, which offers a huge amount of random micro gears as a very cheap Job-lot. Please don't bother him about it now however, as exams are looming large!
Peter
peter frostick is offline Find More Posts by peter frostick
Old Jan 27, 2005, 05:16 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I passed
This link from Ralph Bradley, I ordered 1/2lb
http://www.clockworks.com/wparts.html
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jan 27, 2005, 07:47 PM
watersharer is offline
Find More Posts by watersharer
Time wounds all heels.
Phoenix, AZ
Joined Jul 2001
Hmmm, after looking at that page of parts...I wonder if it would be possible to build a 'clockworks' engine for an indoor flyer? Use a mainspring and gear set to drive one of those crazy cat-whisker ornithopters? (Yeah, like these soupbone hands could build that! )
I gotta order a 1/4lb of that stuff just to have around, lol.
watersharer is offline Find More Posts by watersharer
Discussion Watch gear gearboxes for sale billystiltner Scratchbuilt Indoor and Micro Models 13 Aug 28, 2006 08:22 PM
DIY bit gear gearboxes billystiltner Scratchbuilt Indoor and Micro Models 26 Apr 02, 2004 03:57 AM
