Old Nov 18, 2004, 12:05 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Watch gear gearboxes
Hey
I have started on a gearbox for some watch gears.
The watch gears I have look like the watch gear drive on Ralph Bradley's firefly.
The spur looks like the spur on Bob Bailey's Room flyer. The pinion has 10teeth and fits over a 4mm pager shaft with some reaming. The spur gear has 60 teeth. The best I can measure with a vernier caliper I get 7.7mm for the spur and 1.5mm for the pinion. Has anyone else measured these little watch gears with a dial caliper? I would like to get the measurements right before I design a gearbox.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Nov 18, 2004, 12:34 PM
LSB is offline
LSB
Find More Posts by LSB
LSB
Athens , Greece
Joined Jun 2004
Billy
Clockmakers use a simple tool for marking the centers of the gears, called "depthing tool"
attached (I hope ) are two relatively easy to make versions i use.
LSB
LSB is offline Find More Posts by LSB
Old Nov 18, 2004, 12:47 PM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
LSBThanks for passing along the info on a center finding/ marking tool
I have beat my brains out trying to measure and lay out the holes when building GB's
Sure will make my life easier, thanks;
Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Old Nov 18, 2004, 02:10 PM
Joined Nov 2002
LSB
Thanks.
That ought to help get a gearbox made.
Billy
Old Nov 18, 2004, 02:38 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Billy, with these tiny gears it is nice to have some adjustability. Peter Frostick recommended this gear box style to me and I tried it out last night. The diagram is by Peter and shows a box he made for an M20 motor. The mesh can be adjusted with a tiny wedge or if you keep the pinion loose till the last minute by bending the wire (needs to be well attached) in the relevant direction until the mesh is good.
Mine is for a 4mm pager and is slightly different. Firstly my spur gear has a long tube in the middle that could be used directly as a bush, this however meant I had to use slightly thicker wire. Also because the 4mm pagers are delicate I opted to mount the motor in a small tube made from carbon braid. The wire was bent roughly to size, glued and then wrapped with a few tows for extra security. Teflon tube is used for bearings and pvc wire insulation for retainers. The new prop was just glued to the brass tube. There is a small plastic spacer behind it made by heating an pulling some plastic tube.
The box weighs 0.1g so I think it is a little heavy however I think it will pay for itself in efficiency and I want to see if this is so.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Nov 18, 2004, 03:17 PM
Joined Nov 2002
Graham
Thanks. I might try that on my next one. Your pinion looks to be the same one I'm using but you've trimmed it down. I've allready fitted a spur to a 0.25" shaft.
Thought about using 1/64" shaft but gosh thats small. I guess I'll try one like Dave W posted to begin with. I'm wanting to be able to change out motors initially and use the gearbox with the 20maH as well as 40maH on small and large(pistachio)planes. Wonder if 6:1 will have to have too big of prop for a 4" plane at the weight they(4"span planes) are currently made? Seems like Matt said there was not much diference in flying time with the different motors and ratios but is flying for longer now. With the higher ratio I will most definately use your(Peter's technique you posted) technique as theres no room for the bush tube with that small of ratio. Nice gearbox. I think it will pay for itself with the added efficiency plus you wont notice if you change your mains to Litz wire. On the Litz wire thing I found I could fold the end over a pin, hold both ends, and twist(same direction as Litz was made) so I have an eylet then apply flux with toothpick. Apply solder to iron tip, push iron tip into eylet, hold till smoke disapears, pull iron out and have an eylet filled with solder. The eylet then solders to anything with a touch of the iron and the ends do not fray.
Billy
Old Nov 18, 2004, 03:54 PM
Sticky Shepherd
Oxford/England
Joined May 2001
Actually I think Matt also used this style of gearbox in his SE5, I could be wrong. The secret may be thin prop of low weight, certainly if you consider your prop to be a scaled down version of larger props the weight and thickness should also scale. There is not really much info (scientific or modeller based) on such small models but most I have seen do LAR (from the TLAR principle). Apart from anything else I think Lipoly's let us get away with a lot.
Graham
Old Nov 18, 2004, 04:05 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
This is how I have done it:
Dave
Oops, a bit large...sorry.
Dave Wulff is offline Find More Posts by Dave Wulff
Old Nov 18, 2004, 10:11 PM
brucej is offline
Find More Posts by brucej
Good glue is evil
melbourne australia
Joined Sep 2003
thats neat dave
brucej
brucej is offline Find More Posts by brucej
Old Nov 19, 2004, 11:18 AM
peter frostick is offline
Find More Posts by peter frostick
peter frostick's Avatar
south shields. England
Joined May 2004
Graham
Nice gearbox. Hard to believe it's that small utill you start scaling the photo!!
Good luck with flight tests.
Peter
peter frostick is offline Find More Posts by peter frostick
Old Nov 20, 2004, 05:03 AM
Sticky Shepherd
Oxford/England
Joined May 2001
Prop is too small, cynoed bearing mounting new prop, will try again
Old Nov 20, 2004, 09:16 AM
Joe P is offline
Find More Posts by Joe P
Peotone,Il USA
Joined Apr 2004
Where do you find watch gears other than junking old watches?
thanks Joe
Joe P is offline Find More Posts by Joe P
Old Nov 20, 2004, 10:13 AM
Dave Wulff's Avatar
Joined Feb 2002
Are watch gears really that much lighter than plastic (nylon, delron, etc.)? I know Ralph has been fond of them for years and I wonder what I am missing.
Dave
Old Nov 20, 2004, 08:01 PM
Raj Quest is offline
Find More Posts by Raj Quest
Joined Aug 2004
Joe,
Junk old watches might be the best and the cheapest source, but you could also try cassette player/recorder (including walkman) spares suppliers and repairers........
But these will be mostly nylon gears.
Raj.
Raj Quest is offline Find More Posts by Raj Quest
Old Nov 20, 2004, 09:21 PM
RC_AV8R_181 is offline
Find More Posts by RC_AV8R_181
RC_AV8R_181's Avatar
state college, pa
Joined Aug 2002
Joe,
Look here-
http://www.slarose.com/store2/store....id=108&step=4#
A load of watch gears and pinions for $6. Also, if you look under "American watch parts/ movt parts" you can get 100 pinions for $7 (I think these are larger mod than the gears though).
Ben
RC_AV8R_181 is offline Find More Posts by RC_AV8R_181
Discussion Watch gear gearboxes for sale billystiltner Scratchbuilt Indoor and Micro Models 13 Aug 28, 2006 08:22 PM
DIY bit gear gearboxes billystiltner Scratchbuilt Indoor and Micro Models 26 Apr 02, 2004 03:57 AM
