Old Nov 18, 2004, 09:13 AM
pkrska is offline
Find More Posts by pkrska
pkrska's Avatar
Toronto, Ontario, Canada
Joined Jan 2004
Which PJS to get for AP SS?
I am planning on upgrading the motor for my newly created Slow Stick for AP.
It came with a 300 motor, so that will definitely be a plus. However, I am wondering what you people recommend as the best PJS to get. I see that they have 800, 1000 even 1500! Some say INVERT.
pkrska is offline Find More Posts by pkrska
Old Nov 18, 2004, 10:07 AM
crooser is offline
Find More Posts by crooser
err...see where it went?
crooser's Avatar
Qld, Australia
Joined Sep 2004
the 800 is the only choice by far for a good mix of power/run time on 3s lipos.
make sure you get a 25amp ESC minimum though eg. CC Phoenix 25
you can run 10x47, 11x47 and 11X7 props well on this combo
more than enough power for an SS AP rig (up to 40oz)
hope this helps
crooser is offline Find More Posts by crooser
Old Nov 18, 2004, 11:17 AM
pkrska is offline
pkrska's Avatar
Joined Jan 2004
Thanks for the reply. The CC Phoenix is a programmable ESC? I take it I would need a programmable ESC for the lipo cut off point?
Old Nov 18, 2004, 11:32 AM
eBird is offline
Find More Posts by eBird
Look! Up in the sky!
eBird's Avatar
Grand Junction, Colorado
Joined Jul 2002
Yep.
eBird is offline Find More Posts by eBird
Old Nov 18, 2004, 01:38 PM
BUBIK is offline
Find More Posts by BUBIK
Joined Aug 2004
I'm using PJS 1000 together with 2 lipos 2000 mAh 15 C. Almost the same output like 800 + 3 lipos, but you save weight.
BUBIK is offline Find More Posts by BUBIK
Old Nov 18, 2004, 04:09 PM
Dampy is offline
Find More Posts by Dampy
honey... anOTHER PLANE!
Dampy's Avatar
Cedar Park, TX
Joined Aug 2002
BUBIK - What prop do you use and how many amps do you pull WOT? Also what's the AUW of your SS?
Neil
Dampy is offline Find More Posts by Dampy
Old Nov 18, 2004, 09:48 PM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
The Cracker Barrel has an 800 on it and it goes almost vertical. With the 1000 do you really need to save weight?
patrickegan is offline Find More Posts by patrickegan
Old Nov 18, 2004, 11:11 PM
pkrska is offline
pkrska's Avatar
Joined Jan 2004
But if I was to use NiMH, would you still recommend the 800 or the 1000?
Old Nov 19, 2004, 12:35 AM
eBird is offline
eBird's Avatar
Joined Jul 2002
I see no reason to use the PJS 1000 on a SS. The 800 is more efficient, giving you plenty of thrust while burning fewer amps.
If you are intending on using NiMH cells, use BIG ones to supply the 1000 with enough amps.
Old Nov 19, 2004, 02:51 AM
BUBIK is offline
Joined Aug 2004
Neil
I use APC 11x4,7 slow-fly, which is recommended by PJS. I've never measured amps, but it shouldn't be more than 20A. I don't use it on SS, i built my own plane, using wing from multiplex's movie star.
Old Nov 19, 2004, 08:47 AM
crooser is offline
crooser's Avatar
Qld, Australia
Joined Sep 2004
Old Nov 19, 2004, 08:48 AM
crooser is offline
crooser's Avatar
Qld, Australia
Joined Sep 2004
wouldnt the 2s lipo be screaming for mercy pushing an 11x4.7 on a 1000?
Old Nov 19, 2004, 01:31 PM
pl1974 is offline
Find More Posts by pl1974
pl1974's Avatar
Rutland, UK
Joined Jan 2004
OK all this talk about it has just about persuaded me, I'm about maxed out on my AXI 2212/26 already at around 12 amp draw... - can anyone let me know of a good retailer for the PJS 800. I'm in the UK, so would need a retailer in UK or an exporter.
Paul
pl1974 is offline Find More Posts by pl1974
Old Nov 19, 2004, 01:48 PM
bbarrus is offline
Find More Posts by bbarrus
Joined Jan 2004
Who is a good retailer in the US?
Also, where do you get the wicked cool mounts?
bbarrus is offline Find More Posts by bbarrus
Old Nov 19, 2004, 02:06 PM
Yumastan RCAPA.NET
Joined Feb 2003
www.topcreationsrc.com for the mount. www.Hobby-Lobby.com for the motor.
Discussion Which battery to get for SS? kc8tad Batteries and Chargers 5 May 07, 2006 11:47 PM
PJS 800 + Tanic 2150 for AP SS... Holy Cow! eBird Aerial Photography 26 Sep 08, 2004 12:10 PM
What wheels for ap ss Chuckhead1 Aerial Photography 8 Sep 02, 2004 05:15 AM
Which plotter to get for under $2000 Mike Hall The Builders Workshop 7 Jul 28, 2003 06:17 PM
ESC - Which one to get for a Twinstar? Alfred Power Systems 4 Aug 15, 2002 08:08 PM
