Old Nov 16, 2004, 10:36 PM
fast_monte is offline
Find More Posts by fast_monte
Cincinnati, OH
Joined Nov 2004
AB X wing on a AB C to make a better glider
Would it be possible to put a AeroBird X-treme wing on a AB Challenger? I want to turn the Challenger into a better glider that it alredy is. If I could do that with a 20 dollar wing that would be cool.
fast_monte is offline Find More Posts by fast_monte
Old Nov 17, 2004, 07:40 AM
catcher is offline
Find More Posts by catcher
Do I have to?!
Chanute Johnson, Kansas, United States
I do not have the ABX but do have the ABC and I think it could handle the ABX wing.
catcher is offline Find More Posts by catcher
Old Nov 17, 2004, 07:49 AM
uscra112 is offline
Find More Posts by uscra112
Mid-Michigan
Joined Aug 2002
If the new wing is much bigger, it will be less stable in pitch. The stabilizer area will now be a lesser percentage of the wing area. You might need to add a little to it to regain the stability.
uscra112 is offline Find More Posts by uscra112
Old Nov 17, 2004, 05:25 PM
RyanPSU21 is offline
Find More Posts by RyanPSU21
RyanPSU21's Avatar
USA, MI, Harrison Township
Joined Sep 2000
You can try it and find out. Way back when I had a Goldberg Mirage which was around 50" span 05 can motor trainer plane. For fun one day we rubber banded on a GP Spirt wing (2meter span glider wing) to it since the chords were about the same. It flew just fine with that wing also but had a better glide ratio.
RyanPSU21 is offline Find More Posts by RyanPSU21
Old Nov 19, 2004, 05:15 PM
Cincinnati, OH
Joined Nov 2004
To answer my own question. The wing is too long to go on.
I busted the ABC wing up pretty bad. The Hobby shop only had a commander wing in stock. I am going to try it. Maybe it will fly a little slower with it. I am going to try to fix up the busted up ABC wing still.
Old Nov 20, 2004, 12:26 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
The commander has the same wing, but a little shorter. If anything the plane will have to fly slightly faster.
aeajr is offline Find More Posts by aeajr
Old Nov 20, 2004, 11:48 AM
Cincinnati, OH
Joined Nov 2004
The commander wing is a little shorter but has more wing area because the wing tips are more blunt. I am heading of to the park shortly to find out.
Old Nov 22, 2004, 05:22 PM
Cincinnati, OH
Joined Nov 2004
I could not detect much of a difference. I need to improve my flying skills, three flights and killed two wings.
Alert AB Pilots, bring it on! CooHead Parkflyers 37 Dec 11, 2003 06:08 PM
verification on M.A.C on wing daveswall Electric Plane Talk 0 Jun 02, 2003 07:59 AM
Slow Flyer wing on a glider? tenover Parkflyers 0 Oct 09, 2001 10:54 PM
