Here - look at this site:
http://www.ezonemag.com/disc/Forum3/HTML/000431.html I just built mine, and I used packing tape for the hinges. Just make sure you REALLY bevel one side so the hinge gap is small. I think my gap is too big. Also, I put two servos in the wings so I could have flaps. They say this flies fast and takes a large field to land. Thus, flaps should help me land in my medium sized field. I haven't flown mine yet, but I'll post information when I do. I'm about 2 days away from finishing construction. All I have left are building the battery pack, installing the motor, ESC, and receiver! Anyone have tips on building a first battery pack? |
I would make sure you have a soldering iron of at least 40 watts and make sure the tip is of larger diameter. If you try to solder with the stock tips of most soldering pencils, you will never heat the tabs/batteries enough to get a good connection. I often use a bit of hot glue to hold the cells in their final pack shape before I begin soldering tabs. That helps with planning the orientation of each battery. NEVER USE ACID CORE SOLDER!! Make sure it is rosin core. Be sure to clean excess rosin from battery tops after an good solder connection has been made. That stuff is corrosive! |
Try my web site for a list of the most recommended mods:
http://chrisd-rc.freeservers.com I used black plastic soup spoons as air scoops. Remember, the outlet airhole has to be 3 times the area of the intake hole. I used foam friendly CA to mount it to the covering. The inlet hole is almost the size of the outline of the spoon. |
| Thread Tools | |
| Lanier Shrike 400 Building Tips??? | Craig Logan | Sport Planes | 6 | Jul 20, 2005 04:55 PM |
| Zoom/Shogun 400 Building Tips ? | jnyoun | Mini Helis | 7 | Jun 23, 2004 07:17 PM |
| Simple 400 building question | emaij | High Performance | 2 | Jul 23, 2001 12:01 AM |
| Spare simple 400 wings? | KMKAZE | Electric Plane Talk | 2 | Jul 12, 2001 01:21 AM |
| Cooling air vents in a Simple 400?? | ErnieR | High Performance | 9 | Apr 20, 2001 06:41 PM |
