Old Nov 16, 2004, 12:09 AM
Johnnie is offline
Find More Posts by Johnnie
Gilbert, AZ
Joined Aug 2004
nimh receiver pack failure???
I just had a receiver pack failure in my glider, it was like some one shut off the receiver, one second it was flying the next second zero control. it was a 640mah 4 cell pack that had recently been charged and it was only a few months old. when I tested it after the crash(more like a really bad landing) it had 4.8 volts static and when I turned on the receiver in dropped to 2.7 volts and wouldnt move a thing. anyone heard of a failure like this. could I have done something wrong. too high of a charge rate? discharge battery too much? I just started using nimh batterys for receivers and I dont know if I should continue to do so , maybe I just got a cell that was made on a monday, if this is an isolated incident I would love to keep using nimh receiver batterys mostly because theyre size allows shoving them way up into the nose of the gliders. by the way I the failure occured in a descending spiral I broke my v-tail on landing and should have it back in the air after a $20 tail replacement. sometimes you get lucky
Johnnie is offline Find More Posts by Johnnie
Old Nov 16, 2004, 01:15 AM
Hovertime is offline
Find More Posts by Hovertime
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Did you try to charge it?
Hovertime is offline Find More Posts by Hovertime
Old Nov 16, 2004, 06:45 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
That's the reason that battery voltage has to be checked under a load.
This is what happens a lot when you fast charge transmitter and receiver packs.The volts goes up fast but it takes time for the Ma's(capacity) to be replaced.
Charles
Charles
Southern Pride
Old Nov 16, 2004, 07:03 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
My first NiMh motor battery did the same thing first time out. I had charged it at about 2A (it was a 3300 pack, so 3A or more would be 'normal' charge rate), but friends at the field told me that I should charge and discharge it at a much lower rate a few times. So I cycled it a couple of times on my slow charger (probably only 100mA) and it's been okay from then onwards.
So, you need to charge it at much less than its normal charge rate for the first couple of times.
abenn is offline Find More Posts by abenn
Old Nov 16, 2004, 08:17 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Originally Posted by Johnnie
when I tested it after the crash it had 4.8 volts static and when I turned on the receiver in dropped to 2.7 volts and wouldnt move a thing.
Your cells are empty. Recharge for 16hrs at 65mAh and discharge it, repeat once.
How recent is recently charged? What was the ambient temperature?
Haldor is offline Find More Posts by Haldor
Old Nov 16, 2004, 08:43 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Any model that uses a Rx pack, I cycle that pack the day before I plan to fly it.
..a
Old Nov 17, 2004, 01:07 AM
Johnnie is offline
Gilbert, AZ
Joined Aug 2004
in response to several questions I charged the pack the night before, I did not try to charge the pack after "the incident" , I did not cycle the pack when I first bought it or any time after that, ambient temp was 70 F , I,m going to replace the pack(I already have a new replacement) and I'll try the low amp rate cycle a couple of times before putting it into service Thanks everyone for the input
Old Nov 17, 2004, 01:28 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Since you say the pack was charged the night before new questions arrise:
1 - What charger did you use?
2 - What charge rate did you use?
3 - For how long?
4 - How long did you fly before it failed?
Old Nov 17, 2004, 06:56 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Charging does not ensure a pack is good, which is why I put one cycle on my Rx packs before flying - some models don't get to fly very often..
Capacity under load (I usually use C for Rx packs, with a 1V/cell cutoff) is, however, a great indication of pack health.
Old Nov 17, 2004, 01:50 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Exactly, and considering that this pack is small and its capacity under load will be even smaller, depending on the amp draw of your glider and flight time, its possible that you just used it up, also nimh self discharge pretty fast, so if it was not charged before the flight there were less mah to start with...
Discussion Discharge rate? 3300mAh NiMH receiver pack TachyonDriver Electric Heli Talk 3 Aug 21, 2007 08:29 PM
Wanted Ni-cd or Nimh receiver pack batteries why2cay Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jul 16, 2007 06:01 PM
Question Can I charge a NiMH receiver pack through the DX6 charger? Spackles94 Radios 6 May 24, 2007 10:32 AM
Expert PRO2700 NiMH receiver pack 1.5 tesla Aircraft - General - Radio Equipment (FS/W) 0 May 02, 2005 07:29 AM
Traxxas T-Maxx 2.5 RTR w/Aluminum Rims and NiMH Receiver Pack!! (RTR) Slavetonone Cars - Cars and Parts (FS/W) 2 Nov 23, 2004 09:05 AM
