Old Nov 15, 2004, 12:11 PM
Douglas, Brent
Douglas, Brent
Guest
n/a Posts
sandable filler
I'm doing some work on an obechi wing w/ a balsa leading edge, and I
have some little depressions at the seam I'd like to fill.
Normally I mix epoxy and microballoons to fill a gap, but I don't want
to sand epoxy smooth or run an iron over it when I finish the wing.
Any better solutions? I was considering spackle filler and white glue,
but that sounds low tech - what else is there?
Brent
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Old Nov 15, 2004, 02:11 PM
Darwin Barrie
Darwin Barrie
Guest
n/a Posts
Re: sandable filler
Light weight spackle from Lowes or Home Depot. When done and sanded put some
medium CA on and spread over the area. Sand again till smooth. Works really
well.
Darwin N. Barrie
Chandler AZ
----- Original Message -----
To: <soaring@airage.com>
Sent: Monday, November 15, 2004 11:06 AM
Subject: [RCSE] sandable filler
Brent
MIME turned off.
Harley Michaelis
Harley Michaelis
Guest
n/a Posts
Re: sandable filler
Brent. . .go to http://genie.rchomepage.com/. Get into the Fine Finishing
file and learn about "Icing" putty.
Sent: Monday, November 15, 2004 10:06 AM
Brent
MIME turned off.
