Old Nov 15, 2004, 11:14 AM
jason_ices is offline
Find More Posts by jason_ices
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
Scratch Build Jet Trainer
Hello Guys, i'm building a jet trainer for my friend. every thing doing from scratch. but the wing core came out heavy, i'm using 32kg/m3 foam density, airfoil are from NACA 2415 modify.This is my first time build turbine plane, need some advise from the expert here. Here are the link Trainer Jet Build thread
Thanks in advance
Jason
jason_ices is offline Find More Posts by jason_ices
Old Nov 15, 2004, 12:38 PM
winmodels is offline
Find More Posts by winmodels
Wareham, Dorset, UK
Joined Dec 2003
Originally Posted by jason_ices
Hello Guys, i'm building a jet trainer for my friend. every thing doing from scratch. but the wing core came out heavy, i'm using 32kg/m3 foam density, airfoil are from NACA 2415 modify.Jason
Hi Jason
had a look at your building thread - very nice.
With e-flight weight is very important - or rather the lack of it. You could try to find lighter foam, there are some available with only 18kg/m^3. But be carefully with the vacuuming, the light foams are easily squashed - don't go below 0.7 bar abs.
For my own model I use blue foam of ca' 35kg/m^3, but then I hollow the cores which saves 1/3 to 1/2 of the weight. I wouldn't vacuum those however - unless you reinsert the cut outs again, perhaps wrapped in news paper to account for the lost kerv.
Have a look in my building thread:
http://www.rcgroups.com/forums/showt...58#post2902558
Try electric!
Have fun anyway
Klaus
winmodels is offline Find More Posts by winmodels
Old Nov 15, 2004, 11:27 PM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
Hi Klaus, i put my hat on your head! Salute!! your work are nice need to learn some from you... do i need to do some lighterning hole in the wing? wing span 80in, root chord 39cm, tip chord 25cm wing core weight at 500+ gram. this haven't include sheeting weight. Our power system are MW 54. What sould i do?? Thanks
jason
Old Nov 16, 2004, 06:23 AM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
do i need to lightening the wing by punch few hole in the wing?
Old Nov 16, 2004, 06:36 AM
sukhoiboi is offline
Find More Posts by sukhoiboi
wiltshire, england
Joined Apr 2004
If you are using a wren mw 54 (or any other gas turbine) you really wanna make sure the plane is very strong! This forum you are in now is for electric jets! Here is a link to where the turbine guys hang out. Turbines and other smelly noisy ic jets! LOL
sukhoiboi is offline Find More Posts by sukhoiboi
Old Nov 16, 2004, 08:11 AM
KSU Flyer is offline
Find More Posts by KSU Flyer
KSU Flyer's Avatar
Manhattan, Kansas, United States
Joined Oct 2001
Klaus,
Excellent foam cutting...CNC?
-Mike
KSU Flyer is offline Find More Posts by KSU Flyer
Old Nov 16, 2004, 10:48 AM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
i'm sorry post it here, moderator please move this to fuel airplane-Jet forum. Thanks
Jason
Old Nov 16, 2004, 02:30 PM
wiltshire, england
Joined Apr 2004
Dont worry! I like turbines too! MMMMMMM PRECIOUS!
Old Nov 16, 2004, 04:01 PM
Wareham, Dorset, UK
Joined Dec 2003
Originally Posted by KSU Flyer
Klaus, Excellent foam cutting...CNC? -Mike
Hi Mike
Singlehanded!
Klaus
Old Nov 17, 2004, 06:23 AM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
work on 17 Nov. daddyhobby.com
Old Nov 17, 2004, 10:25 AM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
No wash-out this what i worry!! any chance to modify it back??
jason
Old Nov 17, 2004, 01:01 PM
jason_ices's Avatar
MALAYSIA
Joined Aug 2003
A Jet Flyer told me this :
There is a spanish quote who says " El mal paso hay que borrarlo pronto " or in english "The wrong step should be corrected quickly" Better cut new foam panels with about 3 degrees washout, Jason... you will not regret. of course, in my humble opinion.
Best Regards, Enrique
So i decide to built another panel wing with 3 deg wash out built-in !! Then i can sleep sweet
Jason
ART/FAST BUILD aileron trainer ???? VaVol Electric Plane Talk 8 Oct 11, 2007 03:44 AM
Scratch build - kit build - or ARF? hardlock Foamies (Kits) 16 Oct 12, 2001 04:05 AM
Want to scratch build a fun fly plane. Cay you recommend plans? WilliamSettle Sport Planes 4 Oct 04, 2001 11:29 PM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
My new jet trainer for EDF 300 kwan Electric Ducted Fan Jet Talk 3 Jun 26, 2001 06:54 AM
