Old Nov 15, 2004, 06:26 AM
Michnet76 is offline
Find More Posts by Michnet76
Carl
Michnet76's Avatar
Riverland, South Australia
Joined Nov 2004
Question
motor/battery and prop configuration... any suggestions!
Hi all... Hoping someone can help out a noob to electrics!
I'm waiting for my new GWS F4U Corsair to rock up and have been busy making sure I have everything to get this bird built and flying.
The Corsair comes with the EPS-350C-BS motor/gearbox and I'm planning to use 9.6V 8 cell AAA 650mah batteries and a new GWS ICS300 ESC.
By the looks of it the kit comes with a 9070 and a 1060 prop, plus I have a few spare 9070 props as well which I was hoping to use. How do you think this motor/gearbox setup will work with a 9070 prop?
According to the GWS website it should be safe to use a 8043 which will run at 8.9amps. 8060, 9047 & 9050 run between 10.6-12.6amps but 9070 isn't even mentioned there. Further down the list though under the EPS-350C-DS setup a 9.6v spinning a 9070 runs at 8.7amps. I'm assuming the BS/DS is different gear ratios?
Any comments would be much appreciated.
Michnet76 is offline Find More Posts by Michnet76
Old Nov 15, 2004, 06:33 AM
zyklon_chichi is offline
Find More Posts by zyklon_chichi
tried a 9070 with 350c and b gear before, it was pretty fast and powerful, but I tried it on 2s lipo which is only 7.4v, going with 9.6v and 9070 might kill the motor really fast.
zyklon_chichi is offline Find More Posts by zyklon_chichi
Old Nov 15, 2004, 06:37 AM
Carl
Michnet76's Avatar
Joined Nov 2004
Yeah I was thinking it would... how does it affect the amperage if you only fly at half throttle? I'm not planning to do any fast flying for a while anyway.
Question Blade CP Motor/Battery/Rotor Configuration chrys_burge Micro Helis 5 Jan 18, 2006 07:43 AM
electric calculator motor battery prop? 60ndown Electric Plane Talk 3 Oct 10, 2004 03:32 PM
EStarter and Corsair: motor/battery/prop? Urthman Parkflyers 17 Jul 23, 2004 02:45 PM
Motor/Battery/Prop selection?? bkdaaa Foamies (Kits) 1 Jun 14, 2004 06:51 PM
Four*40 Motor/Battery/Prop? Curtis Suter Sport Planes 4 Aug 25, 2002 11:03 PM
