Old Nov 14, 2004, 05:11 PM
gunnisonflyer is offline
Find More Posts by gunnisonflyer
gunnisonflyer's Avatar
gunnison colorado
Joined Oct 2002
You just can't keep a good Gambler down
I just could not stand to be without my Gambler after "the incident" (see link)
http://www.rcgroups.com/forums/showthread.php?t=294561
So I decided, what the heck, rebuild her. First thing to do was to strip all the old covering off the wing. The ball of oracover transparent weighed 18 grams.
gunnisonflyer is offline Find More Posts by gunnisonflyer
Old Nov 14, 2004, 05:13 PM
gunnison colorado
Joined Oct 2002
I used some thick CA to glue the broken spar and TE back together. I used some thin CA to wick into the joint between the sheeting and the rib. I added a strip of CF over the break at the spar and over the broken TE. I also removed the old shattered ribs.
Old Nov 14, 2004, 05:15 PM
gunnison colorado
Joined Oct 2002
next step was to make some new ribs, I did this using an x-acto knife to cut out two new ones.
Old Nov 14, 2004, 05:18 PM
gunnison colorado
Joined Oct 2002
Since the ribs were intact in front of the spar, I cut the new ribs off at the spar notch and glued them in place.
Old Nov 14, 2004, 05:22 PM
gunnison colorado
Joined Oct 2002
The former that holds the wing dowel broke, the one behind it seperated from the fuse sides. I got a crack in the balsa in the fuse, but did not go through the FG. I pieced all the pieces back one by one and secured them back in place with thin CA.
Old Nov 14, 2004, 05:23 PM
gunnison colorado
Joined Oct 2002
Wing and fuse fixed. Extra CF was added at panel joints and over breaks.
Old Nov 14, 2004, 05:27 PM
gunnison colorado
Joined Oct 2002
Here is my radio layout. I figured while I was adding so much weight, I might as well throw in a micro switch jack. I needed a little more weight up front now anyway. Notice where the balsa tore away on the bottom of the fuse, the FG is still in place so I did not do anything to that spot.
Old Nov 14, 2004, 05:29 PM
gunnison colorado
Joined Oct 2002
Weight before crash- 7.2 oz
Weight after with new micro switch jack- 7.6 oz
The MSJ weighed 5 grams.
Old Nov 14, 2004, 05:35 PM
gunnison colorado
Joined Oct 2002
Here she is all repaired, she looks as good as new! Thanks for all the encouragement. Right after the crash, I was ready to throw it away. Today I took her out, started with a easy javelin launch, flew beautifully. My heart almost stopped when I saw a dog sprinting after my Gambler. S***, I thought. Luckily, the dog skidded to a stop right in front of it and just stared at it. After the dog left, I wound up for my first discus launch. It went up like a rocket, and on it's first flight back, hooked up with a 3 and a half minute thermal. I was so happy, I almost had a tear in my eye. The moral of the story is no matter how bad it looks, repair it, I am sure glad I did. Even with the .4 new ounces it flew beautiful, I really did not notice the new weight.
Old Nov 14, 2004, 06:01 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Well done!
Old Nov 14, 2004, 10:47 PM
tw126a is offline
Find More Posts by tw126a
Thunder Bay, Canada
Joined Aug 2004
Wow! Great job Gunnisonflyer, I think we all felt your pain and then your inspiration and to get a nice thermal flight, I was getting choked up! Hope my Gambler can look half as good as yours when I build it. Happy thermals.
tw126a is offline Find More Posts by tw126a
Old Nov 15, 2004, 02:26 AM
sloppytypist is offline
Find More Posts by sloppytypist
shoreline, washington
Joined Sep 2002
Steinlager, good choice.
sloppytypist is offline Find More Posts by sloppytypist
Old Nov 15, 2004, 05:54 AM
Shreve is offline
Find More Posts by Shreve
build, launch, rekit...
Shreve's Avatar
Columbia, MD
Joined Oct 2003
Most excellent! Thanks for the pics, too. So she has a war wound or two. No biggie.
Shreve is offline Find More Posts by Shreve
Old Nov 15, 2004, 06:02 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You know, I'm so glad this was posted here and not in "crash discussion" where I personally, and I'm sure many others, would never have seen it!
..a
Old Nov 15, 2004, 09:30 AM
gunnison colorado
Joined Oct 2002
Thanks guys-
It was the encouragement I got here that inspired me to fix it. Hopefully, it will motivate other people to fix their broken crunchies. I was really suprised how well it flew.
I did not even know we had a crash forum, hmmmmm...... will have to check it out.
Discussion To get your fix when you just can't get out there. Brazzzle Club Talk 0 Nov 16, 2006 05:25 PM
Discussion You just can't make up stuff this good... lrsudog Life, The Universe, and Politics 35 Aug 17, 2006 03:03 PM
Sometimes you just can't give up... Mark Wood Electric Plane Talk 3 Jan 17, 2005 11:57 AM
Another "You just can`t beat CC Customer service." kushal_22 Castle Creations 30 Jul 08, 2003 10:56 PM
Just can't build yet another Spitfire ? ChrisP Scale Kit/Scratch Built 0 Jun 25, 2001 04:42 AM
