Old Nov 14, 2004, 03:54 PM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
4 meter Duo Discus install and fly
Hi Folks,
I just got this sailplane this weekend and plan on documenting my equipment installation and hope to get a few pointers from the "pros" on here as this is my first scale sailplane and first aerotow ship...
What torque servos would you recommend for the tow release and retract? I have a friend that recommends 100 oz torque servos here...
How about the elevator? It looks like an HS 85 size servo is the only thing that will fit in the rudder.
Attached are a few pics...
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Nov 14, 2004, 04:00 PM
ptlpc is offline
Find More Posts by ptlpc
FlyLoc
ptlpc's Avatar
http://rcinfo.blogspot.com
Joined Aug 2004
Jeff,
Great looking sailplane. Fantastic cockpit detail. Which manufacture is it? Looking forward to your install.
ptlpc is offline Find More Posts by ptlpc
Old Nov 14, 2004, 08:04 PM
wakumann is offline
Find More Posts by wakumann
wakumann's Avatar
Canada
Joined Jul 2003
If you use the pin in a sleeve tow release, a standard servo will do it .
There is normaly no load on the Servo.
Cheers
Thomas
wakumann is offline Find More Posts by wakumann
Old Nov 14, 2004, 09:50 PM
Fayetteville, GA
Joined Oct 2000
This is what is already installed....
Old Nov 14, 2004, 09:51 PM
Fayetteville, GA
Joined Oct 2000
Ptlc...
I'm not sure who the manuf. is......Etienne at Icare told me but I forgot...
Old Nov 14, 2004, 10:05 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
I would look into putting a Hitec wing servo in the tail for the elevator-- for a 4 meter ship-- I wouldn't trust the HS85's torque-- the wing servo should be thin enough to fit right in-- and get more for the wings too! IMHO
timmig is offline Find More Posts by timmig
Old Nov 15, 2004, 10:39 AM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Use the biggest servo you can fit.........strange things can and do happen during towing.......you want positive release every time....this is what I use....strong...and inexpensive!
http://www.servocity.com/html/hs-705mg_1_4_scale.html
SZD16 is offline Find More Posts by SZD16
Old Nov 15, 2004, 12:10 PM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
I've used HS-85MG+ servos in the elevators of comparable gliders and they work just fine. Just be sure to use the MG (metal gear) versions. Yes, there is a very small amount of gear play, but these servos just don't strip. And for tow release, a strong servo is a must for guaranteed release every time.
SteveR is offline Find More Posts by SteveR
Old Nov 15, 2004, 01:11 PM
Fayetteville, GA
Joined Oct 2000
Thanks for the tips guys...
Here's what I ordered:
JR DS3421 for the elevator
JR 2721 for the tow release
JR 2721 for the retract
JR 531 for rudder
JR DS368 for ailerons
JR 341 for spoilers
10 channel PCM dual converson Rx
It's a little easier on the wallet to order really good radio equipment when you don't have to spend $600 on a motor / gearbox / ESC! :-)
I also ordered extensions with chokes inline for my aileron and elevator leads...Do you guys use them?
The 2721 outputs 120 oz. of torque at 4.8 volts. I could not go with a 1/4 scale size servo as it would eliminate the ability to use the scale cockpit.
Old Nov 15, 2004, 09:36 PM
Capn Crunchie is offline
Find More Posts by Capn Crunchie
Joined Nov 2002
Originally Posted by timmig
-- I wouldn't trust the HS85's torque-- the wing servo should be thin enough to fit right in-- IMHO
HS 85MGs and HS 125/5125servos - same torque
http://www.servocity.com/html/hs-85m...hty_micro.html
www.servocity.com/html/hs-125mg_slim-wing.html
http://www.servocity.com/html/hs-512...ital_wing.html
Capn Crunchie is offline Find More Posts by Capn Crunchie
Old Dec 21, 2004, 07:02 PM
Fayetteville, GA
Joined Oct 2000
Had a chance to start installing equipment in the Duo this weekend.
Here's a pic of the JR 2721 servo installed on the tow release line:
Old Dec 21, 2004, 07:03 PM
Fayetteville, GA
Joined Oct 2000
Here's a pic of another JR 2721 linked to the retract:
Old Dec 21, 2004, 07:05 PM
Fayetteville, GA
Joined Oct 2000
Here's a pic of the JR 531 installed for the rudder:
Old Dec 21, 2004, 07:06 PM
Fayetteville, GA
Joined Oct 2000
Here's another shot of the retract and rudder servos:
Old Dec 21, 2004, 07:07 PM
Fayetteville, GA
Joined Oct 2000
Here's a picture of a JR DS3421 installed in the vertical stab. This is the elevator servo:
Well another 4 meter Discus on Ebay! Astroguy Scale Sailplanes 10 Oct 25, 2005 06:36 PM
F/S Rodel 4 Meter Discus 2A GoodTill Aircraft - Sailplanes (FS/W) 3 Feb 23, 2005 06:04 PM
4 Meter Scale Molded Discus timmig Aircraft - Sailplanes (FS/W) 16 Jan 27, 2005 09:38 AM
Whoops! CG for AMD 4 meter discus?? kevin kavaney Scale Sailplanes 0 Sep 30, 2004 10:25 PM
Come see a 4 meter Discus at Scobee Terror Dactyl Thermal 0 Sep 03, 2004 03:36 PM
