Old Nov 14, 2004, 12:03 PM
rcmann is offline
Find More Posts by rcmann
rcmann's Avatar
Joined Sep 2003
The differences between EPS and EPP foam
Per request, here are some ways to tell the difference between EPS and EPP foam.
EPS stands for expanded polystyrene, otherwise know as styrofoam. Depron, fan fold foam, sturdiboard, and the blue and pink foams found at home centers, are all EPS. This foam is easy to cut, fairly easy to sand, fairly rigid, fairly brittle (cracks easily) and not very durable. If you press your fingernail into it, it will leave a permanent crease. If you hold a very small piece over a match, it will just collapse and dissappear. Regular CA glue will melt this foam, as will some types of spray adhesives and spray paints. Use foam safe CA on EPS foam. See this thread for glues that work on EPS:
http://www.rcgroups.com/forums/showt...3&page=1&pp=15
EPP stands for expanded polypropylene. I know of no trades names for this foam other than EPP. This foam is more difficult to cut, very hard to sand, less rigid than EPS and much much more durable. If you press your fingernail into it, the dent will almost totally dissappear. If you hold a very small piece over a match, it will catch fire and burn. You can use any type of adhesive or paint on EPP, as long as it sticks. From my limited testing, polyurethane glues work the best on EPP, but epoxy, CA and many contact adhesives also work well.
I'll post some pictures of EPS and EPP a little later, or someone else can also post some pictures.
rcmann is offline Find More Posts by rcmann
Old Nov 15, 2004, 10:43 PM
Broncomech is offline
Find More Posts by Broncomech
United States, CA, North Highlands
Joined Aug 2004
Hey Rcman,
Here are two types of EPS.
Good old bead board /styrofoam AKA Expanded PolyStyrene, and
Bluecor / FFF AKA Extruded PolyStyrene.
Kind of hard to tell by looking at them that chemicaly these two samples are the same material.
Broncomech is offline Find More Posts by Broncomech
Old Nov 16, 2004, 05:48 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Bronc: One's Expanded (Beads), and one's extruded...
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 18, 2004, 09:24 AM
JLSalas is offline
Find More Posts by JLSalas
JLSalas's Avatar
Santiago Pudahuel, Chile
Joined May 2003
Very informative thread. What about weight?
JL
JLSalas is offline Find More Posts by JLSalas
Old Nov 18, 2004, 10:04 AM
rcmann is offline
rcmann's Avatar
Joined Sep 2003
Great info. from www.flyingfoam.com
Selection:
Foam selection is dependent on the size of the model, type of covering, intended use and construction methods. Foam is produced in many densities, colors and types. Only a few types and densities are used in the modeling world.
Density is defined as the weight of 1 cubic foot of the material. In other words, a 12" x 12" x 12" cube of 1# density foam will weigh 1 pound. Higher density foams are harder to the touch and more rigid, but they weigh more.
The higher density foams are typically used in high aspect ratio wings that are relatively thin, like high performance thermal gliders. Powered pylon racers, even giant scale racers may also use 2# foam. Large models with thicker airfoil cross sections will work fine with 1# foam. The 1# foam is also used on most powered sport airplanes, trainers, and any airplane or glider where weight is a concern.
Types of Foam:
We stock a number of types of foam, and some types are available in different densities:
- 1.0# EPS
- 1.5# EPS
- 2.0# EPS
- Owens Corning Pink Foam (1.8# density)
- Dow Blue Square Edge (1.8# density)
- Dow Blue Hi-Load 40 (2.0# density)
- Surfboard Foam (AKA Spyderfoam, 2.3# density)
- 1.3# EPP
- 1.9# EPP
EPS - Expanded Polystyrene Foam:
The EPS foams that we use are white beaded foams that commonly used for insulation material or in architectural applications. White foam is available in any thickness up to 8 inches in 1#, 1.5# or 2# density. We purchase EPS foam in large billets, and slab cut it into sheets in our shop. By doing this we get a foam sheet that is flat, has a better surface finish, and a more uniform thickness than is typically available from insulation suppliers.
Blue / Pink Foam:
Blue and Pink foam is readily available in home improvement stores in many parts of the U.S., but not in Southern California. These foams are a higher density material that is typically used as cold weather insulation on basement walls and footers. In Southern California, we have neither basements nor cold weather, so Blue and Pink foams are not as readily available here.
We stock Dow Blue foam in 25 and 40 psi compression and Owens Corning Pink Foamular which is 25 psi compression.
These are closed cell extruded foams that have a finer grain than 2# white beaded foam, but the mechanical properties of the two are similar. We stock Blue foam in 2" thick sheets and Pink foam in 1 1/2" and 2" sheets. Blue foam is also available in 25psi compression in 3" and 4" thick sheets as special order items.
Surfboard Foam:
Surfboard foam is manufactured by Dow, and is a polystyrene foam similar in feel and texture to blue foam. The big difference is that surfboard foam has grain structure that runs vertically through the sheet. Because of the grain structure, it has a compression rating greater than 60 PSI, which is greater than other types of blue or pink foam. Spyderfoam density is 2.3 # per cubic foot.
EPP - Expanded Polyproplyene Foam:
EPP is flexible foam that is used as a packing material for delicate electronic parts. It is also used in the bumpers of some automobiles. It is a rubbery material that is light in weight, yet very durable.
EPP is available in 1.3# and 1.9# densities. EPP is used in the modeling world for combat gliders that need a high degree of durability. Since EPP is not a rigid foam, most all EPP gliders use fiberglass, carbon fiber, or spruce spars for stiffness.
Because of it's lack of rigidity and higher cost, EPP foam is not generally used in models that are covered with balsa, plywood, or obechi sheeting. EPP wings are typically covered with colored shipping tape, or low temperature heat shrink coverings like UltraCote. EPP is about 3 1/2 times more expensive than white beaded foam.
This information courtesy of http://www.flyingfoam.com
Old Mar 26, 2012, 04:37 AM
Gomgat is offline
Find More Posts by Gomgat
Joined Oct 2011
Foam density calculations
I have tracked down a supplier who can give me EPP with the following rating:
965mm x 580mm x 150 mm @ 3.3kg for the block.
However, I am not sure my calcs are correct and this seems a bit on the heavy side. Can someone please help me convert it to number I can compare in your # rating?
Many thanks
Gomgat is offline Find More Posts by Gomgat
Old Mar 26, 2012, 10:20 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
EPP is usually sold in pounds per square foot.
Usually 1.3lbs and 1.9lbs, although I have heavier and lighter.
Butch777 is offline Find More Posts by Butch777
Old May 23, 2012, 08:43 PM
Adverse Effects is offline
Find More Posts by Adverse Effects
Australia, QLD, Acacia Ridge
Joined Dec 2011
it is sold like that for the country's that haven't moved in to the 20th century (metric)
Adverse Effects is offline Find More Posts by Adverse Effects
Old Jan 19, 2016, 11:59 PM
azamkl is offline
Find More Posts by azamkl
The Flying Ants
azamkl's Avatar
Malaysia, Selangor
Joined Aug 2007
For a references, here I posted a few images that hopefully help others rectifying the product.
Local company that supplied all these products can be view at their website here: http://www.mymaterial.com.my/foam/
azamkl is offline Find More Posts by azamkl
Old Jul 06, 2016, 02:21 AM
stsguy is offline
Find More Posts by stsguy
Where o where has my America g
stsguy's Avatar
United States, TX, Spring
Joined Aug 2013
Amazing article. My questions are many but I'll try to limit to one for now..when designing a fpv race wing. You would want (I believe) toughness for many wrecks you will Encounter so EPP seems best. However speed only works well with a rigid wing. So your thoughts on how to make this decision? And what is the average difference in cost 20%. 30% higher for EPP?
See I couldn't do it ... more than one question
stsguy is offline Find More Posts by stsguy
FAQ on differences between types of foam. erashby Power Systems 2 May 30, 2016 12:09 PM
EPP Foam Suppliers wim5150 Electric Plane Talk 6 Feb 18, 2009 10:04 AM
Discussion What is the Difference Between EPS and EPP Foam? BrentB Foamies (Kits) 5 Oct 31, 2006 02:34 PM
FAQ on differences between types of foam. erashby Foamies (Kits) 1 Mar 07, 2002 12:54 AM
blue/pink/EPP foam froghead Electric Plane Talk 1 Jul 02, 2001 04:01 PM
