Old Dec 15, 2004, 04:13 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Top ailerons are not movable, just a stroke of pencil ... It's called the KISS principle .
I set rates on ailerons at 125% and it rolls just fine. I suppose you can make the top ailerons movable either with (somewhat ugly) connector rods or those tiny servos 4g in the upper wing.
Herb is offline Find More Posts by Herb
Old Dec 15, 2004, 04:28 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by Herb
... I set rates on ailerons at 125% and it rolls just fine.
Can you equate that to either angular deflection or travel distance of the trailing edge relative to neutral position? The 125% rates doen't give me much to go on
Tom Frank is online now Find More Posts by Tom Frank
Old Dec 26, 2004, 07:43 AM
jlandis is offline
Find More Posts by jlandis
Joined May 2004
The plane is all done. Too cold and gusty here in Pittsburgh to maiden yet. Took her out tothe driveway to make sure she tracks straight on taxi- had to adjust the rear wheel wire a bit. I think this is critical given that the tail wheel is attached to the rudder. and any correction in steering on takeoff results in the rudder being deflected also- can make for a hairy liftoff IMHO.
My wife gave me a new Apogee 2400 mah battery for Christmas that fits perfectly in the battery bay. Also fits in my new GWS corsair and estarter.
Will post a couple of pictures when I get home. And with my new Panasonic digital video camera, I hope to post a video of the maiden also.
jlandis is offline Find More Posts by jlandis
Old Dec 27, 2004, 07:37 AM
Brutus is offline
Find More Posts by Brutus
Glue can fix that.
Brutus's Avatar
Sunny Miami
Joined May 2004
sounds like you had a damn good xmas.
Brutus is offline Find More Posts by Brutus
Old Dec 27, 2004, 09:12 AM
jlandis is offline
Joined May 2004
Brutus-
I did. I am very blessed.
Old Dec 28, 2004, 11:30 AM
jlandis is offline
Joined May 2004
Pictures
Here are some final pictures of the build.
Below is the completed plane.
Old Dec 28, 2004, 11:34 AM
jlandis is offline
Joined May 2004
Battery
Some pictures of the new Apogee battery and it's installation.
Old Dec 29, 2004, 02:37 AM
mstrcntrlprgrm is offline
Find More Posts by mstrcntrlprgrm
Joined Dec 2004
I'm building my tiger moth 400. The field I fly in is uncut grass so I always hand launch. I'm a little worried about mounting the landing gear wheel on the tail. My instinct is it will rip off the rudder. Also, I'm not sure about the front landing gear either.
What's the best setup for landing in the grass?
mstrcntrlprgrm is offline Find More Posts by mstrcntrlprgrm
Old Dec 29, 2004, 06:14 AM
sa-10 is offline
Find More Posts by sa-10
sa-10's Avatar
United States, GA, Kennesaw
Joined Jul 2002
Just remembered from a past experience. Caution on handing the upper wing before mounting in upper support struts. I was not careful while applying a paint on rub off finish and cracked the wing at its weakest point. If you look closely, you will see where that point runs through the upper strut mounting slot. It was easily repairable, but only after the 10 minute long shock subsides.
sa-10 is offline Find More Posts by sa-10
Old Dec 29, 2004, 03:18 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Both Mark (Gund) and I had the upper wing break cleanly at the weakest point, where the slit is located for the center cabane strut to slide in. Mine broke during a rather sedate roll ... We both landed ours fine, flying only on the bottom wing .
Using epoxy there - and some further slight reinforcment - might help avoid unpleasant surprises ...
We both have four lightweight aluminum tubing struts instead of that floppy brown plastic stuff (Mark's original suggestion).
Old Dec 29, 2004, 05:11 PM
SergeantAsh is offline
Find More Posts by SergeantAsh
DroningON . co
Somerset
Joined Nov 2004
I fly all my GWS models from grass using the standard undercarriage, but with slightly larger foam wheels, never had an instance of the rudder snapping, bear in mind that the rear wheel is actually supported by the small plastic bit that you epoxy to the very back underside of the fuselage.
Just finishing my Tiger 400 tonight hopefully, ready for maiden tomorrow! Always best to maiden via a rolling take off, its more forgiving should you trims be a little out!
Planning to run on a 2s 2600mah pack, also and probably more frequently, I'll be using the 3s 1700 mah E-Tec pack.
VERY excited!!!
On another note, where the struts from the fuselage fit into the top wing, has anyone else glued this, or devised some method of securing it a little? seems like a bad design to me!
SergeantAsh is offline Find More Posts by SergeantAsh
Old Dec 30, 2004, 10:14 AM
jlandis is offline
Joined May 2004
Winds are calm here in Pittsburgh. Hope to maiden in about an hour.
Old Dec 30, 2004, 02:25 PM
jlandis is offline
Joined May 2004
She Flys
Finished a near perfect maiden today. The winds were fairly calm at the start. I was using my Apogee 2480mah battery and a 9060 prop. The rest of the plane is stock. ROG was good- about 10-15 feet and she was airborne. This plane flies like a dream. A little aileron and she starts to turn- keep the nose up though. Nothing fancy today just getting used to how she responds. Unlike the estarter, you have to apply opposite aileron to bring her out of a turn. I found this plane to fly much easier than the estarter.
The only problem came with landing- I cut the power down, headed her into the now stronger wind and at about 4 feet off the runway the wind flipped her over and into the ground. The fuselage broke right at the center wing strut attachment point. Pictures to follow tonight when i get off work.
BUT, a little epoxy and she should be good as new.
Now that I have this plane maidened, I do not feel so bad about starting my C-47. Or maybe the Corsair....................hmmmmmmmm.
Old Dec 30, 2004, 02:52 PM
DroningON . co
Somerset
Joined Nov 2004
Anyone any response to my question, whether or not you should glue the two struts into the center of the wing, or find a way of securing it but being able to remove it again? Last thing I need to do!!
Old Dec 30, 2004, 03:02 PM
jlandis is offline
Joined May 2004
Glue them
The only way to secure them is to glue them. It makes for ackward storage of the plane but there is no other way.
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Electric Plane Talk 8 Feb 05, 2006 03:12 PM
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Parkflyers 0 Jan 23, 2006 05:39 PM
Tiger Moth 400 build "scale details added" Cruzer Parkflyers 9 Feb 20, 2005 12:50 PM
Tiger Moth 400 Build fuzzyhead Parkflyers 0 Oct 24, 2004 07:34 AM
Tiger Moth 400 Build and Maiden Flight review AirWarriorBelgy Parkflyers 180 Aug 16, 2004 02:23 PM
