Old Dec 09, 2004, 11:57 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by jlandis
Also notice the use of Dubro mini connectors. They are an indespensable part of my builds- they make the final servo adjustsments so much easier.
I've never used these (or other screw-type adjustments), because they look inherently problematic. I'm curious... what keeps the screws from coming loose? A good old z-bend at the servo arm and v-bend for adjustment on the wire is inherently safe and very easy to adjust with pliers (for me).
Tom Frank is online now Find More Posts by Tom Frank
Old Dec 10, 2004, 12:38 AM
thunder1 is online now
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
The screws stay tight just fine. It all depends on how well you tighten them. I've actually found that since the screws are steel and the connector housing is aluminum it's easy to overtighten them. That leads to the screw staying in even tighter but makes it difficult to remove.
They make adjustments very easy. I use them on all my planes. Never had one come apart in flight. Just make sure to check them out thoroughly before the maiden flight.
thunder1 is online now Find More Posts by thunder1
Old Dec 10, 2004, 03:05 PM
jlandis is offline
Find More Posts by jlandis
Joined May 2004
I agree. I have never had a problem with the EZ connectors.
As far as the end pin Rx, I did not realize that was what I was getting when I ordered them. They just came, and too much hassle to return them.
Wet, rainy and muddy at the flying field today- no maiden yet.
jlandis is offline Find More Posts by jlandis
Old Dec 10, 2004, 10:07 PM
intermision is offline
Find More Posts by intermision
Rocket Surgeon
intermision's Avatar
Sugar Land, TX
CAan you fit an 8 cell brick pack into it easily?
intermision is offline Find More Posts by intermision
Old Dec 10, 2004, 10:23 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
If you look closely at Post #1, you'll see the inside of one half of the front of the fuselage. That center slot is the battery bay, and it can't even hold a flat 2/3 A pack without some rounding of the foam on the rear edge to allow the pack top be inserted from above through the cockpit opening. A brick pack that it 2 cells high would require removing all the foam between the battery bay and the lower cooling air slot! I wouldn't do it... but, it's probably possible... your choice!
Old Dec 11, 2004, 12:05 AM
ElectRick is offline
Find More Posts by ElectRick
Eye Drather Beef Lying
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
It's best to decide what style/size battery pack you intend to use before you join the fuselage halves. That way you can cut out the battery area to fit while it's easy to do so.
Of course, this idea doesn't help if you've already glued it together.
I used a Kokam 3S 1500 LiPo in mine, and it's the perfect pack for this bird, IMO. It fits snugly into the battery slot, but only after you open the slot up a bit to get it to slide forward enough to balance with no clay. But it WILL balance...mine balances perfectly with the pack sticking out clear of the slot by about 1/2" inch or so.
Here's a trick I used to hog out the foam in the top of the slot a bit more after I'd already finished the build (I had opened the slot up some before fuse assembly, but it wasn't quite tall enough).
Take an old butter knife and bend the blade to about a 30-40 degree angle to the handle. Attach a strip of 60 grit sandpaper to the blade with a bit of rubber cement or spray glue and use it to sand out the slot to fit your pack. You could also add sandpaper on the bottom of the blade too, for the bottom of the slot, if necessary. Works great.
Rick
ElectRick is offline Find More Posts by ElectRick
Old Dec 11, 2004, 05:53 AM
coillte is offline
Find More Posts by coillte
ireland
Joined Nov 2004
I have been following your thread and cant wait to see it in the air.Best of luck. I hope santa brings one for me for christmas.
Coillte
coillte is offline Find More Posts by coillte
Old Dec 11, 2004, 08:56 AM
Ekim is offline
Find More Posts by Ekim
Linux addict
Ekim's Avatar
S. Jersey, US, the 51 state
I hollowed out for the kan1050 and no structural problems there, but is pretty thin.
Ekim is offline Find More Posts by Ekim
Old Dec 11, 2004, 04:51 PM
College Park, MD
Joined Sep 2002
To get a larger battery bay I hollowed out the whole front of the fuselage with a long carving knife. I epoxied a piece of lite plywood to the bottom of the inside of the fuselage and use velcro to keep the battery in place.
It helps keep the battery cool and it's easy to get large batteries in and out of the front cockpit.
I've never had a problem structurally. The landing gear get attached to another flat piece of plywood epoxied to the bottom of the fuselage. That probably adds a lot more strength than stock.
Old Dec 12, 2004, 05:40 PM
Rocket Surgeon
Sugar Land, TX
I was just looking through my TM kit, and I was wondering if you have to drill out the prop to make it fit?
Old Dec 12, 2004, 06:06 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Tom Frank
... they look inherently problematic... what keeps the screws from coming loose? ...
Locktite, CA, silicone glue, acrylic paint etc . Works just fine and is the most practical way of setting up cleanly these parkflier linkages.
Built mine in one evening and painted it the next (slope glider). About 30 flights on it, Himax 2025 5300 on 6.6 gb, 10x6 apc, Kontronic smile controller, Kokam 15C 2000 3S, ca. 180 Watts. Light aluminum struts.
Herb is offline Find More Posts by Herb
Old Dec 12, 2004, 11:00 PM
College Park, MD
Joined Sep 2002
Yes. The EPS400 prop shaft is 4mm.
Old Dec 13, 2004, 02:28 PM
ElectRick's Avatar
Jacksonville, FL
Joined Aug 2002
Odd. My supplied prop fit the shaft with no problems, without drilling.
Must be some variations in what prop goes into the kit boxes.
Rick
Old Dec 14, 2004, 07:07 AM
Brutus is offline
Find More Posts by Brutus
Glue can fix that.
Brutus's Avatar
Sunny Miami
Joined May 2004
depends on the prop.
I believe all the Slow flyer props are 3mm, and the other series such as the HD are 4mm.
Brutus is offline Find More Posts by Brutus
Old Dec 14, 2004, 04:24 PM
sa-10 is offline
Find More Posts by sa-10
sa-10's Avatar
United States, GA, Kennesaw
Joined Jul 2002
Herb, would you please post pictures of your aileron mod? Or a sketch?
sa-10 is offline Find More Posts by sa-10
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Electric Plane Talk 8 Feb 05, 2006 03:12 PM
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Parkflyers 0 Jan 23, 2006 05:39 PM
Tiger Moth 400 build "scale details added" Cruzer Parkflyers 9 Feb 20, 2005 12:50 PM
Tiger Moth 400 Build fuzzyhead Parkflyers 0 Oct 24, 2004 07:34 AM
Tiger Moth 400 Build and Maiden Flight review AirWarriorBelgy Parkflyers 180 Aug 16, 2004 02:23 PM
