Old Dec 08, 2004, 09:42 PM
jlandis is offline
Find More Posts by jlandis
Joined May 2004
Pictures
Here are a couple of pictures. Below is the radio gear installed. I tested the servo's and they seem to have a bit of jitter. Moving the EZ connects in to reduce the torque helped reduce it. I think the throw will still be enough.
jlandis is offline Find More Posts by jlandis
Old Dec 08, 2004, 09:44 PM
jlandis is offline
Joined May 2004
Cowl
Here is a closeup of the cowl attached. Also, note the wheels. I was not happy with the GWS wheels so I got some new ones. I have used these on my estarter and the ROG are much more smooth with these typewheels.
Old Dec 08, 2004, 09:46 PM
jlandis is offline
Joined May 2004
Other pictures
And a couple of other pictures of the nearly finished plane. I would attach the wings tonight for a final picture but will keep you waiting in anticipation. I worked all last night and am too tired to complete.
Old Dec 09, 2004, 08:34 AM
jlandis is offline
Joined May 2004
Wind picked up this morning so no maiden today.
Old Dec 09, 2004, 09:06 AM
sa-10 is offline
Find More Posts by sa-10
sa-10's Avatar
United States, GA, Kennesaw
Joined Jul 2002
Dont forget to cycle your cells!
Nothing burns a maiden quicker then non cycled cells, with the exception of incorrectly reversed servos.
I hope your not going to fly on that cell pack that is in the picture. Are you?
sa-10 is offline Find More Posts by sa-10
Old Dec 09, 2004, 11:54 AM
jlandis is offline
Joined May 2004
sa-10
Sure that is one of my best packs!
Actually that is a couple of old cordless phone batteries put together to give me a cheap 7.2v battery to use for testing servos, programming my Pixies, testing receivers. Guess you could call it my shop battery.
Old Dec 09, 2004, 11:55 AM
jlandis is offline
Joined May 2004
Battery
The pack I will fly with is a 3S1P 1500mah lipo.
Old Dec 09, 2004, 12:29 PM
intermision is offline
Find More Posts by intermision
Rocket Surgeon
intermision's Avatar
Sugar Land, TX
I plan I getting some Kan 1050s to power my TM 400, what configuration should I get?
intermision is offline Find More Posts by intermision
Old Dec 09, 2004, 01:39 PM
Ekim is offline
Find More Posts by Ekim
Linux addict
Ekim's Avatar
S. Jersey, US, the 51 state
I carved out the battery bay and put in a hump pack
Ekim is offline Find More Posts by Ekim
Old Dec 09, 2004, 01:56 PM
Rocket Surgeon
Sugar Land, TX
Whay leyout would work so I wouldn'r have to carve out the bay?
Old Dec 09, 2004, 10:35 PM
jlandis is offline
Joined May 2004
Too cramped
In trial fitting my plane tonight I noticed that the following picture with electronics does not work. The aileron servo hits the receiver when placed where it is in this picture. I am still trying to fit it together and will post a final picture later.
Old Dec 09, 2004, 10:36 PM
jlandis is offline
Joined May 2004
Any thoughts on the chatter I am getting from these small (cheap/inexpensive) servo's?
Old Dec 09, 2004, 11:31 PM
thunder1 is online now
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
I haven't heard much about the interflight 4.6g servos but a lot of the smaller servos have a reputation for being jittery.
Have you tried different servos in the same receiver/esc combo?
Try to use a dedicated receiver battery instead of the esc to eliminate the ESC as a suspect.
thunder1 is online now Find More Posts by thunder1
Old Dec 09, 2004, 11:43 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
I use 8-cell 2/3A packs in my GWS PT-17, and will do the same in my TM400 that is not yet built. Use either a side-by-side flat pack or a double-stick (4 cells end-to-end, two cells wide. The latter is just a tad shorter and also narrower, and is my favorite. I think it will still be necessary to remove a little foam on the upper underside of the pack cavity so the packs will slide in through the cockpit opening (I saw this in another thread), but this will fit the best and will get enough weight up forward for balancing with little or no clay (from what I've been told by others).
Tom Frank is offline Find More Posts by Tom Frank
Old Dec 09, 2004, 11:44 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
This is the main reason I don't use end pin RX anymore!
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Electric Plane Talk 8 Feb 05, 2006 03:12 PM
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Parkflyers 0 Jan 23, 2006 05:39 PM
Tiger Moth 400 build "scale details added" Cruzer Parkflyers 9 Feb 20, 2005 12:50 PM
Tiger Moth 400 Build fuzzyhead Parkflyers 0 Oct 24, 2004 07:34 AM
Tiger Moth 400 Build and Maiden Flight review AirWarriorBelgy Parkflyers 180 Aug 16, 2004 02:23 PM
